Hi, My tv is am Australian SONY Bravia KDL46XBR - 3100, I purchased it in 07. My problem is when I try and turn my tv on there is sound for 30 seconds but no picture then it switches itself off with a 5 blink fault code. Sometimes the sound doesn't come on either, but also occasionally the TV turns on and works perfectly but it's very few & far between when that happens. I have an extended warranty with a 3rd party, but it doesn't cover lamp replacements so I want to make sure it is or isn't that before I lose my TV for 5 weeks for them to possibly send it back saying that it's not covered under my warranty. Thank you very much for the help.
  • 6,993 Answers
Below are the interpretation of Sony TV blinking codes, so check the one yours fall under. Also, note that your warranty would be void if you open the TV back or unscrew the TV back cover. And to fix this problem, you must open the TV back cover. So the choice is your if you want to fix the TV yourself or use your warranty.
ONE Blink--- not used for the self-diagnosis
TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking, try turning up screen slightly.
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.
NINE blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative).
TEN blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Good luck.
Posted on Apr 02, 2011
We have sound but no picture
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by Repair.com 467,264 views. 2:30. LCD & LED TV Repair - No Image ...
How to fix sony bravia has black screen - Digital TV - Streaming ...
www.tomsguide.com/forum/56867-4-sony-bravia-black-screen
Aug 19, 2014 - 12 posts - ‎11 authors
Hello, My Sony Bravia TV screen has gone all black. The green on/off light comes on,but no picture appears. The model ... Your solution solved the non picture for live tvbut still no picture (just sound) fir OnDemand. Score. 0. No picture on LCD TV with HDMI cable plugged into ...
Aug 4, 2014
Tv problems picture ok but no sound - HDTV
Sep 8, 2011
More results from www.tomsguide.com
Dec 14, 2015 | Sony BRAVIA KDL-55XBR8 55 in. HDTV LCD TV
Sony Bravia KDL-46S4100, No Picture No sound
I have a sony bravia kdl 40v 5100 for less than two years and i did not purchased an extended warranty and now my tv is down.
I have no picture, no sound just a black screen when i turn the power on, the power (green) light is lite up and the tv turns off by itself for like less than 30 seconds. I have tried to press as many buttons on the remote control and on the side of the TV to get any message but nothing seem to happen. Any suggestions and solutions? Thanks
Aug 23, 2011 | Sony KDL-46S4100 46 in. LCD TV
Sony Bravia KDL46XBR-LCD. No picture but sound. Trouble shooting light blinks 5 times in cycles. What does it mean.
If your television blinks 5 times or for a count of times, it simply is indicating that there is a problem inside the unit.
The problem applying to this situation is a faulty lamp. The lamp is bad and simply need to be replaced.
As soon as you replace the lamp, the television will be in good condition once again.
Take care and good luck
Nov 06, 2010 | Sony KDF-E55A20 55 in. LCD Television
Sony Bravia periodically has loss of sound. Sound
then contact TECH support again . you have a warranty do you not ?
Nov 28, 2017 | Sony BRAVIA KDL52XBR2 Television
Problem using headphones 3.5mm output with Sony Bravia tv
Just mute the TV and you will get sound out of your headphones. You may have to turn the TV sound up though.
Sep 09, 2009 | Sony Bravia KDL-37L4000 37 in. LCD HDTV
Clicking sounds when turning off Sony bravia kld-40v4100
ACTUALLY WITHOUT SEEING YOUR PROBLEM PHYSICALLY I CANN'T SAY ANY THINK, BUT FOR YOUR KNOWLEDGE LET ME TELL YOU NO TV MAKES ANY KIND OF SOUND DURING SHUT OFF. & you are saying for more than 30sec, i think you should call the SONY TECHNICIAN for visit.
Dec 20, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sound problem
Go into your TV settings and change the Automatic Volume Control Sound Mode. It's probably at Dynamic and the TV is trying to adjust the volume. The popping sound may be caused by static electricity building up on the circuits of your TV or cable.
Does this also happen when you are watching a video/DVD?
Nov 27, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
I can't Tune my V32XBR1 in Australia
Greetings...
Are you connecting to a digital signal from a cable box using an HDMI cable?
Ed
Apr 03, 2008 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Televison & Video Logo
71 people viewed this question
Top Televison & Video Experts
