Question about Dryers
Dryer is no longer heating - Dryers
  • 1 more comment
  • Michael Hill Apr 02, 2011
    Hi Daniel,
    In my original enquiry I didn't provide model details which may help further. The dryer is an AEG Lavatherm 3300 Digitronic.
    Why do you think it is the thermostat rather than the heater element? There is no heat in the dryer at all.
    I'm also not sure of the reason for checking the dryer belt and idler pully. The drum is turning ok.
    Regards
    Mike
  • Michael Hill Apr 06, 2011
    Hi Daniel, I have managed to fix the problem. The thermostat and element were both ok. The problem was a wire brush that runs around the outside of the dryer drum. The plastic bracket holding it had snapped, no doubt due to age.
    I found it as soon as I took the top off the dryer.
    Thanks for your suggestions.
    Regards Mike
    Not really. I solved the problem myself after opening the top of the machine and seeing the broken part which I fixed.
  • 4,323 Answers
Hi
I believe that everything else is fine rather it is the thermostat that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if bad replace it as it cannot be reset. If the fuse is fine then check the dryer belt and idler pulley...Hope this helps...please post back for further assistance.
Daniel
Posted on Apr 02, 2011
  • Daniel Scott
    Daniel Scott Apr 03, 2011
    Hi Mike,
    Usually the thermostat or thermal fuse goes bad. The heater element doesn't turn bad easily. To be sure, turn off the power to the dryer and use a multimeter to check the heating element resistance (should be between 3000-3300 ohms). If element seems to be fine then check thermal fuse and thermostat. Replace if necessary. Also make sure if the dryer's door is latching.
    Hope this helps... please post back if you need more information.
    Daniel
  • Daniel Scott
    Daniel Scott Apr 06, 2011
    Thats Great Mike
The dryer no longer heats up and the timer no longer turns the dryer off .. .... the dryer works fine otherwise ... it is a gas dryer.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 29, 2010 | Dryers
My dryer is not getting hot or even warm
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 10, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
My dryer no longer heats. What's wrong?
heatman101
May 24, 2010 | Dryers
Gas Dryer no longer putting out heat.
heatman101
May 14, 2010 | Whirlpool GEQ9858J Dryer
Dryer is no longer heating? Could it be a heating
If it will run, but does not heat......Yes, it is most likely a heater or thermostat failure. Most dryers have more than one thermostat. You can find out which one is faulty by measuring continuity with a meter. At room temperature all thermostats will have continuity between the two terminals. Make sure to unplug the power cord before opening any machine!!
Apr 06, 2010 | GE Profile Wizard DPSE592EAWW Electric...
My dryer is no longer heating. I understand that
remove the back board first,then the top board.then the suspension system.
Mar 14, 2010 | Dryers
Dryer no longer heats. Checked continuity on the
check continuity of the thermal fuse,the cycling switch,the hi-limit switch any of these that are open will stop heating all are on or near the element or air flow path to the vent
Jan 27, 2010 | Kenmore 64902 Electric Dryer
My GE Profile Harmony Dryer is no longer Heating
Does it get hot when you turn it on, and then never gets hot again while its running? On my dryer the solenoid broke, when the dryer was cold it worked and the dryer operated properly because the dryer and solenoid were cold and the solenoid wire was closed, when the dryer was hot enough the solenoid opened and the heat would not restart. the solenoid is a coiled wire which is used to open the gas valve.
Dec 28, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer has no heat
either your heating element or your thermostats are bad. on the heating element casing there are two thermostats. check the top one for continueity if it doesn't have continueity the change both thermostats. if they are good then check your heating element for continueity. after you get your dryer heating then clean out your vent system... if it's not venting properly then your dryer will take a long time to dry.
Jun 16, 2009 | Frigidaire Dryers
Dryer no longer has heat to dry clothes
The element gets brittle and breaks. The element is in the rear of the dryer under the dustcover.
May 06, 2009 | Kenmore Dryers
Dryers Logo
87 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
