It's cost two much if there anymore cheper - Computers & Internet
  • Vernal McIntosh
    Vernal McIntosh Apr 02, 2011
    Exactly what cost too much
  • Computers & ... Master
  • 27,725 Answers
If you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
you might have to get a portable usb sound card if you mean dont have a sound card installed
Posted on Apr 02, 2011
Panasonic th-50pz700u
no , its ur pix sills if its a new 1 , if not ur tube as gone, it will cost more to fix a new tv , but if its not a plasma it mit be cheper 4 u
Sep 03, 2013 | Televison & Video
Travemate2420
Go to Tigerdirect.com they have the best adapters and if you call they will get the best match for you and they will be cheper than most
Jan 23, 2011 | Acer TravelMate 2420 Laptop AC Power...
I have a model 8445w. the crossover channel is broken. I need to order the part.
http://buyitnow64.stores.yahoo.net/brgasgrbucac6.html
It's aftermarket, but much cheper and works great, I suggest to go ahead and buy all 3 to replace.
Aug 20, 2010 | Brinkmann Grilling
To much play in clutch pedal inkage 1997 f250 7.3 not releasing all the way
there is a plastic bushing that goes on the clutch arm and in the master cylinder arm that wears out. it's enough to cause your problem.you can get an assortment pack at the parts store. it's still cheper than the dealer
Jun 16, 2010 | 1997 Ford F250 SuperCab
I FORGOT MY UNLOCK CODE
dont do that buy a smart sim is cheper
May 08, 2010 | Motorola Mobility RAZR V3
2005.5 Jetta Cd player says, CDC hardware error. How do i fix it?
local stereo shop will send it to the proper tech usually or offer a new stereo witch is somtimes cheper
Jan 28, 2010 | 2005 Volkswagen Jetta
No paper last years model
big help thanks four nouthing
Apr 28, 2009 | Kenmore Grilling
Leaking seal cost to fix?
which engine? if it's a 4.0L the seal is in the rear main bearing cap...I have seen people do a replacement without removing crankshaft but have never seen one done this way that worked. If leak is small, try some lucas sealer...It softens the seal and swells it a bit. Also use oil for high mile engines afterwards...that too contains a conditioner.
(cheper to try this than removing engine)
Good luck!!! If engine is not 4.0 check back with me and I'll tell you what I think. I didn't mention cost because engine removal is a lot of $$$
Apr 26, 2009 | 1996 Jeep Grand Cherokee
Computers & Internet Logo
David Payne
David Payne
