Question about Sony Bravia XBR-52HX909 52 in. LCD HDTV
I have a sony 3d tv model xbr-52hx909 how do you change the resolution from 1080i to 1080p
  • 11,361 Answers
The resolution is controlled by the video sources, you do not adjust it at the TV, if you feed it with video sources that is 1080i it will display 1080i.
I hope that will explain how it works.
Posted on Apr 02, 2011
How do I change the resolution on my Phillips 4k tv from 720 to a higher resolution tools
The TV will select the correct/appropriate resolution based on the source. To achieve the highest resolution you will have to connect a unit (video source) capable of providing 4K using HDMI 2.0 compliant cables. To achieve any HD resolution, the video source will have to be connected to a HDMI port. The ATSC terrestrial digital broadcast signal (over the air TV) is generally 720p, but many stations transmit in 1080i/1080p.
Jun 23, 2016 | Televison & Video
Dynex HDTV says not supported when PS3 is connected via HDMI
Have you tried changing the video output settings on the PS3? It may just be on a setting that the TV does not support. For instance, if the poutput setting is 1080P, and the TV only supports up to 1080i, you would get a "not supported" signal. Hook the ps3 to a tv that it works on...turn it on, go to settings- display settings-output settings- select HDMI as the connector type- if it asks for 3D tv size...select the size- now you need to set the resolution...select all resolutions that the TV supports, since it is a dynex...it is likely a 720p TV. So I would start by selecting only 720p, and then hook the system to the Dynex TV and see if it works now. If it works, you can go back in and attempt to select 1080i or 1080p to see if they work... but again, being a Dynex, it is probably only a 720p TV... The PS3 is likely trying to output a 1080i or 1080p signal...which that TV doesn't support.
Mar 21, 2014 | Video Game Consoles & Games
Trying to use ps3, even after using hdmi cable on input 6 or 7, it says check your device output and i see green lines on my screen?
hi
There maybe some problem with your TVs resolution. ps3 outputs full hd high resolution video(1080p) through its HDMI. May be your TV is not supporting that resolution. Connect ps3's component video out to your TV's component video input and then try. if it ask for any resolution selection. select 720p or 1080i, above that resolution your TV will not support. Your tv is hd ready one, not full hd. ps3 's HDMI out is full hd (1080p).
or try this
Connect your ps3 to any full hd tv and then goto video setup of ps3. change resolution to 1080i (down scaling ). then connect to your TV via HDMI. surly u will get the video.
ok
Jun 09, 2011 | Sony Grand WEGA KDF55E2000 55" Projection...
I want ot change my LG television Model 47LH40 to 1080p using my LG remote
1080p video resolution can only be achieved by a Blu-ray Disc. Satellite TV, broadcast TV, cable TV do not actually send out 1080p resolution. So unless you are using a Blu-ray movie, you will not be viewing 1080p. Your HDTV has a NATIVE screen resolution and the TV will SCALE all incoming video to its native resolution. Most people cannot tell the difference between 720p and 1080i. 1080p signal sources are slightly sharper. But if you have a HDTV that is 1080p capable and you give it a 1080p source (Blu-ray Disc) and use a HDMI cable to connect, you will get 1080p, you do not have to change the HDTV as it will automatically display 1080p.
Mar 25, 2011 | LG Televison & Video
I have hooked up my br to an onkyo home theater through hdmi. i now get an unusable signal on my flat screen. This also happens when I hook it up directly to the tv. What can I do to get this to work
hi,
The Blu-ray player outputs full HD VIDEO (1080p) through HDMI, if your tv is not a full HD one then you can't see the video. Do one thing connect the Blu-ray player to any full HD tv and go to it video setting. Down scale the video to 1080i. All HD ready tvs supports only resolution up to 1080i. only full HD tvs supports 1080p. Down scale the video to 1080i surely you will get video. Also check the version of HDMI cable you have used. It should be 1.2 or above.
ok
Feb 15, 2011 | Sony BDPS570 Bluray 3D Player
Will the Sony STR-DG820 receiver support 3D?
I have this amp and mine does not have the latest firmware (indicated by a green or blue dot near the serial number) and it does not pass through Audio or Video when a 3D Blu-Ray is played in my PS3 although my TV (Sony Bravia XBR-52HX909) does say "3D Video Signal Detected." No audio or video ever plays but the PS3 looks like it's playing.
Dec 31, 2010 | Sony STR-DG820 Receiver
I was watching a dvd on my week-old Sony Bravia XBR-52HX909 for the past three hours when the screen suddenly went blank. The standby indicator light in red started blinking. I attempted to turn on the...
This tv only a week olds,should never having this problems already.The tv should be return and get a new tv for the replacement,this tv have tv Tuner signal board or tv power supply board distrubution problems.Even when the store test it out it work,don't take that tv back.Insit they give a new tv for the replacement.
Dec 13, 2010 | Sony Bravia XBR-52HX909 52 in. LCD HDTV
I have a Sony Bravia kdl-32s2020 LCD with MPEG-2 DBV-T. Are there any possibility to upgrade them to DVB-C MPEG-4. This model is also HD-ready. Haw can convert them to FULL-HD (changing SD receiver with...
This tv have the capabillity for the Full HD max resolution 1080i or 1080p.The problems u have is not the tv capabilities.The tv incomming broadcasting signals are vary like DTV,SD,480i,720i low end HD.Max HD resolutions are 1080p or 1080i.
Dec 01, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
New ps3,new 40in. samsung 3d led, new monster hdmis yet when i play god of war3 which is capable of 1080i it automatically gives me 720 not even 720p. so i unchecked 720p in setup and it gave me 1080 not...
To change this setting, you must exit the application and change your Video Output Settings from the display settings option in the Settings menu. Make sure the tv is not set on 720p/i and that it is set to 1080i. There has been issues with games that are 1080 downscaling the resolution. this can be confirmed by reading this article. if you provide me with the model of the tv. I can help assist you in ensuring its on 1080p. If you need further assistance please let me know after you try the following above. Thanks, Midwest-tek
Aug 28, 2010 | Sony Playstation 3 (PS3) Console
I have a sony 32 inch xbr TV (myt first non analog). HOw do you change the resolution from 480i to 1080i. What is the difference between 1080i and 1080p Thanks for your help. Maria
The resolution can only be change on your resolution source (ie cable box, dvd, etc). On your cablebox go to menu/setting->audio/video->output resolutions->and here you can change the setting. The main difference between i and p is how the video is scanned. I is interlaced, meaning you get the odd lines of video, then the even lines, and the picture may flutter but its better for fast action. P is progressive giving all the lines of video at once, better for still images, but slower of some tvs.
Dec 06, 2008 | Televison & Video
Sony Bravia XBR-52HX909 52 in. LCD HDTV Logo
122 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
