Question about Honeywell Heating & Cooling
Honeywell Thermostat won't turn on
It was working just fine yesterday afternoon. But last night we noticed it felt warmer and when I went to turn it down, there was nothing on the display. We've checked the fuse box; nothing was tripped. We've popped the unit off the wall and put it back in - nothing. Ideas?
  • 1 more comment
  • melmoore Aug 05, 2008
    Not that I know of, but then I'm really bad with electronics and repair. The model is a T8411R102 if that helps.
  • Anonymous Sep 21, 2008
    Thermastat will not turn on. Was working fine and I went to turn temp down and it was off. No directions on how to trouble shoot.
    [email protected]
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Is there an internal battery? My Honeywell has one.
  • 1,420 Answers
There is a small automotive type of fuse in your air handler (not thermostat), check that. Also check to see if the Emergency Switch somehow got turned off (Usually found in stairwell or closet).
Posted on Aug 07, 2008
  • RobbiDobbi Aug 13, 2011
    5 amp fuse in air handler was blown. Replaced and working fine. Thank You.
    Problem Solver:
  • 9 Answers
Check the water sensor in your drain piping if you have one. If it's sensing water backing up, it will blank that display.
Posted on Oct 06, 2009
  • B Frank Stokes Jr Sep 07, 2011
    Thanks to furcifer, that solved my problem. With that water sensor sensing water in the pipe, it shuts everything down. Thanks again.
    Frank S
  • Anonymous Sep 09, 2011
    Glad it helped somebody!
    New Friend:
I have the same problem... after a thunder storm and the electric company shut off all the electricity in in my area but when the eectricity went back my thermostat is off.. no display.. i tried changing it still the same.. the electric company came and checked if theres a problem with the power supply.. they said theres nothing wrong.. not they told me to call the air conditioning guys to have my unit check... i dont know what to do.. should i call them?
Posted on Jun 09, 2010
    Problem Solver:
  • 3 Answers
It could need the 3 batteries replaced. I just did that and now it will come on but won't light up. Trying to solve that now.
Posted on Mar 22, 2010
SOURCE:
Our 85 nissian 200 sx will go into gear but will not go into reverse
Check your adjustment cable it's probably a few turns out because the cable has stretched over time
Dec 22, 2012 | Transmission & Drivetrain for Nissan 200SX
Honeywell thermostat won't turn the furnace on after power outage.
probably tripped a limit switch or a low voltage fuse would kill your display on the tstat, you should have battery power on your stat though.unless you have knowlege of electrical you better call a technician
Dec 09, 2012 | Honeywell Programmable Thermostat Heater
I changed a honeywell thermo last night. I'm
check your transformer some of them have a little reset button on the side if it arched it could of tripped it.if there is no reset make sure you have 24v coming into thermostat.
Apr 22, 2012 | Honeywell Heating & Cooling
I have Honeywell T8011R programmable Thermostat. Turn AC on last night for first time...working fine...came back late morning to find display and fan off. Check circuit breaker...on. I took it off and...
Hello, first you must verify if you are getting 24 volts to the tstat at the secondary side of the transformer, if not you have a bad transformer. If you are getting 24 volts then check the batteries in the thermostat.
Apr 12, 2011 | Honeywell Programmable Thermostat Heater
1995 Camry won't crank
battery in not holding charge ,,have battery tested at local auto part store.....
Aug 13, 2009 | 1995 Toyota Camry
Heating & Cooling Logo
10,034 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
