Question about Iomega (33090) 250 GB Hard Drive
My power source for hard drive doesn't work. pins broken. Where can I get a replacement ASAP? Part #31426900 Model#DA-30C
  • 12,061 Answers
Hi, yes you can,in fact I have just replaced a customers PSU for his 1 Terabyte drive, his PSU blew the onboard fuse, so we got a replacement, from Ebay, they have many many sorts all differing Pin-Outs, just look for the one that fits yours, (They have drawings) they are all pretty standard and there are about 3 maybe 4 types to choose from. Alternatively, if you cannot find the pinout, simply get an AC/DC supply, check the OLD adapter and just get one with same or more higher ratings in the Amps but same in Volts.
But check the internal drive actually works, the customers on didn't, the new PSU worked fine, however the HDD inside didn't, upon testing it was found that the USB electronics inside were OK, however the power transistor ON the actual HDD itself had "Blown" and was burnt and smelt that way. So B4 you get a supply open up the unit and check if all is well internally,.I NOW, use a SATA/IDE HDD/DVD to USB dongle, (Got from Ebay) and test it with this ...
Posted on Apr 02, 2011
I got a 2000 Chrysler Sebring n da ABS light is On. I drove it like dat 4 like 1*day n 2*times da ABS light turn off but da 2*times dat it turn off I experience a ugly feeling noise wen eva I push on da...
He told you what sensor to replace. Replace it. You don't have to replace any of the other ones. Plus , you can drive your car like that. It will still stop with out ABS...
Nov 11, 2014 | Cars & Trucks
I have the Western Digital My Book Essential Edition 250GB External Hard Drive. I have moved and lost the power cord. I purchased the DYNEX 500ma Universal AC Adapter as a replacement. When I plug the...
I don't have a photo of the AC adapter, but if you look on it the Voltage and Amperage specifications are;
Input: 100-240VAC / 50~60Hz
Output: 12VDC / 2A
This means the Input power can be from 100 volts to 240 Volts AC, and at 50 to 60 Hertz
The Output power is 12 Volts DC at no more than 2 Amp's. (Amperes)
Asian Power Devices Inc. has a model DA-24B12 that fits these specs.
Also a Wattac AC adapter model number - BAO362Zl-8-A01 will work.
Otherwise just use a 12 Volt, 2 Amp power pack, with a positive on center contact, and a 2mm pin hole
Sep 15, 2011 | Western Digital 250GB MyBook External USB...
Hi there, I have a Toshiba external HDD 250GB that is giving me some problems and need some urgent help! When I plug my external HDD into my laptop everything seems to work fine. The lights come on, the...
It sounds as though your issue is one of in adequate power. Do both the external HDD have their own power source, or are they powered through USB? if they are powered through USB it may be that as soon as the second drive spins up to transfer the files, it overwhelms the limited power of the laptop. You can try it with the laptop plugged in (though this may not provide it with more power than the battery) or by purchasing a usb hub with its own external power source so that it is not drawing power from the laptop, or purchase an external hard drive with its own power source
The other option is simpler and free, and its to copy the files first to your laptops own HDD, then unplug the source external hard drive, and then plug in the drive you want to copy to, then transfer the files from your laptops hard drive. This will of course take twice as long, but will cost you nothing.
May 29, 2011 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
Describe your Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive Problem Do you have a picture of the voltage and amperage adapter for the Western Digital 250GB MyBook External HD ?
Output: 12VDC / 2A
Nov 23, 2010 | Western Digital 250GB MyBook External USB...
Need power supply spec's for this WD25001032 hard
If you can procure it you need a "Wattac" AC adapter
model: BAO362ZI-8-A01 (made in China)
Otherwise you need a 12 volt 2 Amp. power pack with positive on centre contact & 2mm pin hole.
Mar 26, 2010 | Western Digital 250GB MyBook External USB...
Elements by WD, AC Adapter Failed
There are replacement models for this 5V/1.5A power supply that the AD6008 uses.
One of them is made by a company called "Asian Power Devices" [APD] and their model number for the replacement for this particular unit is: DA-30C01.
I've seen them for sale on www.amazon.com for around $25.00.
Feb 22, 2010 | Western Digital Elements powered by WD 320...
Broken pin on my Iomega power suupply P/N 31426900. Does not match four pin pictures on products
you can buy this here:
<a href="http://www.ep-mediastore-ab.de/netzteil-5v12v-kompiomega-31426900-p-80445.html">http://www.ep-mediastore-ab.de/netzteil-5v12v-kompiomega-31426900-p-80445.html</a>
best regards
k
Dec 04, 2009 | Iomega (33090) 250 GB Hard Drive
Replacement power cables
Can find them on eBay, if you can narrow down on the manufacture date. For the model I had, either Acbel AD6008 OR Asian Power Devices (APD) DA-30C01 work. I ordered a replacement which worked - but my real problem was needing a new hard drive casing. So now I have 2 power cords I don't need...but at least I have my data.
Jan 21, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
I have a Iomega 250GBExternal hard drive. The pins that connect to the hard drive via the adapter pack have broken. The serial number is 579233448 the model no is DA-30C03 and the p/N is 31426900. I wanted...
i have the same probleme . I have a Iomega 250GBExternal hard drive. The pins that connect to the hard drive via the adapter pack have broken. The serial number is 579233448 the model no is DA-30C03 and the p/N is 31426900. I wanted to know which is the correct product to buy please
Sep 08, 2008 | Iomega (33090) 250 GB Hard Drive
Open Questions:
See all Iomega (33090) 250 GB Hard Drive Questions
Iomega (33090) 250 GB Hard Drive Logo
49 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
