Trying to hook up Honeywell RTH6350 thermostat. When turned on cool out air blows out. We only have a green, red, yellow and white wire from the old unit. Are we missing some wires? we have a heat pump.
  • kruegerachas Apr 02, 2011
    Thank you Justin. Our t-stat is programable and battery operated. The red wire is connected to the R terminal with a jumper between R and RC. The system goes on but blows hot air when on cool. When wiring we just have the thermostat on off. Are we supposed to turn something off at the circuit breaker box also?
  • w_petersonjr
    w_petersonjr Jul 17, 2013
    I Cant get my compressor to come on i have white goin to w yellow goin to y green goin to g nothing goin to o red goin to r again red goin to r nothing goin to b nothing goin to common what do i do
    Guru:
  • 257 Answers
Your Thermostat should wire as Red to Rc/Rh (if Rc/Rh are not connected you need to put a jumper between them; White to W; Green to G; and Yellow to Y on your thermostat. These will be the only wire connections that you need to connect from the unit to the thermostat. However, if your thermostat is not battery operated and is programmable then you will have to run on wire form the transformer in the units C to the Bl on your thermostat.
Thank you for choosing FIxYa.com
Justin
Posted on Apr 02, 2011
  • 5 more comments
  • Justin Burnett
    Justin Burnett Apr 02, 2011
    No you do not have to but it is a good idea so that you do not burn up the heat anticipator. Is your outside unit a condensor or a heat pump? If it is a condensor then you only need the four wires. Make sure that your outside unit is powered while the thermostat is in the cooling operation. If not post back and I will tell you how to check it. W is heat, G is fan, R is tranformers 24 volts, and yellow is colling.
    Justin
    We have a Trane XE1000 Heat Pump
  • Justin Burnett
    I relook at the post and notice now that you have a heat pump yes you need a fifth wire. You will need to energize the revirsing valve. You will need to run a new five wire wire to your thermostat. Everything else still connects the same except except W will go to AUX and O from your unit will hook up to O. I also need to know if your heater is gas or electric so that we can program your thermostat accordingly.
    It is electric...how difficult is it to wire a new 5 wire? Do we need to call an electrician? We have no clue.
  • Justin Burnett
    Now it is not difficult at all and it is low voltage not risk of shock. You will need to turn off the power to the unit. Open the service door and locate the low voltage wires see what connections you have. Run the new thermostat wires from the unit to the thermostat. Install as before except your white go to W1 and heatpump (O) will go to W2 at on thermostat. Then you will have to program the thermostat for a heat pump refer to your owners manual for the set up of the functions on page 13, Note the heat pump reversing valve on a trane is energized during cooling.
  • Justin Burnett
    Now it is not difficult at all and it is low voltage not risk of shock. You will need to turn off the power to the unit. Open the service door and locate the low voltage wires see what connections you have. Run the new thermostat wires from the unit to the thermostat. Install as before except your white go to W1 and heatpump (O) will go to W2 at on thermostat. Then you will have to program the thermostat for a heat pump refer to your owners manual for the set up of the functions on page 13, Note the heat pump reversing valve on a trane is energized during cooling. If you need a copy of the manual i can give you a url to it.
  • Justin Burnett
    Justin Burnett Apr 03, 2011
    No, but if you think you not going to be able to do it. Call a Heat and Air service company and tell them you have a Honeywell thermo stat you need hoocked up to a air handler and heat pump. The service charge should not be over a $100. Shop around for the beat price. Electrician is of no use they do not install HVAC and most do not know how to wire the low voltage.
    Justin
    Sergeant:
    Novelist:
  • 185 Answers
You will need 5 wires from the air handler to the new Thermostat to work properly IF YOU don't have electric heat back up then 4 wires will work R Y O G C to C=common;W to AUX=electric heat ;G to G = fan; O to O/B =reversing valve;Y to Y = Air conditioning; R to R leave in metal clip in R/Rc =power; Use a jumper wire and connect E & AUX on the thermostat......
Heat Pump you will need R;Y:O;C R=power, Y=Air Conditioning; O= reversing valve; C=common If the Heat Pump has a W terminal that is used to turn on the electric heat when the Heat Pump goes into a defrost cycle..... Here is a manual for the RTH6350 http://customer.honeywell.com/techlit/pdf/PackedLit/69-2416ES.pdf
  • Justin Burnett
    You only need C if the thermostat is not battery operated. O if it is a heat pump his unit operated before on 4 wires it will operate now with four wires as long as the thermostat is battery operated.
  • kruegerachas Apr 03, 2011
    Thank you for all your time and help. Found a 5th wire - blue - had friend come over and he fixed it for us. Thank you again
How do I replace an old White Rodgers thermostat with new honeywell TH5220
The Orange wire for the reversing valve and used with a Heat Pump
If you have a heat pump, then yes. If you have a gas furnace then no. If you have a HP and the reversing valve is not connected, then you might just be using the emergency electric heat strips. :-o
Jul 21, 2014 | Honeywell Th5220d1003 Non-programmable...
Wiring with new Honeywell thermostat
You need to put battery in the new thermostat if you gonna leave the C terminal disconnected
Jun 21, 2017 | Heating & Cooling
I installed a Honeywell RTH230B model thermostat. The heat works fine, but the AC is blowing warm air. Wires from old system are as follows: Y=yellow; G=green; R=red; O=brown; C=blue; E=white (it looked...
the colors of old system are for heat pump.if you have a heat pump you need heat pump thurmostat and colrs will make more sense.if not,then you need to go into furnace to see what colors go where.yellow is cool, goes to compressor contactor,usually another wire going from furnace to outside unit.green is fan relay rh is heat call rc is cool call
Jan 01, 2011 | Honeywell Programmable Thermostat Heater
My honeywell heater thermostat is only blowing cold air, there is no heat blowing regardless of setting. how can i fix it? it won't even turn off.
the wiring for thermostats are color coded. R(red)power, Y(yellow)cooling, G(green)common, W(white)heating. O(orange), E(emergency)heat. Make sure that you have the right thermostat because there is an air condition thermostat and there is a heatpump thermostat and they wire up differently.
Nov 27, 2010 | Honeywell Programmable Thermostat Heater
How do you wire a honeywell round mechanical thermostat
What are you trying to wire up?
Typical Thermostat Wiring for 4 or 5 wire Heat/Cool Thermostat (not heat pumps)
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
With 2 transformers one for indoor unit
And one for outdoor unit
Rc = Red One Side of (outside) 24 volt (outside transformer)
G = Green Blower (outside transformer)
Y = Yellow Cool (outside transformer)
Rh = Blue One side of (inside) 24 volt (inside transformer)
W = White Heat (inside transformer)
COOLING ONLY Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
R or Rh One Side of 24 volt Transformer
W = White Heat
Feb 09, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
Thermostat Wiring Problems!!!
. your blue is probably common and if you hooked it to Y you shorted the transformer or blew the low voltage fuse. Green is fan, yellow is AC, Red is 24volt. Is it a heatpump or just ac? I think its probably a heat pump and your brown is your Reversing valve it needs to be hooked to O on the new stat. If its a heatpump your tstat must be a 2heat 1 cool stat w/ aux heat. Without knowing what terminals the wire were hooked to on the old stat you may have to look at whats hooked up at airhandler( furnace) and on A/C (heatpump) tobe able to determine what goes where on the new one.
Sep 20, 2009 | Heating & Cooling
Replacing the thermostat, took the old one off without marking the wires. Hooked it up by color and we get the furnace when we put it on cool. wires are green, red, yellow & blue (ground wire)on the...
the normal wiring for stats is white=w=heat,red=r=24volts,green=g=fan,blue=c=common,yellow=y=cooling.
see what ties into your furnace board and match the terminals.
Aug 12, 2008 | Honeywell Heating & Cooling
Replacing thermostat
What is the blue hooked up to now?
Jun 07, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
2,198 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
