I need to change my UPnP setting - Computers & Internet
    Sniper:
  • 69 Answers
Login to your Router typically by typing 192.168.0.1 in your browser, here you can change the settings. It is a good idear to get the manual for your Router to find the setting easy.
Posted on Apr 02, 2011
How do enable upnp on belkin router
Since you aren't specific about the model of Belkin router you are using, I can only give you some general advice. This is what is have from MY Belkin router manual. Yours may be different....
Enabling/Disabling UPnP
UPnP (Universal Plug-and-Play) is yet another advanced feature offered by your Belkin Router. It is a technology that offers seamless operation of voice messaging, video messaging, games, and other applications that are UPnP-compliant. Some applications require the Router's firewall to be configured in a specific way to operate properly. This usually requires opening TCP and UDP ports. An application that is UPnP-compliant has the ability to communicate with the Router, basically "telling" the Router which way it needs the firewall configured. The Router ships with the UPnP feature disabled. If you are using any applications that are UPnP-compliant, and wish to take advantage of the UPnP features, you can enable the UPnP feature. Simply select "Enable" in the "UPnP Enabling" section of the "System Settings" page. Click "Apply Changes" to save the change.
Jun 29, 2015 | Belkin Computers & Internet
Upnp disabled
UPnP (Universal Plug n' Play... a feature that opens up necessary ports for PSN and gaming automatically.)
PS3 always says 'UPnP Failed' , so just diable it and opened up the ports manually.
On router Motorola SBG901 you can just follow the step and open your ports for games and other detail with snapshot is given in link
http://portforward.com/english/routers/port_forwarding/Motorola/SBG901/XBOX360_Call_of_Duty_-_Black_Ops.htm
Click the Advanced Link. The menu on the left should change. In this new menu, click Forwarding Go ahead and enter the settings shown above into the Forwarding menu.
You should see another page of settings that need to be entered into one of the blank lines on your routers Forwarding page. Go ahead and enter those settings now.
When you're finished, click Apply near the bottom of the screen to save your changes.
Nov 27, 2013 | Motorola...
NAT IS STRICT
STEPS TO CHANGE NAT SETTINGS TO "OPEN":
1- Using your Browser, Log on to your router (by normally typing in the 192.168.1.1 address check your router's manual to see what the default gateway address)
2- If you already know how to log in to your router, then skip this step. If you have never logged on to your router then more than likely you still have the default initial log in credentials (username: admin - Password:1234 ..... Again check your router's manual to be sure). The minute you log in you need to change that password immediately, most network-savvy folks know that 90% of the people out there never reset their router's initial password and they can log on and make any changes to suit their needs, including locking you out of your own router.
3- Once you are logged in, you should be able to find two advance settings (One if for NAT - and the other is for Upnp)
4- Let's start with the NAT setting changes, and we will move on the Upnp at the end. I have personally tried the NAT setting changes and it didn't fix anything, I still had a "Strict" NAT setting on my xbox360, Only when I checked for the Upnp "allow authorized incoming traffic" options when the NAT settings on my XBOX finally came back as "Open" and not "Strict". But I will still explain what I did anyways with the NAT table cause I know it may work for some other routers.
5- So what I did with the NAT setting is this. I located the NAT advanced setting on my router, I click on the NAT (Edit List setting) or whichever link/button you have on your router advanced NAT settings to access the table needed to open certain ports (TCP and UDP - 88 & 3074) .
6- You will need to find out what the static/dynamic (preferably Static) IP address you xbox360 has. To do so, go to the Dashboard, go to the Console settings page, and click on the network settings to see the IP address (should be something like 192.168.1.x). You will need that IP address to enter into your NAT table on your router.
7- Once you got your XBOX's IP address enter it in the NAT Port Forwarding table (From - To - IP address: those are the 3 fields you should have on the table if you are using SUA NAT)
8 - In the first line enter 88 under both "From" and To" fields, then enter the IP address of the xbox in the field where you are to enter an IP address. (this is for UDP port)
9 - Repeat the same step for port TCP (which is 3074)
10- If these changes do not help open your NAT settings, then try the Upnp option. Click on your Upnp Advances settings and click on the "Allow Traffic" option, this is mostly secure because you are only accepting the incoming traffic that matches your outgoing traffic.
Mar 02, 2011 | Belkin Basic Wireless Router
How do i enable upnp
Using your Internet browser, you can access the Router's Web-Based Advanced User Interface. In your browser, type "192.168.2.1" (do not type in anything else such as "http://" or "www"). Then press the "Enter" key.
Click login, the router comes with no password set, so unless you have changed the password, just click login.
To take advantage of the UPnP features, you can enable the UPnP feature. Simply select "Enable" in the "UPnP Enabling" section of the "Utilities" page. Click "Apply Changes" to save the change.
Oct 18, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Linksys wrt54gs changing upnp settings
Hi, you can enable UPnP on a Linksys WRT54GS router by logging in and then clicking on the Administration tab. The first sub-tab is Management, and at the bottom of that page there are buttons to enable or disable UPnP. Click Enable and then click Save Settings at the bottom of the screen.
Jul 21, 2010 | Zyxel P660HW-D1 Router
How do I enable UPnP on this router WRT160N
on WRT160N router UPnP is enabled by default.
You don't need to enable it.
If you want to check the settings of the router then you will need to open the set up page of the router. Router set up page is a page where you can check/change all the settings of the router.
Is there any computer connected to the router. Check the Ip address of the working computer and open the router set up page.
Once you open the router seyt up page, click on Administration Tab. On that page at the bottom you will see UPnP. It must enabled.
Click Here for more information about router and
networking
Feb 04, 2010 | Linksys WRT160N Wireless Router
How do I enable UPnP on a router
Login to the router throught your chosen web browser, then on the administration tab at the top tick the box that enables UPnP
"UPnP. If you want to use UPnP, keep the default setting, Enabled. Otherwise, select Disabled.
Allow Users to Configure. Keep the default setting, Enabled, if you want to be able to make manual changes to
the Router while using the UPnP feature. Otherwise, select Disabled."
Jul 03, 2009 | Microsoft Xbox 360 Pro System Console
Hay me again
to enable your upnp you need to "log into your router" the all your settings will be there for you to change such as enable upnp tutorials for this can be found on youtube
Jan 27, 2009 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
