Question about Interlink VP4810 Remote Control
I can't figure out how to program this remote so I can use it for my power point. I do not have the manual.
    President:
  • 1,114 Answers
Hi - You can download the manual from the link underlined in blue below:
VP4810
More info here.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Posted on Aug 05, 2008
What is the code for a sanyo tv and how do I program it
If your TV is older than the URC-4220, the code should be 0154. (The universal remote generally can only control devices that were released about 6 months or more before the remote was programmed.)
To program the remote, turn on the TV manually. Then press the TV button on the remote once. Press and hold Set until the LED blinks twice. Release the Set button at that point. Enter 0154, check if the LED blinks twice again. If the LED blinked properly, point the remote at the TV and press Power. If the TV turns off, this is the correct code. If you take too long between steps, the remote may leave the setting mode. If the LED didn't blink, start over from pressing the TV button on the remote.
The manual for the One-for-All URC-4220 remote is available here: http://voxrightnow.custhelp.com/app/answers/detail/a_id/11828/~/programming-and-operating-the-oneforall-urc4220-universal-remote-control . Scroll past the directions for using and programming the remote to the link to the Owner's Manual. The list of codes starts at page 36.
I hope this helps.
CIndy Wells
Feb 10, 2015 | One For All URC4220 Remote Control
Cant turn on my target device manually
If your STB has no power switch, plug it in.
Nov 20, 2017 | RCA RCRN03BR Remote Control
Samsung AK59-00123A remote to a M261VP vizio tv
Hello
[1] Switch your television on
[2] Point the remote control towards the
television
[3] Press and hold the TV POWER button, and
then enter the two-figure code in the table
to the right that corresponds to the brand of
your television by pressing the appropriate
number buttons.
If your television is compatible with the remote
control, it will switch off.
The remote is now programmed to operate
the TV.
The code for Zenith TV is [TV POWER + 63]
Sep 20, 2011 | Zenith ZEN700 Remote Control
I have an Interlink RemotePoint VP4810 presentation remote that works great on my Vista laptop. However, when I plug it into my Windows 7 laptop, nothing. The laptop doesn't even make the sound it usually...
If you have the pro version of Windows 7 then you can run the program in compatibility mode (selecting Vista).
After you install the program, find the exe file and right click. Go to properties and click on the Compantibility Tab. You'll see options to run the software in a mode other than Windows 7.
Jan 22, 2011 | Office Equipment & Supplies
I have a universal remote control called signalex and i cant figure out how it works on any of the electronics in the house, am starting to think its a fake *** company that made this **** *** remote...
Auto search...
1) Turn the device you want to program on.
2) Press the button you want to program it in as (i.e TV1, VCR1, etc.)
3) Press and hold the Set and Power Button on the remote for a few seconds, pointing the remote at the equipment.
4) Release the 2 buttons and the light on the remote will flash.
5) As soon as the device turns off press any key on the remote and the light will stop flashing,
6) Check the remote now operates correctly, if not repeat the above until it does.
Nov 05, 2010 | Televison & Video
NEED SONY CODES FOR PHILLIPS REMOTE
Universal Remote Control Simple Setup
* Point it at a TV set and press the Mute/Power button. (Mute button if TV is already on, or Power button if the TV hasnt already been turned on)
* Keep pointing it at the TV until the TV turns on or muted, most TVs respond in about 5 seconds, the most is up to 20 seconds. (Other universal television remote you find in stores take minutes to program and enter long confusing codes)
* Once the TV is muted or turns on, simply let go of button and you have total control. You can use the remote as if you had the original remote, and responds instantly. ENJOY YOUR FREEDOM of choices with our remote!
Most remote controls require minutes of programming a universal remote code into each television while you read the confusing instruction manual.
Jan 02, 2010 | Philips Magnavox Learning Universal Remote
I have a Mitsubishi VS-45605 projection TV and a Philips DVD player model DVP3962/37. Can anyone help me figure out how to program the remote to control the DVD player? I only have the original remote for...
I've got the same tv and...I've still got the manual!;-)
Programming the Remote to control other audio and video products:
  1. Move the slide switch at the top of the remote to select the a/v product you want to control (in this case, DVD).
  2. Press and hold the Power button so that it stays down when you enter the code.
  3. Enter the code for the equipment. Release the Power button
  4. Point the remote at the equipment and press the Power button. If the equipment respondes, you're done. If not, and you have more codes that apply to that equipment, go back the step 2 and try the next number.
If none of the numbers work, I'm afraid you might be out of luck.
Oct 20, 2009 | Mitsubishi VS-45605 50" Rear Projection...
Programming a remote
    Programming a Living Solutions Universal Remote
  1. Step 1 Turn on the component you wish to sync to your universal remote--your television, DVD player, VCR or stereo.
  2. Step 2 Point the remote at the device you are programming and press the corresponding device button on the remote. These buttons are labeled "TV," "VCR", "DVD," etc. Hold the device button for three to five seconds.
  3. Step 3 Push the power button on the remote. This should turn on the device that you are syncing.
  4. Step 4 Push the "Channel Up" or "Channel Down" button on your remote gradually until the device that you are programming shuts off.
  5. Step 5 Press "OK" or "Enter" on the remote once the synced device turns off.
  6. Step 6 Press the device button for the component you just programmed, and hit the power button while pointing the remote at the component. If programmed correctly, the device should turn on, and you should be able to control it with your Living Solutions Universal Remote.
Sep 01, 2009 | Televison & Video
INTERLINK Navigater 2.4
http://www.smklink.com/library/media/papers/pdf/RemotePointNavigatorUserGuide.pdf
This should sort you out, but if you can't get the link, you remove the receiver from the pc and reconnect it after a few seconds. Press and hold the "Next" button on the remote (the right arrow) until the red light on the remote turns back on. the LED on the receiver should turn from flashing green to solid green then back to flashing green.
Sep 07, 2008 | Interlink RemotePoint Navigator Remote...
Interlink VP4810 Remote Control Logo
1,122 people viewed this question
Top Interlink Televison & Video Experts
Greg Cann
Greg Cann
Are you an Interlink Televison and Video Expert? Answer questions, earn points and help others
