Question about LG RETAILSUPER MULTI DVD REWRITER DVD-RAM Burner
THE UNIT DOESN T READ DVD - LG RETAILSUPER MULTI DVD REWRITER DVD-RAM Burner
  • LG Master
  • 27,725 Answers
Make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Apr 02, 2011
When I try to play a movie it doesn't read that
The disc loader mechanism and optical pickup unit should be checked. Seek a tech suppot.
May 23, 2012 | Sony Televison & Video
Lg dvd recorder/vhs combo doesn't read dvds
Buy a DVD cleaning kit follow the instructions, sometimes brings it back to life. If no change! the assembly will need to be replaced,"not cost effective" cheaper to replace.
Mar 15, 2012 | LG XBR446 DVD Recorder/VCR
Technika combi unit dvd player wont read discs anymore
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Regards.
Jan 12, 2012 | Televison & Video
My DVD player DRC313 doesn't read, doesn't give any answer when fed it with a regular dvd. Shall I try changing the lens? Is it wise to ask the repair man to look at it and the lens is not the...
It is probably better that you leave the laser and its related assemblies within the DVD player to a qualified experienced technician; he can give you a detailed description of the actual trouble, a quote on the likely costs of repair (where applicable, including replacing/fitting the laser if required), and a second opinion as to whether it is economical to fix in the first place, or replace with a new unit, since this is not a DVD recorder, it might be expensive, but it is up to you.
Unless you have some technical experience, it is unwise to open the unit up to clean the laser or make any internal adjustments without the correct measurement equipment (DVD laser assemblies are precision aligned and balanced; blind adjustment and/or incorrect handling would render them inoperative permanently) - no room for error.
In this case, you cannot simply 'change the lens', it would take more than that to restore full operation of your unit, but get a couple of repair quotes first before making any further decisions.
Jun 08, 2011 | RCA DRC313N DVD Player
Acer aspire 5315 fails to recognise disc when inserted.
The dvd unit has a lens that is used to read the disks - if this lens is dirty or defective the disks aren't recognized. Clean the lens using a cleaning disk that you can buy at every IT shop. If this doesn't help then you must replace the entire dvd unit - you will have to take your Acer to a repair shop.
Apr 16, 2011 | Acer Aspire 5315 Notebook
My dvd player dvp615 doesn´t play dvd discs. only music cd´s
The unit has two lasers one for the cd and one for the dvd, the one for the dvd is bad and the whole laser assembly needs replaced. Cheaper to buy a new player.... sorry
Mar 16, 2009 | Zenith DVP615 Portable DVD Player
LG RETAILSUPER MULTI DVD REWRITER DVD-RAM Burner Logo
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
