Question about Sharp UX-P115 Plain Paper Thermal transfer Fax
Receipt for sent faxes
How do I program the machine to get a receipt for a sent fax?
  • Anonymous Mar 19, 2014
    lexmark fax
I called Sharp on a toll free number and got all the info I needed.Thank you!
Posted on Aug 06, 2008
My faxes are going through but I get error tx reports. Why is this?
because the fax is not going through as transmitted
the fax report will have OK if it was sent and received correctly
call the recipient of the fax direct and ask what the fax looks like or if they got it alright
Oct 24, 2016 | Office Equipment & Supplies
How do I set automatic fax receipt?
If you got a satisfactory solution to the fax receipt issue, I would surely appreciate your sharing it with me. I don't think that any HP all-in-ones will give you a receipt from the recipient. I need this too.
Maybe I will reinstall Win Fax
Jun 02, 2010 | HP LaserJet 3390 All-in-One Multifunction...
RECEIPT FOR SENT FAX
Pree menu/set then numbers 2, 4, 1. Chose on with the up and down arrows then press menu/set.
May 28, 2010 | Brother MFC 420CN All-In-One InkJet...
How do i print a report confirming the receipt of a sent fax
In the main menu under "fax" options you will find the option to print a fax report.
Nov 03, 2009 | Sharp UX B700 Plain Paper Inkjet Fax
Q. 1 - When I try to send a fax I get an error message that says: Fax Send Report is set to Off Q. 2 - I have an 1/2 inch black line down one side of any copy I try to make.
1. Usually a "fax send report" just means that you will not receive a "receipt" or "confirmation" that the fax was successfully sent. Changing the setting to off is pretty much just saving you ink & paper. When my fax machine report is set to off, I only receive a receipt if the fax was unsuccessful. However, all fax machines are different and have a mind of their own...so your best bet it to refer to the owner's manual or call the company where it came from.
2. The only thing I can think of is maybe you need to replace the plexi-glass on the copier or do an internal wipe of the underside of the glass. Sometimes the ink can smear from underneath when faxed papers get jammed or printed.
Sep 04, 2009 | HP Office Equipment & Supplies
Need printed confirmation fax receipts
I had the same problem with my 6210. A different machine, but this may be worth a try. You need to go to the general setup, rather than the fax menu on the keypad. Two pushes of the button takes you to "print reports". Press OK and you go to "Fax Report Setup", OK again gives you "Print Report". You then can toggle with the arrows for the various options. In this case press OK when you are on "sent faxes"
Apr 20, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Information about e-mail
You cannot know for sure.
If you don't get an automated "failure delivery" message from sending server like "destination unreachable", you can assume that the mail was sent.
The other aspect is -DO the recipient RECEIVED the mail?,
SENDING mail does not assures you that it was RECEIVED.
Well, There is a way to add a confirmation request to your mail but most people click "NO" to the request.
To configure the receipt request in outlook express do the following:
Open outlook express --> press on "tool" tag --> a new menu is displayed, --> press on "options" tag, a new menu is displayed, --> press on "receipts" tag and tag "V" at the first chioce "requesting read receipts".
To configure the receipt request in outlook (not express) do the following:
Open the outlook program and press on "tool" tag --> a new menu is displayed, press on the "options" tag, a new menu is displayed, press "preferences" tag -->press on "email options" tag --> press on "surveillance options button", a new menu is displayed, then tag(V) on the 6th tag "send receipt"
May 06, 2008 | Pitney Bowes 9920 Plain Paper Fax
Not sure if faxes have been sent successfully how can i tell?
I am not technically qualified for faxes but most fax machines i have used have a setting that allows you to have a receipt that prints off after you have sent one, this is something that can be turned off if not wanted, look in the manual and it will tell you how to reset it, i think it was called "polling" after a fax has been sent it prints off this little bit that says what time it was sent how many copies and time received, fax number it was sent to and sometimes company name etc some machines i have seen and used have a poll button after you have sent your fax, try just pressing it, it may print out a conformation receipt of the last ten faxes sent hope i have helped, if so rate me please
Oct 04, 2007 | Canon FAX-JX200
Fax Transmission Reports
You should have a "setup" button. Press that and go to "fax" set up. You can select your options from there. Your options should include the ability to receive a receipt for all transmissions, or none, or just for failed transmissions. Also, you mentioned you "inherited" the machine. I'd suggest going to hp's website to update the software/drivers. The site is www.hp.com.
Oct 02, 2007 | HP LaserJet 3050 All-In-One Printer
Open Questions:
After I plug in power cord and telephone cord of fax machine to use it, dispaly starts flashing numbers, often going back and forth between 2 numbers, like 19 and 20 or 20 and 21, etc. I have never se machine get dial tone insert item to be faxed, and finally enter fax #, I hear the tones of the #'s I enter over the dial tone which continues and machine does NOT "dial" or make the call. The other odd and new thing since my last successful use of fax machine a few weeks ago after which it was unplugged and put away (standard for me as an infrequent fax user), is that now the display shows alternating numbers such as 20and 21. Later it may be 24 and 25. No information in manual regarding this. SInce the last fax use was to receive a lengthy fax while machine was unattended and I ran out of paper, then replaced paper and got rest of fax, I wondered if that event had triggered this and if there was some memory issue. Again, machine ahd been unplugged after that seemingly successful fax use. I did check memory now and found it to be 0.0& which is to be expected since machine was unplugged . And I do think that I got all the pages of that fax froma few weeks ago. Any ideas for the sudden change? Has not been dropped. Also did find that machine had set itself to pulse dialing although it has always previously been on tone which is its factory setting. So I have manually reset it to tone.Again this is mentioned as another oddity in association with current fax machine dysfunction. Any ideas anyone? Thank you!!!
Mar 02, 2017 | Sharp UX-P115 Plain Paper Thermal transfer...
See all Sharp UX-P115 Plain Paper Thermal transfer Fax Questions
Sharp UX-P115 Plain Paper Thermal transfer Fax Logo
142 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
