Question about Solar Chicago Timer Lamp And Appliance, 40148, New,free Ship
Looking for a manual for a chicago electric lamp and appliance timer model #40148
Can't figure out min are on the wheel
Copy following link for setting analog timers by experimenting with features:
http://waterheatertimer.org/How-to-set-timers.html
Add a comment March 2013 and describe what you discover
Mar 08, 2013 | Solar Chicago Timer Lamp And Appliance,...
Message on screen says lamp needs to be replaced then timer reset. Need lamp and instructions to reset timer
The lamp time reset will be or should be in the owner manual---Google the model number with keywords "lamp install" with the model number and the "manual" with the model number---Google can be a great help.
Nov 01, 2012 | JVC Lamp W/ Housing For Hd-52g786 /...
Hello, I have a es107 connect-it timer, do you have instructions for it, please. Many Thanks Glennis
I do not have manual specific to that timer.
ES 107 timer appears to be 240Volt analog 24-hour timer with 15 minute segments located around edge of dial.
http://p.mdcd.net/product_images/full/f21276b30757d43b9c32a6c12eb4695d7e02cfdb.jpg
Here is generic manual for Lamp timer that has identical 24-hour dial to ES107, but is rated for 120Volts and has red button on side:
http://waterheatertimer.org/pdf/Chicago-lamp-and-appliance-timer-40148.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html#Chicago
Here are generic how-to-set instructions:
Aug 09, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
I have a customer who is needing to get the the manual for a indoor lamp and applicance timer Sylvania model sa110. Is there anyway I can get that?
Open following link to identify timer and download manual
ttp://waterheatertimer.org/Sylvania-timers-and-manuals.html
Add a comment for more free help
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 12, 2011 | Stanley 38439 LampMaster Lamp and...
How do I work this timer? Model 59200. Does it work on any kind of lamp? Do I turn the lamp on? Tried it and didn't work, never turned the lamp off. Manual sheet not much help. Thanks for more info. Rita
Open following link to identify timer and see manual plus written programming steps:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59200
Lamp must be turned ON, and Bulb is good.
Raise and lower a few segments on the timer.
Plug timer into wall, and plug lamp into timer.
Manually rotate timer dial clockwise to watch lamp turn on-off.
Notice also that timer has switch located on top.
Move switch into one position and manually rotate dial again.
Move switch to other position and manually rotate dial again.
This will tell you how to set timer switch and segments.
To set current time, rotate dial until current time lines up with arrowhead located on inner dial.
Dial rotates as time passes, and segments click a switch back and forth that turns circuit on-off.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Feb 07, 2011 | Woods 59200 Lamp and Appliance Timer with...
Two out of three of my timers have jammed up. the timer does not turn at a certain point without forcing it. they are like 2 weeks old. can I fix this or should i just change brand
I test timers.
4-6% arrive defective >>> and most last less than a year. But some last a long time.
Plug-in timers are made cheaper today.
Inside the timer is small clock motor that rotates plastic gears that rotate time dial.
Plastic arm rides along the time dial.
When segments or pins are up-or-out, plastic arm moves back-n-forth and opens and closes electrical contacts.
If motor is not able to turn the dial, then motor is overheating and is in downward spiral.
They don't make replacement motors for inexpensive plug-in timers.
So you need a new timer.
Amazon has interesting page that shows wide selection:
http://picclick.com/Amazon/Home-Improvement/Electrical/Timers/
Amazon sells 2-pack of plug-in timers with 2 prong outlet
http://www.amazon.com/59419-Appliance-2-Prong-Outlet-24-Hour/dp/B002Y1KZHQ
3-prong outlet
http://www.amazon.com/59366-Appliance-3-Prong-Outlet-Repeats/dp/B001D8VIKE
Here are Woods timers:
Tork timers:
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html
Dec 18, 2010 | Woods 59200 Lamp and Appliance Timer with...
I need to use the Globe electric timer, tonight. Could someone tell me -- 1) which teeth/switch do you flip up and 2) does the time first cut off light and then switches it on or the other way round
Plug in timer and plug in light, and make sure lamp is turned ON.
Pull up a few segments, and then manually rotate timer dial around to see if segments-up = ON or OFF.
USUALLY ... when segments are UP timer is OFF, except with some GE timers.
You posted under Globe 2-pack which looks very similar to Woods 51419 2-pack.
Woods segment-type timers: segments up = timer OFF
Nov 30, 2010 | Globe Electric Globe Indoor/Outdoor Lights...
I need an instruction manual
Instruction manual requires brand and model of timer
For example Intermatic, GE, Tork, Paragon are brands of timers
If timer fits inside a wall box just like a switch, you might have to turn off electricity and remove cover and bring timer out until you can see markings on side of timer, or on back. Take a digital photo so you can see large image on your computer.
If timer is inside a metal or plastic box, turn off electricity and look on inside of door. If timer is outside, stand on dry boards to work on timer.
If timer is part of appliance you need the model and serial number from inside door or back or side of appliance.
Once you find brand and model or timer, you can post here or do internet search for the specific brand and model.
Sep 12, 2010 | Hardware & Accessories
Is the intermatic standard lamp and appliance timer..TN111C...powerful enough to start up reliably a 400 -430 watt metal halide or high pressure sodium light?? Thanks
intermatic makes a timer for window air conditioners its the same design and only a few bucks more is more robust . I just tested my 175 mh lamp and it draws 1.9 amps on start up the amps go down after it starts.. harbor freight has a cool timer also (cheap) But please try to buy the timer made in the good old USA ....Jay
Aug 20, 2010 | Intermatic TN111C Standard Lamp &...
Solar Chicago Timer Lamp And Appliance, 40148, New,free Ship Logo
1,854 people viewed this question
Top Solar Hardware & Accessories Experts
Gil Shultz
Bill Boyd
Gene Haynes
Are you a Solar Hardware and Accessory Expert? Answer questions, earn points and help others
