Question about Car Audio & Video
I have a 2000 VW Passat GLS that I'm trying to install a Dual stereo system into but I can't figure out what the wire colors on the car are for each thing (power, ground, etc.). I've looked online through Google search for diagrams but have had no luck finding wire color break down. What do I do?
    Problem Solver:
  • 18 Answers
First of all I would highly reccommend you use a wiring harness such as the Metra 70-1784 or the Scosche VW01B for two reasons; 1) it will make things 10 times easier for you and 2) it will keep all your factory wiring intact.
If you want to tackle this without using a wire harness do not just go and cut off your factory plugs, leave them on in case you ever need to change out the radio to a different model/brand of if you ever decide to sell the car or trade it in you can put your factory radio back in and keep your nice new radio for the new car. Just tap into the wires behind the plugs and make sure to insulate your connections really well so you don't pop fuses or worse.
Here's the wire colors and what they do:
12 volt constant wire - Red/blue
Ground wire - Brown
Radio ignition wire - Red (thicker red wire)
Radio illumination wire - Gray/blue
Front left speaker - Red/green (+) and Brown/green (-)
Front right speaker - Red (+) and Brown/red (-)
Rear left speaker - Blue/white (+) and Brown/white (-)
Rear right speaker - Blue (+) and Brown/blue (-)
If you're using a amplified antenna adapter that has a blue wire attached to it, connect that blue wire to the thicker red radio ignition wire.
Hope that helps.
Posted on Apr 02, 2011
What can be the problem with my car?
Hi,when you did the headgasket did you clean the surfeses properly,did you have the head scimed could be worped,if water and oil are mixing its most of the time to do with the head,sorry.
Nov 07, 2015 | 1998-2005 VOLKWAGEN VW PASSAT LOWER CHROME...
My 2000 VW passat 1.8 wont start. when i push the clutch and turn the key it makes a clicking sound, what does that mean?
flat battery or bad batt terminal connection .........its the starter relay clicking .........check all earth wires re attached properly from removing head
Sep 03, 2014 | 1998-2005 VOLKWAGEN VW PASSAT LOWER CHROME...
Free download manuals vw
i have a 01 vw beetle gls/aph and the abs/srs lights come on@ 15 mph when doors lock, I had a scan run and it showed the l/r hub. installed new hub and sensor yep still there. I jacked up front end(both wheels) and started car ,bam! there it is. I've installed rotors/pads and sensors. don't know what else to try..........
Thanks
Oct 01, 2013 | 2006 Volkswagen Passat
Stereo
It can be wiring issue.The stereo wiring has to be inspected.
For more help on car radio problems, I suggest you to go through these troubleshooting links, these will help you: -----
Click the link below: ---
Cigarette lighter, Remote central locking, and Radio stopped working
http://whoisbyme.blogspot.in/2012/07/cigarette-lighter-remote-central.html
VW passat radio off safe mode? VW radio CODE?
http://schematicsdiagram.blogspot.in/2012/03/vw-passat-radio-off-safe-mode-vw-radio.html
How to wire new Radio on 1990 Toyota Celica?
http://schematicsdiagram.blogspot.com/2011/12/how-to-wire-new-radio-on-1990-toyota.html
Radio Stereo Wiring Diagram for 1991 Chevy 1500?
http://schematicsdiagram.blogspot.com/2011/12/radio-stereo-wiring-diagram-for-1991.html
How to remove radio on Acura Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-radio-on-acura-car-models.html
Where is Radio Fuse located on 2007 Dodge charger?
http://schematicsdiagram.blogspot.com/2011/12/where-is-radio-fuse-located-on-2007.html
How to reset Radio code after car battery is died?
http://howtobyme.blogspot.com/2011/12/how-to-reset-radio-code-after-car.html
Can car radio code block Passkey anti theft system ?
http://schematicsdiagram.blogspot.com/2011/12/can-car-radio-code-block-passkey-anti.html
After Market Stereo wiring for 1999 Chevrolet Silverado 1500?
http://schematicsdiagram.blogspot.com/2011/12/after-market-stereo-wiring-for-1999.html
Chevy car radio doesn't allow to switch to the XM Band to get the radio ID?
http://schematicsdiagram.blogspot.com/2012/01/chevy-car-radio-doesnt-allow-to-switch.html
No power to radio on 2005 Toyota Scion Xb?
http://repairhelpcenter.blogspot.com/2012/01/no-power-to-radio-on-2005-toyota-scion.html
Lexus rx330 Radio has power but no sound?
http://repairhelpcenter.blogspot.com/2012/01/lexus-rx330-radio-has-power-but-no.html
Radio goes ON and OFF while driving?
http://technoanswers.blogspot.com/2012/01/radio-goes-on-and-off-while-driving.html
Lincoln Town Car Radio stereo wiring?
http://technoanswers.blogspot.in/2012/02/lincoln-town-car-radio-stereo-wiring.html
Radio wiring diagram for 1997 Lincoln Town Car?
http://technoanswers.blogspot.in/2012/02/radio-wiring-diagram-for-1997-lincoln.html
How to remove cd player from dash on 2003 Lincoln Aviator
http://technoanswers.blogspot.in/2012/01/how-to-remove-cd-player-from-dash-on.html
These details will help you thanks.
Dec 07, 2012 | 2009 Chevrolet Cobalt
Heater in my 2001 vw passat 2.8 GLS blows cold air. How can I fix it?
Possible air lock in cooling system or thermostat is faulty.
Dec 21, 2010 | 2001 Volkswagen Passat
Need Stereo Wiring Diagram
Here is a link listing all the colors/wires for your 91 Passat. Good Luck!
Greg
http://www.the12volt.com/installbay/stereodetail/2195.html
May 22, 2009 | 1991 Volkswagen Passat
2003 passat 1.8T gls power dirver seat
Seeing you have a GLS edition... most of them have at least a power DRIVERS seat. I own a 2003 GLX v6 and it comes with both front seats powered and heated. i hope this helps!
Jan 28, 2009 | 2003 Volkswagen Passat
Car Audio & Video Logo
224 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
