Question about Sharp Heating & Cooling
The Sharp CVP-10MX Portable Air Conditioner has stopped cooling. when i turn it on only the fan works but the air is not cold.
SOURCE: Whirlpool portable AC, compressor works, but no exhaust fan
This is a single speed permanent split capacitor motor for the condenser. One of the capacitor wires shows infinite resistance to hot and netral. The motor needs to be replaced.
Posted on Mar 31, 2009
  • 5 Answers
SOURCE: i have an amana portable electronic air conditioner wont turn on
try draining the water. Mine did the same thing. Started right back up. There is alot of water be careful.
Posted on Aug 03, 2009
  • 534 Answers
SOURCE: air conditioner doesn't blow cold air. Continues
If the a/c fails to continue to blow cold there could be a few problems you can look for. First once you activate the system check to see if the compressor kicks in. You will hear the compressor humming . Once the a/c quits cooling go and see if the compressor is still running. If its not running its probibly gone into thermal overload (compressor overheated). If that is the case then you need to check to see if the coils are icing up if they are icing up then the problem is with 1) air flow restriction filter dirty, coils dirty simple repairs there replace filter, clean evaporator coil with a coil cleaner that can be purchased at a home repair store cleaning the condensor coil the same. 2) system is low on freon in which case the system will need to be recharged. Also, If you have a digital thermostat replace the batteries that may also be of some help. Good Luck on repairs
Dave
Posted on Aug 31, 2009
louislevel_2
  • 374 Answers
SOURCE: Air conditioner isn't cooling the room
hi there,
insufficient cooling have several reason,most common factor is low freon charging due to service factor,defective thermostat control,dirty evaporator and condenser fin,try to check the current rating using ammeter clamp tester if the rated current read in tester below the rated current on tag(compressor)
you need to charge freon,if the fin and evaporator is dirty need to ve clean,if the thermostat is not functioning replace thermostat.
also consider the main defective if the aircon is running chck the compressor if it is running by touching the tip of screw driver to the top body of compressor you can feeel vibration,if compressor is not running yo don't have cooling effect only blowing of air.on repairing this this should be done by a certified aircon technician,have a nice day fix my rate,thank you very much.
Posted on May 14, 2010
dhj144
  • 80 Answers
SOURCE: My Air conditioner stopped putting out cool air.
The unit is overheating and tripping the internal overload of the compressor. Clean outdoor coils.....check outdoor fan to see if it turns or is siezed......possible bad Start/Run Capacitor which is a very common failure on condensing units......possible bad fan motor need replaced! Unit compressor can be cooled with a water hose to get it to reset the internal biometalic high limit switch that is located in the hermetically sealed compressor!
Posted on Aug 22, 2010
Danny DPA120B1WB portable Air conditioner 12,000 Btu will not produce cool air. The fan will start but no cool air. I tried to reset, restart, and clean filters.
This may sound foolish but it works turn the unplugged air conditioner upside down and leave it that way for about hour and a half , then turn it back over after the hour and a half let sit for half hour plug it in and it should blow cold air , by turning it upside down it allows the oil in compresser to flow
Jul 23, 2016 | Danby Heating & Cooling
Why did SPT Portable Air Conditioner stopped blowing cold air?
Unit needs to be taken apart and washed out , also check to see if motor turns freely by hand , clean base of unit fans / blowers and drain ports / channels . Check outdoor motor to see if bearings are tight or fan overheats and cuts off if so replace outdoor motor .
Oct 04, 2014 | Heating & Cooling
Not cooling
Turn the thermostat down or it may be bad.
Aug 20, 2014 | Sharps 10,500 Btu Cv-2p10sc Portable Air...
Air conditioner shudders, stops blowing cold, then resets every 5 mins
Cleaned the filter this AM and closed the door but now a red
light keeps flashing.
Jul 19, 2013 | Sharp Cv-p12lx 11500 Btu Portable Air...
The unit suddenly stopped blowing cold air. the air is coming out and it's just a little cool, but not as cold as before
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jun 12, 2011 | Haier CPN12XH9 Portable Air Conditioner
Blowing out hot air
check for the clogged evaporating coil
Jul 20, 2010 | Sharp CV-P10LC Portable Air Conditioner
Danby DPAC8399 Portable Air Conditioner no Cool air
You possibly might have a bad switch or have a dirty ac unit.Try 1st turning off the unit and cleaning the inside ...
May 27, 2010 | Danby DPAC8020 Air Conditioner
Hi I have a sharp portable AC unit model CVp 10lc works for 1hour
I have the same problem. I have only used my unit 3 times. It keeps "triping" and shuts off. Also, I smell a plastic burning smell and the plug gets very hot.
Apr 02, 2010 | Sharp CV-P09FX Air Conditioner
Heating & Cooling Logo
63 people viewed this question
Top Sharp Heating & Cooling Experts
Tim Whalen
Pete Norton
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
