Question about LG VOYAGER VX10000 Cellular Phone
When i go to get it now applications. my phone says connecting but b displays error code (3332). how do i fix this problem?
My nokia 5230 sowing memory delet some data,i use *#7370# formula but require code, bt showing code error and default code 12345 is not machting.pls help me Thank u
Ok you can generate the code by using this software.
1. Downoad [ANT] Simple Ant Simple.zip
2. If you have Nokia PC Suite running, be sure to close it by exiting from the taskbar icon.
3. Extract [ANT] Simple ] and run Simple.exe located in the folder
4. Connect the phone via USB to the computer by selecting Pc suit/Ovi suit when prompt a message in your pone.
5.After you've connected your phone, Click "Read Info"
6. On the MAIN tab, click on GET. Your phone IMEI number and model should be displayed on the bottom panel.
7. Now click on the SERVICE tab and click on GET button under USER CODE
8. Your security code should now be displayed on the right side of the application window.
For details How to Generate Your Phone Security code..Only for Nokia bb5
Thanks For visiting Fixya
Sep 15, 2011 | Nokia 5230 Cell Phone
I have problem does not support resort factory setting code.(12345,1234,0000)
If you could not restore due to the error code here is a tiny software you can generate the code by connecting usb cable to your Pc.
6. On the MAIN tab, click on GET. Your phone IMEI number and model should be displayed on the bottom panel as shown below
If you could not understand just follow this link How to Generate Your Phone Security code..Only for Nokia bb5
Sep 02, 2011 | Nokia 6300 Cellular Phone
I type *#7780# than restore factory setting>than press ok> i type 12345> than rusult= error code.....why?
You can generate your code from this procedure
In case if you don't understand follow this link How to Generate Your Phone Security code..Only for Nokia bb5
Aug 18, 2011 | Nokia 5310 Cellular Phone
My blackberry had error code 200 and now it only has small menu and everything gone blank,how do i reset the software on it.
hi murphy201 and welcome to fixya,
re-install the BlackBerry device Software and applications to the BlackBerry smartphone, try this steps: first, connect the blackberry phone to the computer and open Blackberry desktop manager double click Application loader, you may need to unplug and re-attach the USB cable to the phone for it to e recognized by application loader then click next, choose the port that the blackberry phone is connected and click next if prompted, type the blackberry smartphone password and click next. The device application selection screen appears. Select the applications to be loaded onto your Blackberry phone. If the device backup screen appears, choose whether or not to automatically back up the Blackberry Smartphone, click next. wizard screen appears displaying all the software will be loaded to your phone click the advanced button and make sure that erase all application data and erase all currently installed applications are both selected. Pls. take note that if the application loader was not able to access all of the Blackberry smartphone data, then both erase all application data and erase all currently installed applications will be grayed out. Click next, Click Finish. The device software will be loaded on your phone. Do not disconnect until the process has completed.
Thank you and have a nice day
Jan 06, 2011 | RIM BlackBerry Curve 8520 Smartphone
Application closed error
open massage inbox sow below error
application closed
APPLICATION MASSAGING
REASON CODE USER
REASON NUMBER 130
Jan 10, 2009 | Sony Ericsson P990i Cellular Phone
Motorola RAZR V3m mobile shop error
the settings need to be checked you can call the mobile provider to have them assist you with this.
Dec 26, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Device Error 373 Reset
Hello afterhours!!!
Is seems funny but according to blackberry customers , seems the error is fixed by dropping down the phone on a floor!!!
Not sure about the solution .. But y not give a try on a carpet floor!!
Regards
Smilemaker
Jun 17, 2008 | RIM BlackBerry 7290
System Error. Code : 87. Parameter is Incorrect.". Please give me solution for this
When I want to connect a software ,which connect to Database through ODBC display the messageV"System Error. Code : 87. Parameter is Incorrect.". Please advice solution
Mar 29, 2008 | Microsoft Windows 98 for PC
!SisRegistryServer error
We have 2 problems :
1-Application
!SisRegistryServer
Reason Code
ucmp
Reason number
0
2-Application
Application installer
Reason Code
KERN-EXEC
Reason number
Nov 13, 2007 | Sony Ericsson P990i Cellular Phone
LG VOYAGER VX10000 Cellular Phone Logo
314 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
