I want to change the time on my computer screen but i am not sure how to do it.
    Sergeant:
    Champion:
  • 218 Answers
Move the cursor over the time and right click than select adjust date and time
Posted on Apr 02, 2011
My projector does not display the image that is on my computer screen. It used to work fine, but not sure what happened.
Have you tried changing the screen resolution settings on your computer? This will probably be the problem if you are getting a no signal message. Also you can set the computer to display the same as your computer or to be a second screen so you should check this setting as well.
Jan 17, 2016 | Office Equipment & Supplies
How to set the date and time
Right-click or tap on the date and time in the Windows Notification Area in the bottom right corner of the screen. Make sure your Time zone is properly set if the computer is setting the wrong time. To manually adjust the time, turn off the Set time automatically option and then click the Change button.
Jul 04, 2014 | Advocate Wrist Blood Pressure Monitor...
How can i resolve this issue "website certificate error"
The first item to check would be your PC's Time and Date settings on your computer and make sure the month, date, and time are all correct. If not correct, double click on your time in the lower right of your computer screen. Once you change the Time settings, Apply the changes, go to the Internet Time tab and click Update Now. Make sure all your browsers are closed. Press your Window's key on your keyboard + R key to bring up the Run Command Window. Type GPUPDATE /FORCE in the run field and press okay (Make sure your Browswer, IE, Chrome, etc., is closed).
May 14, 2014 | Computers & Internet
Screen dimmed
The monitor is going bad. The capacitors that drive the screen are getting weak. It is too expensive to fix, you'll need a new monitor.
Dec 08, 2013 | Soyo Computers & Internet
Working on a Inspiron 530s, it was brought to me and said I can't fix it, help. The problem is: loads to Dell screen then to Windows Error Recovery black and white screen. It says windows failed to...
Not sure of the legality of this, but you could try to download a dell oem vista DVD, burn it, and be up and running in no time. I do this all the time. I assume its legal because I am still using the license that the computer came with.
Sep 12, 2011 | Dell Inspiron 530s Desktop Computer
The led is blinking and the screen is flashing and stays black, no picture or desktop appears and monitor menu doesn't work when power on comp after being off for few hours or longer, Tried with changing...
Make sure that your computer isn't going into Standby or Hibernate mode. You can test this by briefly pressing the power button and wait to see if the screen comes back on.
Oct 26, 2009 | Samsung 943NW Monitor
Blue screen on death then windows wont load
Hi Dear,
This is Azeem Inam. So you are having a blue screen when you try to start your windows. its not all the time but when your computer restarts it says no system disk present. Dear you'll have to do 2 things with your motherboard in order to solve above stated problem.
1. Change the Slot of your RAM. And;
2. Change the position of jumper # J32 written as CMOS, to the one free pin and the centeral pin. it is found near the battery. start the computer, it may not start now replace the jumper to its original position again. It will reset all settings. and you are done.
Thanks for your contact. We hope to have a better response from you in future.
Feb 14, 2009 | Intel Motherboard
Monitor won't stay on
Your computer may be in screen saver mode, it has instructed the monitor to go to power saving mode, or the the monitor's video cable is not properly connected to the computer. Another possible cause of this is a locked-up or in-operative computer since the computer is what supplies the monitor with all the display data or information. Move the mouse or press a key to de-activate the screen saver or power saving mode. Check the monitor's video cable and make sure it is snugly connected to the computer. To see if the computer is operating properly, press the CAPS LOCK key on the keyboard repeatedly while checking the CAPS LOCK light. If the light is not turning ON & OFF, the computer is non-functional. Contact your computer manufacturer for help.
Dec 02, 2008 | Computers & Internet
Size
Is there an auto adjust option on the monitor menu? If so, use it. Also, make sure your screen resolution is set to 1024x768 at least.
Sep 29, 2008 | HP vs15 15"LCD Flat Panel Monitor
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
