Question about Brother HL-2170W Laser Printer
I have a paper jam. Paper is caught up in printer
  • 71 Answers
Read page 85 of the manual:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002308/cv_hl2140_usaeng_usr_d.pdf
Posted on Apr 20, 2011
Paper jams in heater
Hello
An overheated fuser is one of the most common causes of a paper jam. When large loads of print jobs are pushed through a printer, the fuser slowly starts to warm up. As the fuser warms up, the heat causes the corners of the printer paper to bend. The hotter the fuser gets, the more the paper bends. Eventually the paper bends so much that it causes the paper to get stuck in the fuser, causing a jam.
If you cannot find any other reason for a continuous printer jam, the problem may be the roller. A cracked roller can easily grab a piece of paper and get it caught. A glazed-over or dirty roller can also cause the paper to get caught on the roller and jam the printer. If the roller is cracked or glazed, you may need to call your print technician or replace the roller.
THANK YOU FOR VISITING FIXYA
Mar 03, 2011 | Ricoh Aficio CL7000DTL Laser Printer
Paper jam in the region of rolling
rollers should be cleaned with a special solution if you do not use alcohol or replaced in case it rolls after cleaning paper jam message appears. If you use long rolls wear and print out if you need inlocuite.Observati paper reception area. that there was a paper route in case you caught it ever caught and torn paper inside the printer .. good luck!
Feb 25, 2011 | Samsung SCX 4521F All-In-One Laser Printer
I have a dell 948 all in one printer, clear paper jam then press check. There is no paper jam. I have follow instruction and site recommendation, ran printer software, problem still exist, please help
This is a known issue with Dell all in ones.
It's a problem with the power supply inside the unit.
If you were in the middle of a print job, though, and it jammed, do recheck as I've been caught out
with a paper jam where a tiny partical of paper was doing the jam. Look carefully before contacting Dell support.
Dec 31, 2010 | Dell 948 All-In-One InkJet Printer
Middle light blinking message says paper
Look for any small rips of paper caught in a sensor back there. There are little "fingers" that the paper runs over and its all timed. if one of those sensors are jammed with something or sticky, error messages.
Sep 22, 2009 | HP DeskJet 550c InkJet Printer
When we put paper in the printer it goes cricked
Lexmark printer have paper roller problem take printer for once service
Jul 25, 2009 | Lexmark X1270 All-In-One InkJet Printer
Paper jam
You have a piece of paper stuck in one of the switches that tells the machine you have a paper jam. One of the worst things to cause these are printing peel off labels as they sometimes peel off while printing and get caught in the mechanim. You have a jam it's just not a full size piece.
Jun 01, 2009 | HP LaserJet 3030 All-In-One Printer
CONTINUING PAPER JAM. I OPEN DOOR, CLEAR THE JAM, AND PAPER STARTS TO FEED, THEN AGAIN ANOTHER PAPER JAM, AM I USING WRONG PAPER?
I know the problem, Its the Exit paper sensor! if u make a short circuit on the pin 2 and 3 of the CN2 when the paper reaches the sensor it wont jam. Chainging the sensor resolves the continous paper jam or try to clean it!
Apr 08, 2009 | Samsung CLP 315 Laser Printer
Paper Jam light on, but no paper jam
A piece of paper torn from copy paper is caught around registration switch, exit switch or feedshift switch.
so check theme.
Jan 18, 2009 | Sharp AL 1631 Copier
Paper jam
This video explains how to resolve a recurring paper jam on your product. It sounds like the rollers on the rear access door may not be working properly and are making jamming the paper as it starts to feed up into the printer? Check the rollers on your rear access door and see if they have some give in them and roll freely.
Sep 27, 2008 | HP Photosmart C7180 All-In-One InkJet...
Brother HL-2170W Laser Printer Logo
62 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
