SOURCE: Hitachi Tv
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
SOURCE: Screen is all Shades of Red....
You need to remove the front tv panel, search for the screws right behind the screen and speaker area on the sides of tv. Should be four of them, carefully remove the lower have/quarter and you will find a control box, 6 knobs. Try adjusting them to clear the problem, each color has its own knob, be sure to mark their original position befor adjusting. When you find the red adjustment knob, you should be able to turn it down enough so that it doesnt overpower the rest of the colors. Good luck.
SOURCE: funny colores and shades on my Toshiba projection TV
the convergence tube is the faulty part in this case a new convergence tubes replacing is required.
SOURCE: blue and yellow shades
That problem is due to failure of convergence section in TV, you need to check convergence out section in TV to fix that problem.
SOURCE: thin shade on top of screen on the toshiba
it's a faulty light engine. Toshiba usually does replaces those for free because they sold with a faulty part. Had mine replaced for free last year. Check your serial number on this page:
http://www.tacp.toshiba.com/tacpassets-images/notices/50hm66_56hm66.asp
...and if it checks out, give them a call!
