Question about ASUS Eee PC 1000H Laptop
My friend droped her notebook and now when she turns it on it just beeps and tells her to reboot and select proper boot device.what is boot device?
  • 62 Answers
A boot device is the drive that the machine tries to find Windows on. Usually it is the Hard disk. But there are time to boot from a floppy. It appears that either the hard drive is bad or the bios needs to be reset. Bios is the settings that tell the computer what the system is made of(hardware wise) it also is where you set the time, so when you power down the machine it still remembers the correct time.
Depending on what make of computer you have there are different way to get into the bios.
How to get into the bios: restart the computer and before the windows screen comes up, type F1 or sometime enter key. This veries by manufactor. Once you select the correct keys you should see a tab that saids startup and in there there is an option to boot from the cdrom first, Hard drive next etc...
Let me know if you need more help.
P.S. Please don' t forget to rate me.
Thanks
Posted on Apr 02, 2011
  • pretty1_33 May 13, 2011
    i did also bumped mine and it does the same thing..so i reset to default and now its saying " missing operating system''....whats that mean and how can i fix it? i need step by step teaching pls
  • 356 Answers
Boot device means anything you can boot from (eg hard drive, CD, flash stick, etc). If your getting that message its most likely because it isn't recognizing the hard drive. You can try to take the back off and make sure the hard drive didn't get knocked loose, but depending on how big of a drop it suffered, it might have broke the glass platters.
Black screen with white letters reading "REBOOT AND SELECT PROPER BOOT DEVICE"
Misty here is what I would do:
1.Start the computer in safe mode.
2. update drivers. I go into Slim Driver - a free prog. and scan the system to see if ok or need updates.
3. once updated, reboot the system normally - any change? GL
Feb 01, 2014 | Dell Inspiron M5030 Laptop
Help with reboot message for Asus G1 notebook.
Sounds like its trying to boot from the Optical drive (cd/dvd drive) thats empty or has no disc in it. You will need to get into the BIOS and change the boot sequence. Select HDDR 1st to boot from your C: drive where your OS is.
Dec 15, 2011 | ASUS G1 Notebook
What do I do when I get a reboot and select proper boot device and there is no devices connected?
Hmmm - select a proper boot device - but you probably already tried that.
Anyway, its possible your system has a little corrosion on one of the contacts connecting your
hard drive (a proper boot device) to the PCMCIA or PCI bus on your notebook PC. If so, you
may want to reseat the hard drive, which is to say remove it, and then plug it right back in - just to
try and make the proper connections between the hard drive and its bus.
Also, if you have a bootable CD, then insert it, and boot away.
I assume that this notebook PC was an Xmas gift and you're still getting familiarized, but if not,
happy Xmas anyway.
Dec 27, 2010 | Montgomery Ward Home Mirus Innovations...
My EEE PC1015 PE keeps giving error message "Reboot & Select proper boot device of Insert Boot Media in selected Boot device & Press a Key." Also, beeps continuously for approx. 1-2 min then stops...
in situations like this you just must download the correct manual and reinstall the OS,if you have no disk choose a different OS some are virtually cost-free
Aug 29, 2010 | ASUS Eee PC 1000H Laptop
The lid of my Lenovo Ideapad Y510 was slammed down, and it doesn't work anymore. Whenever I try and turn it on, it makes weird noises which include beeping, and tells me to "Reboot and Select proper...
I am sorry that the Computer is not booting. Please try accessing the BIOS by pressing the F2 key or Del key. In the BIOS windiow, press F9 to reset the BIOS to its default values. If you have the service manual of the Computer, please remove the back panel of the Notebook and reconnect the Hard Drive cable.
Jun 30, 2010 | Lenovo IdeaPad Y510 - Intel Core 2 Duo...
Reboot and select proper boot device or insert boot media
its basically telling you that your master hard drive with O/S installation cannot be found in the booting system...Check if your master HD is not corrupted and see if your O/S still exist or maybe wiped out..
Mar 31, 2010 | Computers & Internet
Hi, ull need to check the boot device priority in ur BIOS which is accessable usualy by pressing the delete key at the start of the boot process. If everthing is correct there and yet it doesnt boot from ur hard disk, try changing it to boot from cd and check if it boots. If it does then i think either your hard disk is corrupted or your OS.
Jul 08, 2009 | EliteGroup ECS 755-A2 Motherboard
When I turn on my MSI M510C notebook - ''reboot and select proper
Your notebook does not see the proper boot files on your C drive. Many times the boot.ini has been corrupted.
You will need a Windows XP Install CD mounted in the CD Rom. When you boot the system you need to choose the CD as the boot device (if the notebbok does not do it by default) then typr R to enter the recovery console. Once you get the C: prompt you will need to create a new boot.ini file using the bootcfg command. See the following website for details in using the Recovery Console:
http://commandwindows.com/recovery.htm
Jun 15, 2009 | MSI M510C Notebook
Computer beeping and saying reboot and select proper boot device
When you reboot, go to BIOS, restore factory BIOS settings. If that doesn't help, you'll need to reinstall your OS.
Jun 04, 2009 | ASUS Eee PC 1000H Laptop
When I turn on my MSI M510C notebook - I get this message "reboot and select proper boot device or insert boot media in selected boot device and press a key" and cannot do anything else. Can someone t
I've read this problem due to new hardware interferences with desktop computers, all they had to do is change a few pins around on the harddrives.. since this is a laptop, and is quite difficult and dodgy to access the hardware, the only other suggestion is to reinstall windows with a recovery disk, or windows CD-ROM.
Hope this helps :)
May 27, 2009 | MSI MEGABOOK M510C Notebook
ASUS Eee PC 1000H Laptop Logo
99 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
