Question about Philips Televison & Video
I have a phliips hdtv lcd model 47PFL7422D/37. the left side of the screen is darker than the right. The screen started flickering. like a strobe light. any suggestions????
    Novelist:
  • 159 Answers
Hi, Yes unfortunately i know what it is. When repairing another make of hdtv one time, I used a different " BALLAST " for testing purposes-it was a little under powered to say the least-but i knew this-it allowed me to determine the bulbs were good. when the bulbs lit using my makeshift apparatus-HALF of the bulbs lit up lit up( dim on one side as well as some flickering! ) therefore you have a power supply that drives the backlights that is going "SOFT". Let FixYa know whatever else we can do to assist you. good luck. Prodzilla. P.S. there is a workaround you may try to give more life to this soft power supply, if able,go into menu and adjust brightness down a few notches until it evens out and stops flickering. Again good luck
Posted on Apr 02, 2011
I have this model N3735w Viewsonic LCD flatscreen TV and it is flickering. The screen is also getting darker.
Try turning off the automatic brightness feature . This mode adjusts the brightness according to the light level in the room.
Dec 26, 2013 | ViewSonic N3735W 37 in. LCD TV
I have a Philips lcd 1080p 46". The screen was
Every one of those I have repaired, I had to replace the controller ic on both the slave and master. Monitor the 5 volts on the controller and the output, that's a dead give away. Don't bother with the cf lamps, thats not your problem.
Aug 05, 2012 | LG 42LC2D 42 in. LCD HDTV
Philips 47pfl7422d 37 and flickering
Looks like the TV has developed dry solder/dry/shorting capacitors. To make sure, first of all try the same input device on some other TV. If it works there, you can be sure that your TV is having problems. Then I would advise you to stop using it to stop aggravating the defects. It is better to show it to a qualified service technician.
Jul 17, 2012 | Philips 47PFL7422D/37 Television
My screen goes dark. I can make out the picture but the left side is almost black, and the rest of it looks dark and/or flickers black.
I was told to replace the master and slave inverters as the capaciters were popped, still didnt fix the problem, have you had any luck???
Aug 16, 2011 | Philips 47PFL7422D/37 Television
I have a Philips Model 47FL7422D/37 the left side of the screen is darker than the right side and I can not adjust it. What is the problem.
Scrren problems can be a bad screen or a bad t-con board. The only way to check wich one is by trading out the T-con board, If the problem goes away it was the T-con board if it does not it's your screen. To find the part you have to get the part number from the actual part. you can order parts for this TV at www.interliquidparts.com
Jun 13, 2011 | Philips 47PFL7422D/37 Television
Our sanyo lcd tv is a couple of years old and recently when the tv is on for the first couple of hours the screen will flicker and get progressivly darker from the center of the screen to the left....
Hello; I am John at J. D. Electronics, Poland Maine. This problem is caused by a defective LCD panel. This part is very expensive! Aprox $ 1000.00 from Sanyo and less than $400.00 from Encompass Parts Inc.
Oct 09, 2010 | Sanyo DP46849 46 in. HDTV
Flickering screen. Picture is darker and the left side of the screen(when looking at screen) is weaker than the right side. Flickers for about 15 seconds then screen goes black
Ur LCD inverter board is dying.Must replaced this board,to get picture back good.Tries Shopjimmy.com,Ebay.com for the board.It a long board.
Jan 10, 2010 | Astar LTV-3001 Television
Televison & Video Logo
450 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
