Question about Xerox Office Equipment & Supplies
Xerox hole punch - x30 one of the punches does not go all the way back and get hung up on the papers that were punched
    President:
  • 2,072 Answers
Its become dull or developed burrs on the shaft, should be replaced.
Posted on Aug 05, 2008
SOURCE:
My machine will not punch holes how do I fix it
If it's a hole punch make sure the tray ( where the paper "holes" go ) has been emptied. It's like a little dust bin.
Jun 05, 2018 | Punch Office Equipment & Supplies
Swingline 74030 manual hole punch handle is locked down
by locked down I am going to assume you mean it will not go back to the normal postion when it is not making a hole. this can be caused by too many of the scrap pieces of paper that are left from making the hole. clogging the punch area. remove all the excess pieces of paper that may be stuck in the whole punch, then try again, you may have to pry the handle and or push and pull it until it releases. do not use again until the handle moves smoothly, clean the areas around the punch.
Mar 07, 2014 | Swingline 74030 Manual Hole Punch SWI74030
Cannot get the arm all the way up
this can be caused by excess paper stuck in the punch area. clean out all the excess paper, making sure to pay attention to the punch area. gently try to move the handle, it may take several tries to get the handle to move freely, make sure you clean out all excess paper before you use again.
Sep 23, 2013 | Swingline Swi-74650 Three-hole Punch - 3...
My hole punch won't release the paper. I have to jiggle it before it finally releases.
You are stacking too many sheets of paper. Reduce the thickness of the stack. Think of all the time wasted while trying to the paper released. Sometimes the holes punched may be ripped.
Aug 22, 2013 | Sparco High Volume Electric Three-Hole...
Putting a hole in a sports patch
You need a leather hole punch. It's much like a paper hole punch, but with a different cutter. You can find them at craft stores.
May 04, 2009 | Bernina 1008
How to use a eyelet hole punch.
try a single paper hole punch or a leather punch might be easier to use but that will also depend on the size of hole you need
if i is just a case of not being able to sqeeze with your hands try a using a rubb
Feb 26, 2009 | Hobart Handler 140 Mig Welder
Docu color 252 fault code 012-324 ???? Bill
HERE is the manual for your unit.
HERE is the online support page.
THESE are all the available documents for your Copier
Your error code 012-324 is not listed in any documentation.
Is there something it is doing/not doing when this error comes up?
Their customer service will help you with the error code.
Please call 1-890-925-050 and have your 10 digit serial # available.
Thank you for Using FixYa!
Jan 20, 2009 | Xerox DocuColor 12 Color Copier
I'm running a xerox 4110 at the kinkos i work at with the error code 012-322. Tech won't be out for another day and i need to start this job... Any idea if this is a quick fix??? Thanks!!
Thst is a hole punch home position sensor not detecting the 2 or 3 hole punch.
Try reseating the hole punch assembly then power the machine off and on.
Aug 10, 2008 | Xerox Office Equipment & Supplies
Open Questions:
437 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
