Question about GE Refrigerators
Ge refrigeretor bottom freezer not working - GE Refrigerators
  • GE Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 03, 2011
Control Panel show: Refrigeretor temp panel = all ligths OFF Freezer temp panel = all ligths from 1-5 =OFF 6-7 = ON ??? Thanks
You have a problem with the freezer fan motor inside the freezer. It is not circulating cold air up to the refrigerator section. You will need to determine if the fan motor has failed or has frozen due to ice buildup. You will need to remove everything out of the freezer including the drawer assembly and remove the back wall panel to gain access to the freezer fan motor.
Jun 28, 2011 | LG LFC23760ST Side by Side Bottom Freezer...
I HAVEA GE SIDE BY SIDE, THE FRIDGE AND THE FREEZER ARE ONLY COLD IN THE BOTTOM HALF, FROST BUILD UP IN THE FREEZER, BOTTOM HALF,
HI you have a bad defrost heater, located in the freezer behind the rear panel at the bottom, the part cost around $50-70.00.
Sean
Mar 28, 2011 | GE Refrigerators
The freezer and the refrigeretor side are not cold the fan in the freezer is turning
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 15, 2010 | GE Profile 25.5 Cu. Ft. Side-by-Side...
Gss22jeta refrigeretor quit working
For a refrigerator to operate properly, it must: 1) have power to it; 2) the compressor (underneath the unit) must run; 3) the compressor fan (close to the compressor) must turn; and 4) the evaporator fan (inside the freezer unit, usually behind an access panel) must turn.
These would be the first things to check.
Oct 18, 2009 | Whirlpool GS6NBEXR Side by Side...
Fridge not cold, freezer on bottom works fine
you have defrost problem 1 timer defrostthermostart or heater
Jan 19, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
PDS22SBRLSS Ge Profile bottom freezer
hi is the fan motor running in the freezer. is there frost built up on the freezer wall did you pull fridge from the wall and clean the coils by the compressor
Sep 29, 2008 | GE PDS22SBRLSS Bottom Freezer Refrigerator
Hi, I have a GE refrigeretor model #ge pds22mbsww the freezer works perfect but the refrigeretor stop working for a day and start to work for about 10-14 hours and then stop agin what to do.
Sounds like a defrost problem or a plugged drain... to get it to work temporary ..defrost the freezer. Unplug the refrigerator, open the door and get a blow dryer and warm up the freezer. wait until the water stop dripping out or about 12 to 24 hours and then you can plug it back in . it will work for 2 to 3 weeks. To unplug the drain.defrost the freezer .remove the back cover. Use a pipe cleaner to clear the drain. pour a few cups of hot water down the drain. The defrost systems is:
HEATER-DEFROST
THERMOSTAT-DEFROST
( in the GE refrigerator the heater anf the thermostat are sold together)
TIMER-DEFROST
Start with the timer. It is just under the front kick plate. there is a knob you can turn it slowly.until it clicks off the compressor. then open the freezer and listen . You should hear the heater come on .. it will sizzle when it comes on ...
You will have to remove the back panel of the freezer to check the heater for and thermostat for continuity. Heater are the lease likely part to go bad... I always change thermostat and timers together.
let me know if this helps or we can chat if you need more help.
Sep 03, 2008 | GE Refrigerators
Ge fridge
you have 2 fans one underneath by compressor ,one in freezer make sure one in freezer is running
Dec 14, 2007 | GE GDS20SBS Stainless Steel Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
