Question about AudioBahn AW1500 Car Subwoofer
I have two audiobahn aw1500 15" subowoofers and i was trying to figure out how to wire them so that they come to 2 ohms. I have a Kicker 400.1 amp that is 2 ohm stable.
    Habit-Forming:
  • 50 Answers
What is their ohms at the moment. If they are 8 ohms the will become 4o hms in parallel, 4 ohms will become 2 ohms in parallel. Since your audiobahns are dual four ohms coils one speaker wired in parallel gives you 2 ohms and both wired together in parallel will give you 1 ohms. You will need to wire them in series parallel to to keep two ohms and that is a waste of power. Kickers are good amps, with a little extra cooling the amp should sustain the 1 ohm capability of your parallel connection or trade in for a 1ohm stable amp
Posted on Apr 02, 2011
My kicker dx 500.1 and my xpliod tens worked for all of ten seconds before the protect light went red then green keeps doing that
You are running more then 1 speaker on a 1 channel amp. You need to verify how many ohms your subs are, and what ohm you are wiring your subs to run at. Your amp is only capable of running at 2 ohms.
Here is a link to figure out how to wire them correctly.
http://www.crutchfield.com/S-FKw5viheGLo/learn/learningcenter/car/amplifiers/sub_amp_guide.html
Here is a link to your amplifiers specifications.
http://www.kicker.com/dx_amplifiers
Jun 06, 2011 | Kicker Car Audio & Video
Best amp for two l7 15inch speakers are 4 ohms
i personally like the audiobahn a.k.a. cheater amps ill go with the A2300hcx model
May 10, 2010 | Car Audio & Video
Need An amp for 2, 4ohm Kicker 12" L5
i bought two Audiobahn A2300hcx on ebay for a little over 400. look around on ebay you can really score sometime dirt cheap........ Check out audiobahn amps, never did me any wrong...........
May 06, 2010 | Kicker Solo-Baric L5 Car Subwoofer
Can i hook up my sub if it's wired to a 2 ohm and my amp is 4 ohm
Hi martineztag
You should never connect a load of an impedance less than the min the amp is able to drive. This can have disastrous consequences that may easily result in failure of the amps output stages. You need to use a different configuration that does not overload the amp in this manner for safe operation.
regards robotek
Jan 19, 2010 | Kicker Solo-Baric S12L5 Car Subwoofer
I have an Audiobahn A8000T amp and 2 12" Kicker CVR (DVC) Dual voice Coil. The Subwoofers are 2OHM a peice. What is the best way to hook this all up to run a 2 OHM load to my subs?
This is a link to Kicker for your CVR12 Subs...if you have the 2 ohm version (2 ohms per voice coil) and you have 2 speakers ....you will need to wire EACH speakers voice coils in series to get 4 ohms from each speaker and then wire the 2 speakers in parallel.....as in....2 ohms in series with 2 ohms = 4 ohms....both speakers wired same way, then in Parallel with each other = 2 ohm load. Page 2 of this link gives examples of both series and parallel wiring of your speaker.
http://www.kicker.com/sites/default/files/2006CompVX.pdf
If you are still not sure as to my description of ' How To',
PLEASE respond and I will attempt to explain it EXACTLY via wiring directions.
Nov 18, 2009 | Kicker CVR12 Car Subwoofer
Help me with my system
More information is required to start solving your problem. (ie. your make and model of "1500W amp", the voicecoil configuration of the kicker and Audiobahn 15's, and why you want to encorprate 2 crossovers in your system)
Seems as If you have a system without a plan.
Head unit?
More info necessary to give you the best use of your components.
Jan 14, 2009 | KEF Audio PSW 2150 Speaker
I dont know which wires go where on the back of my sub woofer. its an audiobahn aw1251t woofer, 400 watts
I used to have exactly the same subwoofer. It has dual voice coils which are driven independently.
Hope the diagrams help out. Just make sure you know how many ohms your amp is.
Wiring Option #1
Wiring Option #2
Nov 20, 2008 | AudioBahn Car Audio & Video
Tryin to hook up 3 10
The Class D amps from JL are good down to 1.5ohm. The class A/B amps are good down to 2ohm.
I take it you have (3) 4 ohm subs? Wired in parallel?
Consider looking for an amp that is 1 ohm stable for this load such as audiobahn, or kicker.
Dec 11, 2007 | Car Audio & Video
Kicker solobaric l5 12''
how to wire a kicker solo baric l5 12'' 4ohm down 2 and 1 ohm
Sep 25, 2007 | Car Audio & Video
AudioBahn AW1500 Car Subwoofer Logo
134 people viewed this question
Top AudioBahn Car Audio & Video Experts
Professor_V
Professor_V
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
