Question about Wittnauer 11D04 Savoy Dial Stainless Steel Gold Plated Watch for Men
I need to know where to get dial, movement and hands for a Wittnauer Men's 11D04 watch replacements and individual costs. Can you help?
  • Wittnauer Master
  • 19,396 Answers
Hi.
The primary distributor for Wittnauer parts is Bulova. They manufacture Wittnauer watches. Find the contact starting from their global page: Bulova - Bulova Homepage.
There are also several third party Wittnauer parts distributors. Here two links:
Wittnauer - WatchPart.co.uk - Quality Supply
Wittnauer : Watch Parts Supply
Sometimes parts can also be purchased used from Ebay. Here an example. At the moment I did not find parts for your Savoy listed on Ebay.
Call Bulova or one of the distributors listed above to find parts price and availability.
Regards.
Ginko
Posted on Apr 02, 2011
Battery on m Invict Pro Diver watch replaced , now the second hand stays swinging back and forth in the same place
Do the minute and hour hands keep proper time? I've seen your problem before when the hand has come loose from the center post that turns it. You probably need someone who knows what they are doing to pull the crystal and reseat the second hand. Do this when the watch is off!
Sep 08, 2014 | Invicta Pro Diver 9309 Watch for Men
Replace wittnauer wrist watch band
Looking for men's Wittnauer gold stainless watch band for JV 8243 Swiss 9544.
Please advise if you know where the are available.
Regards,
Steven Foxworth
sfoxworth1@comcast.net
Apr 10, 2012 | Wittnauer 10D02 Montserrat Watch for Men
Question 1:Well,this guy was gonna throw away this watch,so i asked him if i could have it.Now i have a Guess G65023G watch that doesn't work. I want to fix that. Problem 1:The minute hand turns when...
Well, thats a good watch. however, based on the conditions of your watch, probably, its battery is not dead. some of its mechanism were not in place or broken. Repairing it is advisable. Afterall it has no scratches like what you've said. So go for repair men!
Jun 09, 2011 | Guess G65023G Watch for Men
Two years ago , I bought Bulova 26e10 men watch and yesterday it stopped moving . I noticed that it was slower than normal watch first of all and then it stopped moving when I let it alone 3 days....
Don't know what battery but a watchmaker will be able to help you for a very reasonable cost. He will also inspect the rest of your watch, case and band. Your watch will likely need the chronograph reset also.
Mar 28, 2011 | Accutron 26E10 Lucerne with Chronograph...
The second hand was delayed by 2-5 seconds and then it quit altogether. I read that this meant that the battery was dead, so i got a new battery and replaced it. After replacing the battery the watch still...
You do not give a model number for your Wittnauer Montserrat. It does sound like it needs a reset - generally this is making an electrical connection for a few seconds between the positive terminal of the battery and a reset contact point on the watch movement - a pair of fine point tweezers is ideal for this.
HOWEVER - without knowledge of the movement used in this watch, this is just speculation.
Oct 14, 2017 | Wittnauer 10D02 Montserrat Watch for Men
Watch is new out of the box. Movement will not start. ???
mcdevito75 here, If your Wittnauer is a Quartz movement, look for a small piece of plastic, just under the crown (winder) remove this piece of plastic carefully and push the crown back down to start your watch, if it's an automatic movement, try to wind with the stem if you feel a resistance then winding will initially start yor watch by winding with 20--30 winds, if you feel no resistance when winding the simply rock your watch back and forth in your hand, you will detect something moveing inside the watch, this is the counter balance winding the watch, rock the watch back and forth for approx. 30 seconds to start an initial wind.
Jul 10, 2010 | Wittnauer Belasco 36 Diamond 27 Mm Watch...
My Wittnauer is jumping every 5 seconds
Your watch is fitted with EOL feature and let you know about insufficient battery power by moving seconds hand by 2-5-second increments. You have about two weeks time to change the battery from the EOL engagement or your watch will start to malfunction or even stop. In this case you will have to reset your watch after battery replacement. EOL = End Of Life (relates to battery only). Jumping seconds hand means it's time to change battery.
Rate me, plz.
Jan 04, 2010 | Wittnauer Laureate 12R12 Wrist Watch
I have a stainless steel wittnauer watch with chronograph and instead of being set on the :30 mark, it is set on the :01 mark on the stopwatch. i need it back to :30
Pull out crown and press and hold one of the pushers (depends on a movement model). Try till you see chrono hand moving and reset it by using correct pusher. Every time you try a different pusher - push crown in, then pull out and try again.
Rate me, please.
Jul 28, 2009 | Wittnauer Watches
Clean a watch
Watch cases and bracelets are cleaned in ultrasonic cleaning maschine with the help of special clening liquids.
Mechanical watch movements and mechanical parts of quartz and analog watches are cleaned in special watch cleaning maschines in 3-5 cleaning stages and cleaners.
Electronic parts, circuit boards, LCD screens are cleaned by hand using specialy made cleaning solutions for each individual part.
To do all this you need a watchmakers skills as the watch must be disassembled completely.
Do not forget to rate, please.
Jan 25, 2009 | Bulova Watch
Wittnauer 11D04 Savoy Dial Stainless Steel Gold Plated Watch for Men Logo
75 people viewed this question
Top Wittnauer Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Wittnauer Watch Expert? Answer questions, earn points and help others
