Question about Swiss Legend Karamica Beige Ceramic Watch for Women
I HAVE JUST PURCHASED THIS WATCH / I HAVE NOT YET REGISTERED IT.....i NEED TO FIND A LOCAL CERTIFIED JEWELER WHO CAN SIDE THE CERAMIC BRACELET AND SET THE TIME i LIVE IN CALIFORNIA NEAR PALM SPRINGS / PALM DESERT CAN YOU GIVE ME A LOCAL ADDRESS OR NUMBER THANK YOU
    President:
  • 2,501 Answers
I suggest you go to their web site http://www.swisslegend.com/ .
On the left is a menu, click on "customer service" for a toll free number to get the address you need.
Posted on Apr 02, 2011
Where would I get a pin that fixes the bracelet to the watch lugs of the following Ceramic Oniss Paris watch. Its rose gold in colour
This is a standard item irrespective of the watch it is for. Just go into any reputable jeweler and they will put it on your watch for about 5 bucks.
Dec 02, 2015 | Oniss Watches
Correct battery size and type for guess Waterpro stainless divers watch
Take the watch to your local Watch/clock Repair shop or a jeweler.
Aug 19, 2015 | Guess Waterpro Bracelet Watch
The bracelet broken from the watch face. Can this be fixed?
You can try taking it to a jeweler to see if they can do a repair on it. But it is most likely that you will have to get a new skeleton case and transfer all of the inner working from the broken watch to the new case. Here again, a job best done by a jeweler because they would have the speciality tools that are required.
Jun 09, 2014 | Fossil ES2790 Watch
Kenneth cole watch
many jeweler have drawers full of spare parts like that. watchmakers too. if you strike out at a jeweler, ask who they use to service their watches.
May 06, 2013 | Kenneth Cole New York Automatic Bracelet...
I just bought a new guess watch but its loose to me how to i tight it so as it fit on my waist
Hi, I would recommend either taking to a jeweler at your local mall who usually do it for free. If your like me and have a decent size watch collection, I would suggest to invest in a watch resizing kit.
May 27, 2011 | Guess Collection Gents Bracelet 42001G2 2...
How do I make the band smaller on my ceramic watch
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes
Apr 04, 2011 | Le Chateau All Ceramic Condezza LC...
Adjust bracelet on sea spider?
Thank you for contacting FIxYa.<br /> I suggest you take your watch to a reputable local jeweler for sizing. Expect to pay a nominal fee (around $5) for this service. Do not attempt to size your own watch! You may damage or scratch the watch and bracelet. The liability is yours.<br /> If you still decide to do, follow instructions given here:<br /> <a href="http://www.webwatches.co.uk/how_to.htm" target="_blank">http://www.webwatches.co.uk/how_to.htm</a><br /> Best wishes. Jewel
Aug 26, 2010 | Invicta Watches
Watch band won't open
It is impossible to say what is wrong without handling the watch. I suggest that you take it to your nearest watch shop and ask them to look it for you.
If they can't do anything for you then the watch may have to be returned to the maker.
To find a local dealer go to the Boluva web site "boluva .com".
Mar 14, 2010 | Wittnauer 12P07 Watch for Women
My watch dosen't fit
Have a look at bracelet clasp exetnder from RTL Watches
Jul 28, 2007 | Tag Heuer Link CJF2114
Swiss Legend Karamica Beige Ceramic Watch for Women Logo
206 people viewed this question
Top Swiss Legend Watches Experts
Jimmy Accardi
ray gallant
Are you a Swiss Legend Watch Expert? Answer questions, earn points and help others
