Question about Hitachi Televison & Video
Hitachi 42" Plasma TV 42PMA330A Television plasma is excellent in the sounds , nice deep and rich BUT the picture , it is clear but on start up it is fuzzy until the tv warms up and only happens sometimes and then the picture starts to flicker intermittently it also has a buzzing sound coming from the back. Please help me to sort this problem
5 Suggested Answers
  • 1030 Answers
SOURCE: Rear Projection... Hitachi tv
humm.. could be a crt or a high voltage problem..flyback transformer or high voltage splitter... have a tech check it out for you.
Posted on Dec 07, 2007
  • 15 Answers
SOURCE: 42 inch LG Plasma TV - Lost picture
ysus pcb that supplies voltage to the panel is faulty
Posted on Dec 15, 2007
holborn
  • 17 Answers
SOURCE: No picture and only buzzing sound coming from plasma with cracked screen
Most of the times this type of damage is due to panel overheating. This can occur due to many situations but most offten is due to internal mulfunction of some of the high power/voltage driving circuits. You can only hope that the dealer will replace the set under warranty. Do not settle with a repair.
Posted on Feb 07, 2008
SOURCE: I have no audio on my 42" Samsung plasma tv
This happened to me also. It had to be taken apart. The audio connector on the motherboard had come lose. Hope this helps.
  • 26 Answers
SOURCE: Plasma TV buzzing
If the adjustments on the power board are correct and if you are not at high altitude, the plasma display panel is defective. If the set is off warranty, it is not cost effective to replace the display panel. If it is off warranty, you should give the manufacturers Customer Relations a call. The phone number is usually right on the back of the tv. The manufacturer of the tv might make a warranty concession if they are concerned about their brand reputation. Some manufacturers find it less expensive to just switch brand names rather than make good on defective products. If all else fails, you might get some money back by selling the circuit boards on eBay.
Posted on Feb 20, 2008
I have a 42 inch Hitachi plasma tv that is making a very loud static noice coming from the internal speakers. It stays at a contstant very loud volume unless I completly mute the tv or turn the volum
Based on what you have tried if a buzz or loud static via the speakers you have something wrong in the audio output circuit of the set--problem here is that circuit may be part of the Main board that processes all signal---a look inside---following the speaker leads back would lead you to that board.
A simple thing to do to narrow it a little (you may have done this) is with sound all the way off put your ear to the internal speaker--hear anything at all like a deep hum?
Depending on age of set and cost of the board likely bad it may or may not be a do it yourself repair.
SD TECH
Apr 26, 2012 | Hitachi P42H401 42 in. Plasma HDTV
We have 42" plasma akai
Any luck getting this fixed?Please let me know.Thank You very much!
Tyler
Jan 31, 2011 | Akai LCT2715 27 in. LCD Television
42edt41a hitachi plasma tv went dark sound ok
sounds like your y and z drive boards over heated and need replacing...
May 31, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Sound Problems with Hitachi 42HDS69
Probably the main board, audio processer blown. about 300.00 to repair. A service tech told me this and the repair worked.
Feb 17, 2009 | Hitachi 42HDS69 42 in. Plasma Television
HITACHI 42" PLASMA SOUND BUT NO PICTURE COMPLETELY BLACK
it can be the loose connection on circuit board .can you resold the all pcb joints.
i will hlp you.or give it to service proffesional.
nuwan.
Jan 19, 2009 | Samsung HCL4715W 47" Rear Projection...
Hitachi Plasma screen flickers
Got sound but the picture intermittendly flickers on and off. checked all cables and connections had the tv about 3 years now.
Thx
Sep 06, 2008 | Hitachi 42HDS69 42 in. Plasma Television
42" Toshiba Plasma TV no picture or sound
My experience with 42" plasma tv's with no picture or sound was a missing power supply voltage. On the power supply board check voltages on the plug. The voltages should be marked on the board,
Mar 01, 2008 | Toshiba 42WP27 42 in. Plasma Television
ESA EDTV - 42 inch plasma TV, sound OK no picture.. has vertical lines.
pull plug. allow to reset. try again.
good luck on that, otherwise you need service.
good luck
mark
Nov 28, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Televison & Video Logo
99 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
