I have lost my Lexmark X2450 disc
I had problems with my hard drive and it had to be completly cleaned resulting in the loss of all stored info. I wish to re-install my printer but have no disc.
    Master:
    Sergeant:
  • 398 Answers
Go to lexmark web site and download what you need.
Posted on Aug 05, 2008
I don't have installation cd of lexmark x2450. how can i do it to install?
Any drivers you need can be found on the lexmark website. Note that some printers need the software installed before hooking up the printer. I'd try to install the printer first. The software will tell you if the printer needs to be connected.
Jun 13, 2011 | Lexmark Computers & Internet
Tip
How to use System Recovery console (steps)
Starting a Recovery
Turn on the computer and immediately begin pressing the F10 key repeatedly until a Recovery Screen appears.
You can also start a recovery from recovery discs, or from Windows. For more information refer to Performing a Full System Recovery in Windows XP .
Back to top
Recovery is taking too long
If your computer stops responding after using the recovery program, do the following:
NOTE:If the computer appears to have stopped responding after restarting from a recovery, please wait, it may take several hours or longer to complete the initial Windows XP setup process, especially if a recovery was run from a recovery disc set sent by HP. A Standard recovery may also take longer, depending on how many files are stored in user accounts (like in My Documents ).
1 Exit the stalled recovery process by pressing the POWER button on the PC until the power turns off, this takes approximately five seconds.
2 Before recovering, disconnect personal media drives, printers, scanners, cameras, camera-type memory cards, and other devices that did not originally come with the PC.
3 If you are using recovery discs, be aware of the following items:
4 If you created the recovery discs using Recovery CD Creator, be sure to run the recovery from the same drive that you used to create the discs.
5 Clean the discs with a soft, clean, lint-free cloth wetted with distilled water. Wipe from the center of the disc to the outside edge. You may also use disc cleaning kits or disc restoration kits from your local computer store. These kits produce better results than using cloth and water.
6 You may also use available CD/DVD Drive cleaning kits to clean the laser reading lens of the CD or DVD drive.
Try running a full system recovery again from the hard drive by turning the on the computer and pressing the F10 key until a Recovery Screen appears. This performs the recovery from the hard drive.
7 If the recovery stops when recovering from the hard drive, use the section Disc errors occur during the recovery process to eliminate errors on the drive. Try recovering again after the disk errors are removed.
___________________________________________________________________________________________________________________
2 If you are using recovery discs, be aware of the following items:
3 Clean the discs with a soft, clean, lint-free cloth wetted with distilled water. Wipe from the center of the disc to the outside edge. You may also use disc cleaning kits or disc restoration kits from your local computer store. These kits produce better results than using cloth and water.
4 You may also use available CD/DVD Drive cleaning kits to clean the laser reading lens of the CD or DVD drive.
5 Try running a full system recovery again from the hard drive by turning the on the computer and pressing the F10 key until a Recovery Screen appears. This performs the recovery from the hard drive.
on Oct 13, 2011 | HP Computers & Internet
I have a Lexmark X2450 all in one scanner printer. I want to convert scanned document using OCR, how do I do it?
Make sure the ABBYY Fine Reader is installed on your computer. This software is only available in the install disk that came with your printer. If you lost the cd, contact Lexmark technical support for assistance. For instructions on how to scan using the OCR software, refer to the Lexmark X2450 User's Guide. Thanks.
Feb 15, 2011 | Lexmark All-in-One Printer with PictBridge
How to do system recovery on compaq presario 5000 windows me
Starting a Recovery Turn on the computer and immediately begin pressing the F10 key repeatedly until a Recovery Screen appears. You can also start a recovery from recovery discs, or from Windows. For more information refer to Performing a Full System Recovery in Windows XP . Back to topRecovery is taking too long If your computer stops responding after using the recovery program, do the following:
NOTE: If the computer appears to have stopped responding after restarting from a recovery, please wait, it may take several hours or longer to complete the initial Windows XP setup process, especially if a recovery was run from a recovery disc set sent by HP. A Standard recovery may also take longer, depending on how many files are stored in user accounts (like in My Documents ).
  1. Exit the stalled recovery process by pressing the POWER button on the PC until the power turns off, this takes approximately five seconds.
  2. Before recovering, disconnect personal media drives, printers, scanners, cameras, camera-type memory cards, and other devices that did not originally come with the PC.
  3. If you are using recovery discs, be aware of the following items:
    • If you created the recovery discs using Recovery CD Creator, be sure to run the recovery from the same drive that you used to create the discs.
    • Clean the discs with a soft, clean, lint-free cloth wetted with distilled water. Wipe from the center of the disc to the outside edge. You may also use disc cleaning kits or disc restoration kits from your local computer store. These kits produce better results than using cloth and water.
    • You may also use available CD/DVD Drive cleaning kits to clean the laser reading lens of the CD or DVD drive.
  4. Try running a full system recovery again from the hard drive by turning the on the computer and pressing the F10 key until a Recovery Screen appears. This performs the recovery from the hard drive.
  5. If the recovery stops when recovering from the hard drive, use the section Disc errors occur during the recovery process to eliminate errors on the drive. Try recovering again after the disk errors are removed.
Jan 13, 2011 | Compaq Presario 5000 PC Desktop
I forgot hdd password how to unlock
Toshiba highly recommends the customer to fully understand what HDD Password is and once registered please keep your "PASSWORD" in a safe place.Your HDD password is different from your BIOS Password. Your BIOS Password is stored in the computer, but your HDD Password is stored in the HDD unit itself. So even the HDD unit is removed from one computer and attached to another, the HDD password is required to access it.If you forget your HDD User Password, TOSHIBA will NOT be able to assist you, and your HDD will be rendered COMPLETELY and PERMANENTLY INOPERABLE. TOSHIBA will NOT be held responsible for any loss of data, any loss of use or access to your HDD, or for any other losses to you or any other person or organization resulting from the loss of access to your HDD. http://aps2.toshiba-tro.de/kb0/TSB6B01MC000CR01.htm
Dec 07, 2010 | Toshiba 80GB MK8037GSX 2.5" SATA II SATA...
Corrupted and unreadable external hard drive
THE ONLY WAY TO RECOVER THE FILES IS TO OPEN THEM AND IF YOU COULD OPEN THEM YOU WOULDN'T BE ASKING THIS QUESTION THE ONLY GOOD TO COME OUT OF THIS IS THAT YOU CAN STRIP THE INFO AND HAVE A NICE CLEAN MY SELF HAVE HAD TO RELOAD WINDOWS A FEW TIMES IN FOUR YEARS AND ABANDON ALL MY INFO I LEARNED ANY THING PRECIOUS BACK UP CD ARE THE WAY TO GO HEY IM NO PROGRAMMER I HOPE SOMEONE HELPS MORE THAN I CAN GLENN
Nov 15, 2008 | Western Digital Caviar WD2500BB 250 GB...
Toshiba satellite pro l40 boot up problem
If you run a repair with the recovery disc you won't lose any info. The only time you'll lose the info is if you run a complete reload. Run the system disc until it gets to the point of finding installed operating systems, at this point instead of deleting the partition, press R and it will reinstall the operating system files only leaving other installed files and programs intact. Keep in mind that many times when this happens, it's a hard drive failure. If it is a hard drive failure, then you will have to replace the hard drive and you will lose the info, sorry.
Jul 02, 2008 | Toshiba Satellite A135-S2276 Notebook
Lost intallation disc
Hi Lsw,
Please click on below link it will take you to lexmarkx2350 printer driver page.
  • Select the OS in coloumn Drivers and Downloads
  • Click in Download now button
  • Small window will be opened wait for few seconds if download does not start, click on below link in same window
  • Press Save button , after download is completed run the downloaded file.
http://search.lexmark.com/printer/US/en/19M0000
Hope this post was useful, kindly let me know by providing your valuable rating.
Thanks,
Robosoft.
Jan 05, 2008 | Lexmark X2350 All-In-One InkJet Printer
jasbo
jasbo
