Question about Miele Ovens
Our Miele KM493 oven is not working and is displaying the error message e - 1 3 instead of the hob settings, please help!
4 Suggested Answers
SOURCE: Samsung PKG001 Stainless steel Single Oven and ceramic hob
Had exactly the same problem and just had the samsung engineer out (as it was only 3 months old ) who replaced the thermostat. all is now working ok
Posted on Sep 04, 2009
  • 177 Answers
SOURCE: miele pyrolytic oven: error 90
F90 is a faulty oxygen sensor. This fault clears after resetting your circuit breaker for 24hrs only. you will not be able to use any automatic programmes as the oxygen sensor measures the moisture in the air and then decides how long to cook for. You will need a Miele service technician or a registered service agent to replace the oxygen sensor. This should be covered under warranty but check with your local Miele dealer first.
Posted on Mar 19, 2010
SOURCE: AEG Oven model D98000VF - error code F8
I am pretty sure this is the temerature probe that has failed it can also be a failure of the main control board see how you get on but resubmit question if in bother.Hope I helped.
Posted on May 07, 2010
I was getting a small "0" error message on the display of my Miele dg 155 steam oven. Tried Descaling but the process didn't complete, stopped at 10 minutes (33 minutes total) and started...
GO TO SERVICE MODE. TURN OVEN OFF OPEN DOOR MOVE KNOWB COUNTER CLOCK WISE TO DEFROST PUSH TEMP BUTTON 3 TIMES PUSH + BUTTON TILL YOU REACH 67 CLOSE DOOR AND WAIT FIVE MINUTES VOILA......
Feb 26, 2011 | Miele DG155-1 Steam Oven Single
Miele H 5240 B CS oven Purchased E & S Trading, Ashburton, 1 October, 2010 When I press the arrows and the OKin between, about 70% of the time nothing happens. Sometimes wetting my fingers seems...
Hi the is a two year g/tee on all Miele appliances. I would contact Miele and book a service call. The appliance most likely requires new clock. Modified clocks are available which allow you to change setting via control knobs rather than keypad.
Jan 16, 2011 | Miele Novotronic H350-2B Electric Single...
Having taken the oven out to fix a problem with the hob (720EF double oven and grill), reinstalled the oven and powered –up, the clock won’t come on and stay on, the oven and hob appear to work! Any...
Both the top and bottom oven will only work if a time (any time) has been set on the clock. Setting the time operates a contact to switch the power through. The only exception is the grill. This will work even if the time has not been set. So if the oven controls/lights and heating work, to me it means that the clock/timer is half working and the only thing that isn't is the display.
I haven't had the clock/timer to bits but a fellow blogger has said that in some timers there is an electrolytic capacitor that controls the display. When this fails as they are renowned for doing, the dispaly mal functions. If there is one then Maplin have some - VHR41W/43W and DT64U depending on value etc. Let us know how you get on.
If you need a new clock/timer they are around £80 from espares.
Jan 03, 2011 | Stoves 720EF Electric Double Oven
Miele pyrolytic oven: error 90
Mar 14, 2010 | Miele DG 4080 Stainless Steel Electric...
Error code On Miele Steam oven - oO
o O means that the unit needs to be descaled. See your owners manual for the procedure. If the unit displays O - - o, the safety lock has been activated. Again, see your owner's manual.
Feb 01, 2010 | Miele DG155-1 Steam Oven Single
Kitchenaid KEMS308 display is saying "enter probe temp or remove probe" No probe is plugged in or has been used in a while. This message came up after cooking for about 3 1/2 hours at 300 degrees. Now...
Apparently this is to do with moisture having affected the oven adversely (I got this error message after baking 50 potatoes with all the steam that generated. Have a look at this page http://www.howtomendit.com/answers.php?id=162257 ....the solution is to set the probe for 160F then turn the oven on for 15 minutes or so at 450F. This apparently should dry out the probe position and all work again.....I am trying it now.....
Sep 07, 2009 | KitchenAid Architect® KEMS308SSS Stainless...
Samsung PKG001 Stainless steel Single Oven and Ceramic Hob : Hob working ok oven light comes on and fans work ok no display on oven and no heat any suggestions
Jul 15, 2009 | Ovens
Ignition switch on a gas hob/electric oven not sparking
Some have a AAA battery under the button - replace this, others use mains to create the spark, ensure you have the ignition wired up
Jun 01, 2009 | Ovens
Oven comes on of it's own accord following power failure
no you are not over reacting that could have burnt your house down I would demand a new one sometimes you just got to be pure hateful with these manufacturers and tell them you going to give bad ratings all over the net hope you get somewhere with them Please give high rating
Jan 05, 2009 | Ovens
Microwave
Hi my GE Advantium oven is displaying an error message and beeping. The Error is F3. Could you please help me with this.
Nov 02, 2008 | GE ZSC2001FSS Advantium Electric Single...
Ovens Logo
142 people viewed this question
Top Miele Ovens Experts
Paul Bade
Dan Webster
Dan Webster
John
Are you a Miele Oven Expert? Answer questions, earn points and help others
