Question about Hunter Ceiling Fan Control Switch
What color wires are for the fan speed and what color wires are for your lights? please, text 7128300493
  • 126 Answers
The color wires for ur lights r black/white,and the for the fan is red /blue and or yellow, these should have plugs on them and only plug into one thing
Posted on Apr 02, 2011
How do I wire a light assembly,,,,my ex girlfriend toke it apart when she left...I have everything.need color codes.
See the link below and then enter the model number of your fan in the box. You should be able to retrieve the information you need from there:
http://www.hunterfan.com/Support/Technical-Support/Parts-Manuals
Jul 17, 2015 | Hunter Dryers
I got my craftmade ceiling fan about 10 years ago, the fan has now stopped working but the light works, I changed out the switch on the wall that was not the problem sometimes I will turn on the wall...
pretty sure its the 3 speed pull chain switch.$4.50 to $6.00 at home depot or lowes or hardware/elecrtical store.
how 2 replace switch.
1.turn off breaker to fan/fan lights,probably that whole room.
may need extension cord & floor lamp from closest room with electric, so u can see.
2.need 6ft step ladder to get up to fan.look see how to get to fan speed switch. speed switch unscrews from outside but body of switch is inside fan cover.
3. need to take fan off ceiling to replace switch.
4.switch has 4 wires, power feed into switch and 3 selector
wires that go to high speed winding,medium speed winding and low speed winding.
speed selector switch has 4 settings, off, low,medium,high.
about ac circuits , black wire is 120 volts, hot.
white wires are neutral return wire. an ac voltmeter will read 120volts ac with its red and black probes between black,hot and
white,neutral.
white= neutal=ground which is green. If wired properly and polarity was observed, white and green ground wires both connect to the neutral ground buss bar in the circuit breaker panel box and are the same electrical point.
black wires,and the selector handle getting the hot juice into the fan and white returns the used juice to the circuit breaker panel box.
If polarity was observed, you can touch white and ground without getting a shock.
black will jolt or even fry you dead, so make sure the breaker to the fan is off, so that the circuit is de-energized before you touch it.
PLEASE NOTE--- make drawing on paper of what color wires from the fan motor go to what color wires on the selector switch.
If the switch has 4 black wires, you need to put different color electrical tape as a marker, on each wire. or ,to be cheap, you can use white paper,scissors to cut paper,and pencil and write 1,2,3,4 on the paper and tape to the 4 switch wires.
that is: wire # 1 from the switch goes to the black wire from the wall--ac hot
wire #2 from switch goes to yellow fan motor winding,
wire # 3 from switch goes to orange wire from fan motor
wires are specific and NOT interchangeable.
go to www.ehow.com & type into search engine box
how to replace fan motor speed selector switch.
Oct 12, 2013 | Craftmade International CQ52 Ceiling Fan
I have a ceiling fan switch (Westinghouse 77075) that was broken, so I do not know where the wires (black, gray, yellow and purple) went. The speeds are black+gray+yellow, black+gray+purple, and...
I can offer resources:
1) Test switch that was removed, and test for hot connection to narrow down options.
What speed was fan stuck in when switch was removed? Let's say medium speed.
Which connection at fan is hot? Use voltage tester to find hot connection at fan, and match that up with wire-color on switch that was removed.
One and only one wire on 3-speed fan switch connects to hot. And the hot wire is the only wire that connects to each other wire as switch cycles through pull-chain sequence. All pull chain switches follow same sequence: off, low, medium, high.
Let's say old switch was stuck in medium, and you know which color wire connects to hot.
Test switch with continuity tester to see which wire(s) have continuity with hot wire: some switches, it will be 2 wires, and other switches it will be 1 wire. Match where wire(s) were connected, and map that to tests on new switch.
2) Open following link for illustrations and some other links.
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
Sep 16, 2011 | Speed Ceiling Fan 3-speed Switch By...
Replacing 3 speed 4 wire ceiling fan switch did not take note on what color wire goes L 1 2 3 wires colors are black grey brown and yellow need help to fix fan
Copy following link for 3-speed fan wiring:
Apr 27, 2011 | Solar Fan Impressions 3 Speed/4 Wire...
I forgot to write down the color connections. my options are L 1 2 3 my wire colors are, blacr, purple, yellow, blue. which goes where?
One line on the fan goes to the house common and should be white. this one is separate from the new switch. The other 3 lines on the fan are the 3 speeds. "L" is for the hot line coming into the fan and should be BLACK or RED. It should also be in the same box connector as the white above.
1,2 and 3 are the 3 fan speeds and tie to the 3 leads on the fan.
Try 1=purple 2= blue 3=yellow
You may need to move them after testing but darkest to lightest is usually the 1,2,3 order. Please let me know how much this has helped. Thank you!
Roger
Apr 02, 2011 | Westinghouse Electric Westinghouse...
I have a 3 way fan light switch but wires don't match the colors on my hamton bay fan what wires go where i have a black wire and a brown wire and a grey wire on the switch in the hamton bay i bought...
It takes 2 testers.
699b7e0.jpg regular tester
Continuity tester has battery and light bulb.
Use regular tester to find Hot wire that feeds old-switch.
Remove old-switch from fan
Strip back wires
Separate wires so they can be tested.
Turn on power.
Test each wire to bare copper wire -or- to green wire -or- to metal part of fan
One of the fan wires will light up tester.
This is the Hot wire.
Mark Hot wire.
Mark which color wire on old-switch went to the hot wire.
Use continuity tester on old-switch.
You know which wire is hot-on-old-switch
Pull chain and test hot-on-old-switch to both of the other wires.
When tester lights up, mark this wire.
Pull chain again and test hot-on-old-switch to both of the other wires.
At some point when you pull the chain, the tester will light up both the other wires.
This is the high speed.
Use continuity tester on new-switch.
Repeat the test for old-switch.
Identify which wire will be the Hot wire by process of elimination.
Mark this wire.
Identify high-speed wire.
Pull chain again, and tester lights up on medium speed.
Pull chain again, and tester lights up on low speed
Identify these wires and match pattern to the old-switch
If you need more help, add a comment, and I will answer
Oct 29, 2010 | Westinghouse Electric Ceiling Fan 3-way...
Wiring code for ceiling fan
These fans do not have a standard color code for the fan switch. What you can do is turn off the power, keep the white neutral connected. Then using the black power wire take one of the switch wires and connect to that black, turn the power on and observe the speed .. low mark it 1, medium mark it 2, high mark it 3. Repeat untill you have identified all the speed wires. Then connect these wires to the 1,2,3, terminations of your new switch
Questions?
Please Vote !
May 30, 2010 | Hampton Bay 04893 Ceiling Fan
Westinghouse Lighting 3speed Ceiling Fan Switch 7707500: I just replace the speed control switch in my Hunt...
Typically the old and new switches have no relative relationship to each other .. One way to figure this out is shut off the power and then using the black power wire attach each speed wire to it and turn power back on to observe the speed .. mark the wire with the speed 1, 2, 3, .repeat this untill all the wires are identified .. . then you can put the wires on the appropriate terminations on the new switch ..
questions ..
Please vote !
May 17, 2010 | Westinghouse Electric Westinghouse...
Speed control switch
I saved this text I found when I was researching this a while ago.
Let us know how you do.
Wiring a three speed fan switch
My daughter called me the other day and said Dad the ceiling fan in the kitchen is not working only the light works. I went over and removed the three screws that hold the light and pull chain for the fan down and found that the fan control switch had snapped open and all 4 wires had popped out. The snap clips on each side of the switch had broken off. I went down to Home Depot in the ceiling department and found the switch I was looking for. It said for a four wire ceiling fan. OK, know lets put it back together. First of all if you look at the new switch you should see four holds were the wires will be pushed into. The black wire in the fan is the hot or load wire, this wire is hot whenever the wall switch to the fan is turned on. Put this wire in the hole that is marked “L” this stands for load. Now with this switch in the off position the fan will not work until you pull the chain. The other three holes are marked #1, #2 and #3. On most fans #1 is usually high speed. # 2 medium and #3 low speed. What you now have to determine is what wires are high medium and low. The easiest way to do this is before you put any of the wires back into the new switch is to FIRST MAKE SURE NO POWER IS GOING TO THE FAN. Then simply take one of the colored wires at a time and twist it together with the black hot wire.
Turn the power back on to the fan and knot the fans speed. Do this with all three wires one at a time until you can determine which wire is high speed. Note the color of the wire and mark it down on paper.(Example; blue wire high speed.) Do this with the other two wires to determine there speed. Once you have the speed of each wire you can reassemble the new switch.
Black wire (Load) goes in hole marked L. High speed wire goes in hole marked # 1. Medium speed goes in hole marked #2 and low speed goes in hole # 3. MAKE SURE THE POWER TO THE FAN IS TURNED OFF WHILE YOU ASSEMBLE THE NEW SWITCH.
For those of you that have all these wired hooked up right and still the fan won't work I would then look for an open neutral wire. It should be a white wire. Check to see if all the wires are securly attached.
Good luck. One more word of advice. If you're not sure on what you are doing when it comes to electrical wiring then please do not attempt to do this or any other electrial work yourself. Call a licensed electrian. Any mistakes on your part could void your home owners insurance in case of a fire.
Aug 06, 2008 | Hampton Bay 24002 Ceiling Fan
Dryers Logo
156 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
