Question about ASUS P5NSLI (0610839134670) Motherboard
Just bought x6800 for p5nsli. will not display or beep. is there a jumper setting? manual on disk but w/o system can`t access
    Sniper:
  • 69 Answers
You can get the manual here : http://dlcdnet.asus.com/pub/ASUS/mb/socket775/P5NSLI/e2234_p5nsli.pdf
I would think you need to upgrade your bios to support the new CPU.
Posted on Apr 02, 2011
Getting three beeps with my asus m4a785t-m motherboard initializi
Okay, not much else is mentioned about the system so I would assume you have one CD/DVD drive and now two HDDs and your new HDD is still set to factory default of "Cable Select" or CD, if not and the new hard drive is a replacement for a damaged OS (Operating System) drive, then you need to insert the Windows OS Installation disk prior to booting and set the system to check your CD-ROM before checking Hard disks, for the OS.
First off if IDE, you have a ribbon that resembles this [====[========[ the furthest to the right would be what plugs into you motherboard, being the one with the furthest distance between itself and the next plug/connector.The one on the other end is for the Master drive and teh middle one is for Slave.
If only one HDD, then the jumper for the new drive needs to be set to Master and the CD/DVD-ROM needs to be set to Slave.
  • If two HDDs & one CD/DVD Rom, On the primary IDE Controller, set the OS HDD to Master, the CD/DVD-Rom to Slave & put the second HDD on the secondary IDE Controller as Master.
  • If two HDDs & 2 CD/DVD-Roms they must be set up on totally different IDE controllers to cancel out the chance of cross-communication. This happens on some systems because of having two CD/DVD Roms and/or two IDEs. So, we set the OS HDD to Master on the Primary IDE Controller & we set the CD/DVD-Rom to Master on the second IDE controller and the
I would normally say that three beeps from the motherboard itself would be either graphics card or memory problems, normally solved by simply pulling either or both and reseating them. Wear Nitrile gloves (the blue ones) to keep oils and static charge from damaging the components, ground yourself &/or touch the case before and while pulling the components. Check this site for "Post Codes" if the beeps are coming from the MoBo... if you have Award BIOS (should show what BIOS brand when booting up the system)
Award BIOS Post Codes
If three beeps from the system itself, then that would say it can't find the OS... and you might possibly also find an error on the monitor, stating something similar to "no power to monitor".
If you don't have an illustration on your drive telling you what pins are for what when it comes to the jumper, then search google for the drive brand and the word "jumper" or words "jumper configuration" or "jumper placement"
example: Maxtor Jumper configuration
If the system is SATA only (I believe it to have at least one IDE controller unless the board's controllers are all blue & black, to which I see a controller, but can't tell if it is FDE or IDE), then you'll most likely have to enable the SATA controllers in BIOS and set the boot preference/sequence/order as mentioned above, to check the correct disk for the OS, after removable devices & CD-ROM. Should be that order anyway, with floppy seek disabled to save wear on the head.
Hope that was not too much and that it helps!
Apr 15, 2010 | Frigidaire FEQ1442ES Electric Dryer
Tip
BIOS error, System Failure, Boot failure? ? Lets FIX it.
I guess everyone working on a computer is familiar with the word BIOS and what exactly it is? Still let me tell that BIOS is intelligent software that enables the system to start. I need not to mention that system here refers to computer. Bios facilitate the booting of a system without human intervention. BIOS is a program that is installed in a hardware chip known as ROM chip.
This single word matters a lot to most of the users who face various problems when their system failed to start normally or make some unusual activities. Each time I visit any technical forum I see a lot many users posting their problem regarding BIOS. I researched on internet about BIOS errors and from my knowledge and experience I am posting this piece of help for those who find themselves helpless in getting a solution to BIOS problems.
Sometimes BIOS itself provide a troubleshooting to most of the problems. When you power ON your system it give beep sound. Checkout some beep codes
1 short Beep indicates System is OK (Acceptance Beep)
Continue long Beep tells RAM Problem
1Long 3 Short Beep confirms RAM Problem
2/3/4 short Beep --its time to Check the RAM & Video Card
By now most of you have found some clue about the problems you are facing. Now learn about POST faults
1) K/B Error/ NO Keyboard present
· Check the loose cable connector
· Cable may be bad (Keyboard)
· K/B itself may be bad
· Check the physical condition of K/B connector on M/B
· If all these are ok & problem is still processed
· Than replace the keyboard port
2) Floppy disk drive Fail
· loose data & power connector of FDD
· Data cable may be bad (FDD)
· Load the CMOS defaults
· Floppy disk drive itself may be bad
3) CMOS Checksum error
· CMOS battery has gone bad replace it. (Weak)
· Check the CMOS jumper it may set on clear
· If the entire ok than check the CMOS battery jack, it may be bad
4) Invalid System Disk, Insert System Disk & Press enter when ready/ NTLDR is Missing
· Check the root directory; it may be formatted or missing bootable files.
· Repair the Windows or Reinstall the operating system.
5) Disk Boot failure, Insert System Disk & Press enter when ready
· Hard Disk check in POST Detected or not
· If not Detected Check the power cable
· Check the Master/Slave jumper setting.
· Also check BIOS setting
6) Computer gives message: Your computer has a serious problem
Back up your data & replace your Hard Disk
This error message is displayed due to the SMART option. This scans the HDD for errors, if it detect the errors than it show the above message. Follow the error message & back up your data on to another drive.
I tried to explain most of the problems along with their solutions. There could be a lot more solutions for the problems. Make your own search and try to fix BIOS problems at your own home.
Forward this to all those who need help!!
SOVI
on Feb 09, 2011 | Computers & Internet
How do i clear the cmos on my asus p5nsli
support.asus
just to clarify, to clear your BIOS, there should be a 3 pin set on your board usually located some where just below your RAM. On the board will be printed something like "CLR" or "CLEAR" move the pin connector, with the power off, from its current position to the middle pin and the open pin. Wait about 15 to 20 seconds and move the connector back to the original position. You have just reset your bios to factory defaults.
Oct 18, 2009 | ASUS P5NSLI (0610839134670) Motherboard
When cpu switch on processor & power supply fan runs, no display
if you have swolen capacitors you are on the road the failure
buy a new mb and save yourself some time.
hope this helps
Dec 30, 2008 | EliteGroup P4IBMS Motherboard
I recently upraded my computer with an Asrock Penryn1600SLI-110dB motherboard with an Intel CORE 2 DUO E4600 processor. The symptoms are: When I tried to boot for the first time the cpu and case...
If you have recently upgraded your motherboard and when you turn it on, there is no display. You could check the jumper setting of your motherboard.
http://download.asrock.com/manual/PENRYN1600SLI-110DB.pdf
Check this site for jumper settings. Download the manual. Go first to page 11 and find clear CMOS jumper. That will be number 17. Then go to page 24 for the correct jumper settings. Jumper should be on the pins 1 and 2. That's the default settings.
If the jumper is set already to 1 and 2. Clear the CMOS by putting the jumper on 2 and 3. It should be off when you are going to set the jumper. This is to make sure that the settings for your motherboard is set to its original settings.
If you are going to clear the CMOS settings, you will have turn the computer on after clearing it and then turn it off again. Put the jumper back to pins 1 and 2. Now make sure that computer is totally off. Uplugged the computer just to make sure when you are doing this.
Note:
To test also the motherboard if it is working, do not connect the other pheriperals such as network card, sound card, and other cards that is not buit-in. Also drives such as Hard Drive and CDROM drives.
Check for beep codes. Short beeps tells you that the Video card is not inserted properly. Long beeps tells you that the memory card is not in place correctly.
Just remove the Video card or Memory card and then place it back again.
Computer should be off as well when doing this.
Sep 09, 2008 | Computers & Internet
EP-8d5a3+ Wont startup - LED code 02 - Cant find manual to download
Chances are your cmos is corrupted, you can try this..
1.) Find the Jcmos or Jp1 or JBAT jumper located on the board. Its a 3 pin jumper currently set to 1 and 2,,, set it to 2 and 4 wait a few then set it back to 1 and 2.
If you cant find the jumper or that fails then
  1. Locate the battery on the main board
  2. unplug the system then remove the battery
  3. press and hold the power button for 3 seconds
  4. release
  5. replace the battery
  6. pulg in the system and turn it on, it should boot
  7. load the optimised defaults by entering setup , follow the on screen instructions to do this
  8. thats it your done.
If that fails then the expoxys site will be up shortly.
i hope it works good luck
Jul 29, 2008 | EPoX EP-8K5A3+ Motherboard
Please help me
Hi
Check ASROCK P4i45GV R5.0 User Manual Page 17 - http://download.asrock.com/manual/P4i45GV%20R5.0.pdf
Note: Check Page 11 for the CLRCMOS0 location on the motherboard. From the picture CLRCMOS0 is number 18. You can locate CLRCMOS0 just below the CMOS Cell Battery.
Turn off the computer and unplug the power cord, then use a jumper cap to short the pins on CLRCMOS0 for 3 seconds. Please remember to remove the jumper cap after clearing the CMOS. If you need to clear the CMOS when you just finish updating the BIOS, you must boot up the system first, and then shut it down before you do the clear-CMOS action.
Regards
Mike
Mar 22, 2008 | Asrock P4I45GV R5 Motherboard
Intel 845 gvsr no display
Intel d845 gvsr no display ,but the ram is ok when i incerted the ram there is no beep and there is no sound. may be bios corupted and how to solve the problem
Mar 09, 2008 | Intel Motherboard
New motherboard will not boot
It appears that you are aware of Motherboard jumpers.
1. Reset BIOS settings by CMOS Clear jumper ( Location of jumber is given on the sticker / manual of motherboard )
2. Try updating BIOS of your motherboard from the following link :
http://downloadcenter.intel.com/Filter_Results.aspx?strOSs=All&strTypes=All&ProductID=2838&lang=eng&OSFullName=All%20Operating%20Systems
3. Plug only Optical Driver / Hard disk at a time and check.
4. Contact your vendor and get the motherboard replaced.
Feb 12, 2008 | Intel Motherboard
Master\Slave Jumpers
Should be a diagram on the drive telling you where to put the jumpers (Master, Slave, Cable Select). You might also check Maxtor's site - bet they have the diagram you need. winstephen
Jul 09, 2007 | Maxtor DiamondMax Plus 9 120 GB Hard Drive
ASUS P5NSLI (0610839134670) Motherboard Logo
87 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
