There are 4 LED on front top what do all 4 do?
beeps for many things.
LINE AC IN TOO HIgh
LINE AC IN TOO LOW,.
LINE AC DEAD EVEN FOR 1 SECONDS.
battery failing self tests beep codes\
the codes are in the manual.
if the ups fails to run your legit loads
with main wall AC cord pulled the battery is bad
9 out of 10 times, this is the cause. BAT.
most of these UPS have beeper silence features.
in the manual read that, rtm cs500
I have this same UPS here, wife CS500
and smt750, for me ( super good)
apc.com
load Powerchute.exe app. it will tell you what failed, PE personal edition there. cost ,free.
RTM
Chirps for 1 Minute Every 5
Hours - this alarm is sounded
whenever the battery has failed the
automatic diagnostic test
Four Beeps Every 30 Seconds - this
alarm is sounded whenever the Back-
UPS is running On Battery. Consider
saving work in progress.
Continuous Beeping - this alarm is
sounded whenever a low battery
condition is reached. Battery run-
time is very low. Promptly save any
work in progress and exit all open
applications. Shutdown the operating
system, computer and the Back-UPS.
manual
https://download.schneider-electric.com/files?p_enDocType=Instruction+sheet&p_File_Name=ASTE-6Z7UZA_R2_EN.pdf&p_Doc_Ref=SPD_ASTE-6Z7UZA_EN
if UPS dead some have circuit breaker (fuse)
make sure not tripped
that is all on CS line
there better UPS have alarm beep disable.
some are trick to set, using the power button (fast),on my SMT it's in the LCD menus
SMT750 a great UPS.
and batteries can fail easy even 1year old
3 to 5 is par, but only FATE wins in the battery domain, or 300 deep cycles (DOD) in calif, where powers ends all the time.
SOURCE: APC Back-UPS ES 500: green light flashes&continuous warning tone
On this unit, the likely culprit is the battery and that it needs to be replaced.
With that, you may want to think about the pros and cons of replacement versus buying an entirely new unit.
This unit is a relatively low end ups and the surge supression uses MOVs that wear out with repeated absorption of energetic spikes. That's why the better (and higher cost) UPSs and surge suppressors don't use them. They're not really that good anyway due to their relatively high transient impedance. The better equipment uses a "transorb" -- basically a back-to-back high voltage zener diode optimized for low breakover impedance and high instantaneous power capability. Unless the transient exceeds the design parameters of the circuit, these do not wear out and do not degrade. That being said, I will assume that you would likely replace this unit with a similar one.
The flashing may not be the battery at all and may be the charging circuitry, thus your new battery may not live very long (half the life that you would expect.
Many batteries out there are refurbs and have issues as all used parts do.
If you contact APC, they will likely give you a 35% discount on purchasing a new product.
The difference in price in the battery replacement vs. ups replacement at this level may only be a few dollars more.
I promise that I am not a UPS salesman, I just deal with many on a daily basis; therefore I am giving my two cents to try to thelp you avoid problems a year from now.
Testimonial: "Outstanding answer with right amount of detail. I swapped battery with identical APC UPS that I have and vfd that battery was cause of warning tone."
SOURCE: apc ups flashes red light to replace battery, but battery is new
i think by replacing the battery has not been the solution to the problem
u need to check the battery charging voltage when turned ON with main electricity, if no voltage present from charger, there is no question of battery getting charged and also once the battery is down with charge it may not re charge hence the indicator and alarm.
recomended to nearest service centre
SOURCE: APC Smart-UPS RT 1000VA
Hello Dear Specialists I have a problem with the APC Smart-UPS smart 1000VA: when I insert the
power plug in the wall outlet in one ups , indicate the AVR Boost ups regulating low AC voltage, when I measuring the AC city power voltage that is 207v .whey this ups is not working about the AC low voltage? ,but it should be work from (170v ~ 230v) AC input volte.please solve this problem, which element of AVR from the ups is failed or wrong and give me free circuit diagram low & high AVR and charger and inverter circuits. thanks allot
SOURCE: APC Smart UPS 3000VA - Dead UPS
ok how long you brought the ups and how long you had not start the the ups usaully ups is power dead change the battery and try to power up it should work be sure that all connection is connect properly before power up the ups.. if the ups doest work that will be the mainboard problem you hav to call for vedor to repair the unit.. yes these fuse for the ups but it unlikely to be blown so should worry of the fuse it self.. change of battery come with different spefc for the ups.. eg su3000rmi3u, sua3000rmi3u, su3000rmxl3u --- battery replacement is 8 pcs of 12v 7ah. sua3000rmi2u-- 6 pcs of 12v 7ah or 8 pcs 12v 5ah. su3000rminet-- 4 pcs 12v 17ah,
SOURCE: apc xs 1500 overloads even with nothing plugged
Plz check MOSFET which working in inverter section.
never assume the battery is good, prove it,
the only way to prove it , no spare
is to remove it
connect automotive lamp tail lamp 1157
it uses 2 amps of current (perfectly )
and connect it to battery
and see if it glows bright for 2 yours.
if not the battery is DOA, EOL.
Kaput.
a 50 cent test, one way is have a spare old
parking lamp bulb and socket(all) off car.
2amps for 2 hrs the battery can end at 9.6v even new.
see discharge chart 0.3C here.
https://cdn.shopify.com/s/files/1/0380/9...
