Question about Brother DCP 165C Compact Color Inkjet Multifunction Printer
I have a brother DCP-115C. All my ink cartridges are full and detected, but when I try to print, anything black comes out either extremely washed out or not at all
  • Brother Master
  • 379 Answers
Recently, I had a similar problem which turned out to be faulty non-original ink tanks (cartridges) - they had a valve which was supposed to allow air to be drawn in as ink was drawn out. It turned out they had "gummed up" and weren't allowing air in, so once a small amount of ink had been drawn out a partial vacuum was created and stopped the flow of ink.
If fitting new, original ink tanks and running the cleaning routines a few times doesn't fix the problem, then this could be several things, some of which may mean your machine will have to be repaired by a Brother agent (probably cost you more than a new one), and/or it's time to bin it.
However, sometimes it's just because the print head, or the pipes that connect the ink tanks to the printhead, have become blocked with dried out ink.
If you search on YouTube, you will find a few videos that show how to clear such blockages - you may not find your exact model number, but many Brother machines use almost identical components to many others so the basic technique will be the same. Also search on Ebay for printer cleaning/head blockage kits - quite a few printers (not just Brother) suffer similar problems and a few businesses have sprung up on EBay that sell kits to help you sort this. They sometimes have links to a video they have produced showing how to use the kit which can give you ideas. Again, your exact model number or even make might not come up but these kits might be adaptable to your machine. Got to be worth a tenner or so before binning it ! Good luck.
Posted on Apr 02, 2011
Testimonial: "Thanks, that was very helpful"
I only want to print black color but was asked to replace color inks.
Unfortunatly, because its a color ink jet machine you will need to replace the ink to print anything. The way its designed is that it has one printer head for all four cartridges.
When you replace the color ink you will deffinetly be able to print.
Apr 02, 2010 | Brother DCP 115C All-In-One InkJet Printer
Magenta cartridge is empty, how can I print in
You can't.The printer need all cartridges not empty to initialized and printing.You need to replace the empty cartridges to print.
Oct 26, 2009 | Brother DCP 115C All-In-One InkJet Printer
Printer wont print black.already replaced with new ink but still wont print black
did you take the tape off the new cartridge and is the print head burned out for the black? if you installed the diagnostic's on it then run it and see what it says, otherwise expect the print head to be cooked, however it is possible to get a bad ink cartridge try tapping it on your finger and see if ink comes out if it does not then the ink cartridge is dried out or no good, about %15 of print cartridges are bad on just about any brand printer some more than others.
May 31, 2009 | Brother DCP 165C Compact Color Inkjet...
Hi, my Brother DCP-115C Brother printer keeps telling me my black ink is empty despite putting brand new cartridges in, can you offer any help. Thanks.
Black electrical tape is the answer and it’s because the tape is BLACK. Even if u put black tape on an empty cartage the printer will still try to print.
The tape goes on the side of the cartage that faces the back of the printer (where the sensor must be).
Dec 11, 2008 | Brother DCP 115C All-In-One InkJet Printer
Says, it want new ink (three colours)
My printer always said the same thing. Unfortunately it seems to only work in black when the colours are full.
Cheryl.
Jun 19, 2008 | Brother DCP 115C All-In-One InkJet Printer
Sir
clean and re calibrate it
Mar 14, 2008 | Brother DCP 115C All-In-One InkJet Printer
Brother DCP-115C
good chance....Print head is blocked very common, what sort of inks were used?
 Not economical to repair, buy new!
Oct 19, 2007 | Brother DCP 115C All-In-One InkJet Printer
Brother dcp 115c
Seems to be a problem of your cartassy. The foil is damaged. The ink is inside the printer! So be careful. Try to open dcp: http://www.hstt.net/refill-faq/inside.html#Brother_mfc215c Use pictures how to open cover. After that try this: http://www.fixya.com/support/t184082-brothers_mfc_210c_ink_tray_needed_pin
Sep 04, 2007 | Brother DCP 115C All-In-One InkJet Printer
Brother DCP 165C Compact Color Inkjet Multifunction Printer Logo
419 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
