Question about Sony 8GB Black Bloggie High Definition Touch Camera MHSTS20B
Usb device not recognized on my 8 gig bloggie touch
  • Sony Master
  • 12,061 Answers
Hi this is a very common thing... Hopefully doing the procedure below should help.
Remove and reinstall all USB controllers To remove and reinstall all USB controllers, follow these steps: Click Start, click Run, type sysdm.cpl in the Open box, and then click OK. Click the Hardware tab. Click the Device Manager button. Expand Universal Serial Bus controllers. Right-click every device under the Universal Serial Bus controllers node, and then click Uninstall to remove them one at a time. Restart the computer, and then reinstall the USB controllers. Plug in the removable USB storage device, and then test to make sure that the issue is resolved.
Also to see if the device is OK or NOT. Take the device and USB cable to another PC, and plug it in and see if it is "Detected" if it is, (Load drivers too if asked do full install) and you can "See" it on that PC, all well and good, this at least means that the device is A OK. That would also mean that the "Fault" is with the "Other" PC.
Posted on Apr 02, 2011
Lost all my video. I did not delete, I turned it on and it was gone?
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
May 29, 2011 | Sony MHS-TS10/B Bloggie Touch HD Video 2GB...
Tip
Author/Burn Sony Bloggie Touch Videos to DVD with Windows DVD Maker
How to Burn Recorded Christmas Videos to DVD on Windows? <br /><br />Do you purchase Sony Bloggie Touch as Christmas gift? After shooting 1280x720 resolution videos for your Christmas or other touching moments, you may realize that a conversion program is need to burn a DVD of the video files. There are many free burning applications, and the basic one is Windows DVD Maker. However, it does not work properly with the Bloggie Touch .mp4 videos. Aunsoft Video Converter is the recommended converter for putting Bloggie Touch videos to DVD Maker. <br /><br />Here is the quick step-by-step guide for you to convert Bloggie Touch MP4 videos to WMV for Window DVD Maker to burn and author DVD. <br /><br />Step 1. Import Bloggie Touch videos to Aunsoft Video Converter. <br />Use Bloggie Software on Bloggie Touch camera to download the videos from camera to computer. Free download and run Aunsoft Video Converter as the best <b><a href="http://www.aunsoft.com/video-converter/">Bloggie Touch to DVD Maker converter</a></b> on Windows. Click the "Add" button to browse the .mp4 files. <br /><br />Step 2. Choose WMV output format. <br />Click the "Format" option and choose Common Video &gt; WMV3 (WMV9)(*.wmv) or the next profile WMV2 (WMV8)(*wmv) for conversion. It will keep the original resolution 1280x720 in the output video. <br /><br />Step 3. Convert Sony Bloggie Touch MP4 to WMV for DVD Maker. <br />Click the convert button below the preview window, and the <b><a href="http://www.aunsoft.com/video-converter/">Sony Bloggie Touch video converter</a></b> will start converting 720p MP4 to WMV for Windows DVD Maker. <br /><br />Step 4. Author/Burn Sony Bloggie Touch videos to DVD. <br />When the conversion is done, just insert a blank DVD disc to your DVD-RW burner, and click "Add items" on Windows DVD Maker to import the .wmv videos. Click the "Next" button to choose DVD menu style and start burning recorded videos to DVD disc. <br /> <br />It is so easy to put Bloggie Touch videos to Windows DVD Maker for burning DVD. If you do not have Windows DVD Maker, just use ImgBurn for Windows XP. <br /><br /><b>Tips:</b> <br />1. Aunsoft Video Converter also converts TiVo, MKV, MTS/M2TS, FLV, VOB to different formats like WMV, MP4, MPG on Windows. <br /><br />2. During the Christmas and New Year promotion, <b><a href="http://www.aunsoft.com/christmas/christmas_promotion.html#weekpick">Aunsoft Video Converter is available with 20% off</a></b> this week. Get it as New Year gift for handling videos on PC and play around Bloggie Touch videos.
on Jun 24, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Seagate 120 gig HD in Dynex enclosure not recognized by XP system
Ok, you didn't say if the drive had data or not? Anyway, if it is a drive with no data etc, you will first need to Initialize, & Format the drive before use. Is there any way you can connect it up to an "Internal" or "External" SATA port, & "See" if the drive is recognized, then at least you know the drive is OK.. Also try another USB port if available. If you know it is OK, then go to device manager and Uninstall the entire USB layer, reboot, it will re-install the USB again, with default settings, it NOW may be "Seen".
Feb 22, 2010 | Dynex USB 2.0 Hard Drive Enclosure Kit...
HOW TO GET MY WINDOWS VISTA TO RECOGNIZE MY IPOD TOUCH 8GB?
Do you have iTunes 8?  Are you sure that there's nothing wrong with your iTouch's USB cord? Have you checked your PC's USB ports by plugging in another USB device?
If you've tested all of that and you're still having issues, feel free to call me. I can walk you through some more trouble shooting.
Dan Crowley, iKnowApple.com 919.280.3101
Nov 07, 2008 | Apple iPod touch
Open Questions:
Sony 8GB Black Bloggie High Definition Touch Camera MHSTS20B Logo
115 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
