I have bought two intex multimedia speakers 2.1........but one of these does not sound clearly
  • 27,725 Answers
Try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Posted on Apr 02, 2011
Circuit diagram 5.1 intex
MY INTEX 2.1 SPEAKERS BOTH SPEAKERS ARE WORKING OK, PROBLEM IS IN WOOFER, AND THE SYSTEM IS CONNECTED WITH pc
wHAT COULD BE THE POSSIBLE PROBLEM???
Aug 18, 2012 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Okay I have a 2008 MacBook and my boyfriend bought me the Bose Companion #2 Speakers and the speakers sound out of phase when I up the volume. It sounds horrible from a different room you can even hear it...
Hi.
I would get an external sound card running on either USB (minimum 2.2) or firewire. I have had problems with mac audio ports. M-audio make a good range and so do ION. You need a stereo 2 in 2 out minimum (no need to overspend unless you plaun on starting a home recording or video project).
I would check to make sure there is no kind of phase switch on the speakers in anyway first though.
Jan 14, 2011 | Bose Companion 2 Series II Multimedia...
Driver for INTEX PC it-102 WC silver
Hi! it's Amit..
m sending intex driver link to u..
pls Download and install it..
http://download.driverguide.com/driver/IT+-+102+WC+SB/Intex/d992939.html
Dec 09, 2008 | Logitech Quickcam Chat Webcam
3D MULTIMEDIA PCI SOUND CARD INSTALATION
Make sure you are installing the right drivers to your operating system. If this is an older sound card, goto the manufactures web page and download the updated drivers there.
Apr 03, 2008 | Creative Labs Sound Blaster Live! 5.1...
Speaker won't work
Sija
First things First:
1) check your connectors back on the PC, I presume you use windows XP and sound drivers installed **
2) plug the speakers cable on back or front of your PC in the green (usually) connector.
3) see if sound is NOT mute on mixer , multimedia in control panel.**
4) If you can Enter your BIOS, try to enable sound, for onboard sound, if apply**
good Luck
Jan 20, 2008 | Audio Players & Recorders
When installed INTEX 3D MULTIMEDIA PCI SOUND CARD it is giving sound but immediately it is disappearing
Dear Nath,
I met same problem with my client before. Hope this helps; Uninstall any music or sound application(s) that has remote control feature or disable it (uninstallation is preferred). Now, at Safe Mode(with built-in sound card disabled), in Control panel soundcard device properties uninstall all sound card drivers. Restart in normal mode and reinstall back the sound card drivers. By transferring the secondary sound on another PCI slots may help solve the problem, the reason is the IRQ number conflicts. One of the worst case we met to solve this kind of problem is by reformatting the system but do it only when there is a great need, extra time, file backed-up. Have a great day.
Best regards,
Rosener Guyano
Jan 12, 2008 | Computers & Internet
Messed up speaker
Good day Nessasman
TIme to get back to warranty,
it is a bad inside speaker, or may be the balance of the speakers is at the other side , try in control panel, and multimedia settings first.
Good Luck
Nov 27, 2007 | Audio Players & Recorders
Intex 3D multimedia pci soundcard
Hi, check your speaker leads and speakers, if both of these are ok replace the sound card. a good test for the speakers is to use them with the onboard sound to see if you still get the growl.
Regards mistyman
Nov 06, 2007 | Computers & Internet
NO SOUND FROM SPEAKERS
HI Surthi
First thing came basic, check your speakers with other PC, and see if work correctly, then use the software control volume to see if not set to "mute" connect the speakers to the right slot in the sound card, sometimes according to the colors, usually green. see if you have installed the drivers for your sound card.
good luck!
Carl
Nov 05, 2007 | HP (PP036AA) Computer Speakers
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
