Question about LG GCC-4522B (0048231293594) CD-RW/DVD-ROM Combo Drive
I connected my ide lg dvd rom using ide to sata adapter in my mother board as my mother board does not have any ide connection. so since ti gets detected during boot time but does not shows up or does not gets detected after boot. i have used IDE to SATA converter/adapter. so could you please help me?
  • LG Master
  • 27,725 Answers
Make sure that the cdrw/dvd is getting enough power test all leads that are attached to the cdrw/dvd including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Apr 02, 2011
Connect sata disk drive to bi directional ide to sata adapter
Just asking, you have got a power connexion to the drive as well, haven't you?
Dec 08, 2013 | Computers & Internet
How do you install an lg gh24ls70 dvd rewriter into a compaq presario computer runnining windows xp that is 8 years old
If it's a sata connection on the drive you may not have any sata sockets on the motherboard. You will need something like an IDE to Sata adapter like this one: Adapter.
Feb 18, 2012 | LG Computers & Internet
Change my gx620 motherboard with ide connector for dvd rom to a 745 motherboard which has sata connection for dvd rom so i purchased a sata dvd rom and sata cable plugged everything in but the dvd rom wont...
With sata there are two cables, just like ide. One is the power and the other is for data. The data cable goes from the device to the motherboard. The power comes from the power supply. If your power supply does not have a sata connection you can purchase an adapter that will turn an available 4pin Molex into a sata connection.
http://www.ebay.com/sch/i.html?_nkw=ide+to+sata+adapter&_sacat=3667&_odkw=ide+to+sata+adapter&_osacat=42017&_trksid=p3286.c0.m270.l1313
Sep 11, 2011 | DELL 8X Serial ATA Slimline DVD-ROM Drive...
I have a an INTEL Motherboard Model DH55HC. I am installing a basic Internal DVD writer (DVR-A18M) Interface ATA/ATAPi-7. I have the power cable from the POWER SUPPLY in the correct plug. I attach the...
That motherboard doesnt support ATA it supports upto 6 SATA devices which is actually better and faster. You will need to take your DVD/RW back and ask to swap for a SATA and also make sure you buy a SATA cable and good thing is these are actually cheaper and faster. Its actually a very nice motherboard dont be disappointed. Cheers from Scott and plz vote
Jan 24, 2011 | Intel DH55HC Motherboard
My dvd does not appear in my computer or device manager
Check the SATA/IDE connection and make sure it is securely connected to the mother board and the drive, and that the power connector is securely connected to the drive. If you cannot see the drive in the BIOS, then you have a bad drive or bad connection on the mother board.
Feb 11, 2010 | Compaq Presario 700 Series DVD-Rom Drive...
I have asrock prescott 800 ddr400 fsb800 motherboard. i bought a new dvdrw that is sata. is this dvdrw compatible with the mother board? where to connect?
Sorry but the motherboard Asrock 845GV (P4I45GV) doesn't have a SATA controller and there for does not have the ability to connect a SATA CD/DVD-ROM drive to the MB. However you can buy a serial ATA IDE to SATA converter which will allow you to connect you're SATA CD/DVD-ROM drive into an opened IDE port. Provided is a link to you're motherboard;
http://www.asrock.com/mb/overview.asp?Model=P4i45GV%20R5.0 Next, is a link for the SATA convertor;
http://www.startech.com/item/IDE2SAT25-40-Pin-Female-IDE-to-SATA-Adapter-Converter.aspx
Cheers'
Mike
Jan 30, 2010 | Asrock 845GV (P4I45GV) Motherboard
Installing a IDE to SATA converter adapter
I have successfully connected a older. 20 GB drive to a computer with a 2. sata connection on the mother board.
Buy trial and error I found that connecting a power cable to the converter and the hard drive was the only way to get the Bios To recognize the drive.
Done sucessfuly with a 40GB drive as well, Set drive to master.
Feb 21, 2009 | Generic Memory (RXD639) Serial ATA...
CD ROM DETECTION PROBLEM
LEAVE YOU hard drive on primary master port on your main board set as master or single drive ( IF YOU HAVE A STATA HARD DRIVE THEN DONT WORRY ABOUT THAT PART)
SET YOUR FIRST DRIVE AS MASTER
SET THE SECOND AS SECONDARY
use the jumber in the back of the drive to set them the propper setting is labeled on the drive it self
Connect them to the secondary port on your motherboard
so you should have
HARD DRIVE - MASTER OR SINGLE *jumper settiing* connected to the primary port on your main board
DRIVE 1 = MASTER *jumper settiing*
DRIVE 2 = SLAVE *jumpersetting*
connected to the secondary port on your mother board
IF YOU HAVE A SATA HARD DRIVE FORGET THE PARTS ABOUT HARD DRIVES ABOVE
i assumed you had a IDE hard drive
JUST USE THE SETTINGS FOR THE DRIVES and it should work :)
Dec 25, 2007 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
LG GCC-4522B (0048231293594) CD-RW/DVD-ROM Combo Drive Logo
133 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
