Question about Nikon Coolpix S4000 Digital Camera
My nikon coolpix s4000 can't read the memory card. Why
  • 17,970 Answers
Remove the memory card and you will find a switch on the left side of the card. It must be locked, so slide or push the lock on other side to open it and then insert the card back to the Camera.
Your problem carries all the hallmarks of "your card isn't fast enough". Check your manual to see what speed of card is required for HD video. If it doesn't say, try a card that says as least "Class 10" or "10Mb/s" or "66x". If you set the movie resolution down to 640x480 it has a better chance of working
Keep us updated.
Posted on Apr 02, 2011
Nikon coolpix s4000 write protected
Take out the memory card and you will see a small switch on the one side of it. Move the switch out of the lock position. It should say lock on one side of the memory card. Once you move the switch out of the lock position the camera is no longer write protected.
Oct 29, 2011 | Nikon Coolpix S4000 Digital Camera
How do i transfer picturesstored in my coolpix s4000 internal memory card to my computer or sd card
If you have a working connection between your camera and your computer, then simply remove the memory card before making the connection. You'll be able to transfer the pictures from the internal memory, since the card is not present.
To copy pictures from the internal memory to the card, use the Copy command in the Playback menu. Full details are in the "Copy (Copy Between Internal Memory and Memory Card)" section of the manual (page 100 in my copy).
Aug 27, 2011 | Nikon Coolpix S4000 Digital Camera
When my daughter was shooting a video her display said can't read memory card. Please advise. Eric
Unfortunately that may mean that the memory card has failed. Try reading it on a card-reader for the computer. If the computer can't see it, then you will have to purchase a new one.
Mar 06, 2011 | Nikon Coolpix S4000 Digital Camera
My Nikon Coolpix s4000 can't read the memory card on video mode. it will take the video for about 5 seconds and then it just stops recording. A message then pops onto the screen saying 'this card cannot be...
P.S. if you set the movie resolution down to 640x480 it has a better chance of working...
Feb 03, 2011 | Nikon Coolpix S4000 Digital Camera
What size and male of memory card do i need for a coolpix s4000?
The S4000 uses SD cards up to 2GB in size and SDHC cards up to 32GB in size. Don't worry about the make of the card, as long as you stick with the major brands (Lexar, PNY, SanDisk, etc).
Jan 14, 2011 | Nikon Coolpix S4000 Digital Camera
Is the memory card removale
Yes, the memory card is removable. The following web site gives different cards.
http://support.nikonusa.com/app/answers/detail/a_id/16778/~/approved-sd-cards---coolpix-s4000
The following is a list of approved memory cards for the Coolpix S4000 digital still camera. These cards have been tested and approved for use with the Coolpix S4000.
The S4000 uses SD (Secure Digital) memory. Memory cards with an SD Speed Class1 Memory of 6 or faster are recommended for recording movies. Movie recording may stop unexpectedly when memory cards with a lower Speed Class rating are used.
SanDisk 2GB2, 4GB3, 8GB3, 16GB3, 32GB3 TOSHIBA 2GB2, 4GB3, 8GB3, 16GB3, 32GB3 Panasonic 2GB2, 4GB3, 8GB3, 12GB3, 16GB3, 32GB3 Lexar 2GB2, 4GB3, 8GB31 Specification defining minimum data transfer speeds for SD and SDHC memory cards.
2 If the memory card will be used with a card reader or similar device, check that the device supports 2 GB memory cards.
3 SDHC Compliant. If the memory card will be used with a card reader or similar device, check that the device supports SDHC.
Other cards have not been tested. For more details on the memory cards listed above, please contact the manufacturer.
Jan 06, 2011 | Nikon Coolpix S4000 Digital Camera
In the process of buying a samsung l301 camera. how many photos can you take?
I would recommend you to buy Nikon Coolpix S4000 Nikon's Coolpix S4000 creates touching memories by combining 12.0 effective megapixels, 4x wide-angle Zoom-Nikkor glass lens and an amazing 3.0-inch High Resolution HVGA (460k-dot) touch-panel LCD with sensitive touch. The Coolpix S4000 also features HD (720p) movies for high quality movie recording. The Coolpix S4000, with Nikon's EXPEED image processing concept, 4-way VR Image Stabilization System and Smart Portrait System enables you to get incredible pictures, incredibly easy. Nikon's Scene Auto Selector automatically analyses the scene you are taking and adjusts the scene mode for you. All you have to do is compose, then touchYou can check out more detailed review for Nikon Coolpix S4000. http://hubpages.com/hub/Nikon-Coolpix-S4000-12-MP-Digital-Camera
Jan 30, 2010 | Samsung Digimax 301 Digital Camera
I am buying a Canon SD970 IS digital camera. What
I would recommend you to buy Canon PowerShot SX210IS 14.1 MP Digital Camera with 14x Wide Angle Optical Image Stabilized Zoom and 3.0-Inch LCD. Decidedly slim and sleekly refined, the PowerShot SX210 IS packs a feature set that reads like a wish list. The 14.1 Megapixel CCD joins a 14x 28mm Wide-Angle Zoom for imaging power to spare. Frame your shots in the bright 3.0-inch widescreen PureColor System LCD, with the Low Light mode for sharp images in dimly-lit situations. It also captures stunning HD movies with Dynamic mode for enhanced image stabilization when shooting movies using wide-angle settings. Capture smooth HD video (720p) with stereo sound for a truly natural, high-quality HD experience. The PowerShot SX210 IS not only goes wherever you do, but takes your photography and video to a whole new place, too. You can check out more detailed review for PowerShot SX210 IS http://hubpages.com/hub/Canon-PowerShot-SX210IS-Digital-Camera
Nov 16, 2009 | Canon PowerShot SD890 IS / IXUS 970 IS...
Nikon Coolpix S4000 Digital Camera Logo
298 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
