Question about Sub-Zero 245
Need a wiring/schematic diagram for a older Sub-Zero model 245. Serial no. is M994441. A technical discription of operation would also help if available.
catriver
  • 878 Answers
SOURCE: My subZero Model 245 Icemaker stopped making ice
Ice maker, I don't know where you can find the manual but I'll give you a few ideas of what to look for. First make sure that the inlet tube is not frozen over. Next, look at the center gear on the module and see if the clips in the center are not broken. If so you will have to replace the module. The ejector blades should be at the 2:00 position when home. If you get a jumper wire and jump T to H, this will by pass the bi-metal and run a cycle. The ice maker should fill at around the 12:00 position. Test points L & N will verify if you have 120v to the ice-maker. Test points L & H will test the resistance of the heater, 72 ohms. plus or minus 10%. Hope this gets you going, Catriver...post back.
Posted on Aug 21, 2006
22yooper
  • 828 Answers
SOURCE: sub zero 650 fidge holding at 53 degrees
That depends on if your model has a five or ten year warranty on the compressor. Your problem may not be warranty related. Check and see if the condenser is clean, check for a frozen cooling coil.
Posted on Jun 03, 2008
  • 56 Answers
SOURCE: Need two door shelves, Sub Zero, 251 RFD, the last two shelves
http://www.subzero.com/locator/locator.aspx?type=0&zip=Zip%20Code will get you to the nearest SZ?wolf parts distributor.
Posted on Apr 23, 2009
SOURCE: I'm looking for a wiring diagram for a sub-zero
but when I follow the kinkos link and place an order for the manual they will not print it because it is copyrighted!! Fedex says these links are for subzero employees only.
Posted on Jan 13, 2010
  • 842 Answers
SOURCE: I have sub zero 245
Have you checked the condenser to see if its clogged, or the condenser fan motor to see if its running. Is the compressor running? If not, you may need to by-pass the cold control to see if the problem is there. This older unit has a single compressor, so if the condenser fan is not running, the compressor can over heat and shut down. If the condenser is clogged same thing. If the light switch at the bottom of the door fails, the light will over power the cooling ability too. All of these things can cause the unit to fail. This unit is close to 30 years old. You made want to rethink a major repair at this point. With out seeing the unit, this would be the places I would be looking for answers.
If you need more help, let me know..
Posted on Aug 28, 2011
Testimonial: "I was so impressed by lightning response and professional help that I received for my broken Sub Zero frig. I can't thank you enough."
I need the schematics for the switch light to the head lights on my 1994 Ford Tempo GL 2.3 Can you please help me?
Go to www.bbbind.com free wiring diagrams . On the home page click on technical information . The next page you will see five rectangular box , click on Technical Service Bulletins & Wiring Diagrams
All TSB's and diagrams for every make and model - FREE
on the next page go to the of the page an click on I agree . The next page click wiring diagrams , not TSB'S ! Then add your vehicle information , year , make ,model ! Then under system click on lighting , subsystem headlamps .Then click on search ,then click on the blue link. This will show you the wiring diagram !
On the
Oct 05, 2015 | Ford Cars & Trucks
Need free wiring schematics
http://www.bbbind.com/technical.html
Free wiring diagrams there. It is not the easiest site to navigate-you have to keep going back to search page and enter vehicle information after viewing one set of diagrams- but they have a huge database and complete diagrams for every make and model going back to 1986. Every system on the vehicle, too. Click on TSB's and wiring diagrams, agree to end user license agreement, and you will get on the search page. Then click on wiring diagrams, and enter vehicle information- make, model, year, and engine size- in easy drop down boxes. There are 8 sub-systems under "lighting" for your truck. Good luck.
Jul 28, 2014 | 2004 Ford F250
Sub-zero 245 fridge with door not level on box, how do you adjust
SLide the unit out form under the counter and loosen the 3 allen head type bolts and move the door where it needs to be, then retighten the 3 screws. If the door has never been adjusted before, there will also be 2 Phillips head screws. take them out and throw them away. they are only there to hold the adjustment during shipping of the unit when it was new, and they won't line up anymore after you adjust the hinge. Good luck!
Oct 31, 2013 | Sub-Zero 245
My sub-zero 245 has a build up of frost behind the ice maker bucket, the vent has about one inch build up of frost . The ice cubes are almost clear?
HI.RON.i think this has to be in stages.1-defrost evvvvverything first 2-turn off water supply.if this cure the problem the the fault lies on inlet valve(leakig over)try.good luck
Jun 19, 2012 | Sub-Zero 245
I have sub zero 245 RFD model. It was working great and almost overnight it stopped getting cold. Is there anything I can do before calling for service? Thanks
Aug 28, 2011 | Sub-Zero 245
Need wiring schematic diagram
Most dryers come with a wiring diagram inside the operator console, or inside the dryer as part of a technical data sheet. If you cannot locate any technical information with your dryer, please post back with a MODEL NUMBER so that I may be able to provide you with a assistance. I hope this helps you.
Dec 23, 2010 | Dryers
Can I view a schematic or wiring diagram for the Automatic Windows Master Control Switch? I find the thing dificult to understand and I have a problem with the windows operating intermittently. (The...
Here are two typical GM power window wiring diagrams, one older and the other a newer model power window wiring diagram, but these two diagrams should help you understand the circuit. Let me know if you require any further assistance.
Aug 13, 2010 | Chevrolet Astro Cars & Trucks
Aug 19, 2006 | Sub-Zero 245
Refrigerators Logo
213 people viewed this question
Top Sub-Zero Refrigerators Experts
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
