Have a Bosch Maxx Classic WAE1806AU/05 bought in Australia and made in Thailand. Has dial for selecting wash and buttons for start/pause, rinse plus, and quick wash. Rinse light is flashing which according to manual means motor fault. Have removed and cleaned filter and associated tubing and found a few things that could have blocked pump but is now clean and moving freely. But back togther but light still flashes and machine won't do anything. Is there some sort of reset sequence I have to do?
  • 2 more comments
  • afmartyn Apr 02, 2011
    Sounds fair, I am actually and elctronics engineer with a multimeter etc (dangerous I know), but is there anyway to confirm motor fault and which one. Would have thought pump motor should be easy to check and its saturday here and not going to get anyone out for a while. Also wondering as we have just had renovations and have recently noticed voltage fluctuations with lights flickering and was thinking this could have caused a motor to fail.
  • afmartyn Apr 03, 2011
    This model does not have any display to view error codes, just has rotary dial and lights to indicate if on or in wash, rinse or spin. Bothe the drum motor and pump motor spin freely. Is there a way to check which motor is faulty?
    Thanks Daniel, although mine did not have the dispaly to show error codes, by going thu the sequence of it reset the washing machine and everything now works fine. Bonus points from wife for fixing onweekend and savingat least $100.
    Andy
  • afmartyn Apr 04, 2011
    Yes second solution worked for me and enable me to rest machine and clear fault code after cleaning out pump motor.
  • 1,998 Answers
You would not be checking the pump to clear a motor error you would be checking both the motor and the motor control the pump controls the amount of water that leaves the unit and has a seperate function from the motor entirely two totally differnt systems if you have some electical ability you can disconnect the motor and do a bench test on the motor this will allow you to distinguish between which is causing your problem either the motor or the motor control by your testing and cleaning of the pump area you did nothing to alleviate the motor error and that is why the error code remains. If you have any further questions message me back I await your reply Thanks Rick
Posted on Apr 03, 2011
  • 12,061 Answers
Yes that's quite correct you DO indeed have a "Motor Fault". That flashing LED, tells it all. Those things that you found, in the tubing? that could have blocked the pump, most likely cause the failure?
in any event it is a job for a tech, I feel, that's unless you are a dab hand at DIY & have access to tools and a service manual, then it really is beyond most people.
Ok now a reset will be performed if you simply remove the power from the wall. wait a min or so, and reconnect.
Now if that doesn't work, then my professional advice is to have the unit attended to by a professional. Now contact, either a head or local office of Bosch, now ask then for a referral to a local, servicing center. Ok, then, and now, when here, FIRST only ask for a "Quote" as to the cost and type of repair. This way you can at the least you can then make a decision as to what to do, repair or replace.
Now I say this, as these days repairs can quickly escalate, and customers tell me these days, that if the prospective charges are to be rather a lot, then they would prefer to put that money, towards a NEW unit, with a full warranty. It is food for thought.
Posted on Apr 02, 2011
  • 4,323 Answers
Hi
Enter the diagnostic mode by using this sequence---
Set program selector switch to OFF position. Press and hold the two buttons closest to the dial then turn the program selector counter-clockwise to the first program position. Keep holding the buttons until the display shows P:01 Select test program: Push second button from dial to scroll through tests. Select P:04 for Motor test.Press START/PAUSE button. Test: Sequence: Reversing - Counter-clockwise drum rotation at 50rpm. Clockwise drum rotation at 50rpm.
To abort the test program: Press second button away from program dial or set program selector to Off position. If motor works fine in both clockwise and anticlockwise directions then motor is fine. If not then make sure the wiring harness to the motor is fine, also check whether 120/220 V is coming to the motor. Please be careful while checking the voltage. Replace motor if wiring seems to be fine.
Hope this helps... Please post back if you need more information.
Daniel
Ihave Bosch Maxx 6 e2 error. I tried to reset the machine but it didn't work. What is the problem and what can I do?
The e2 error is a generic error that the machine shows if it's been overloaded or if the load becomes unbalanced during a wash cycle.
To fix you must do a master reset of the washing machine.
1. Close the door and make sure the dial is pointing to the "OFF" function
2. Hold the Start/Pause button and turn the dial anti clockwise (to the left) to the "express 15 min" program at the same time.
3. Hold the Start/Pause button for a minute (the e2 message is meant to start flashing after a minute of holding the button down however with my washing machine this didn't happen) (and neither with mine)
4. Release the button and turn the dial back to the "Off" function.
5. Select any program and the message should not be appearing.
This worked for me
Jan 20, 2016 | Bosch Washing Machines
My Bosch max classic is showing error E2
http://www.fixya.com/support/t3342120-error_code_e2_mean_bosch_maxx
to fix you must do a master reset of the washing machine.
Aug 18, 2015 | Bosch Washing Machines
Washes indefinitely - water does not heat.
perhaps a call to a service man locally will be your best choice . none I have ever worked on had heating as an option .
Jun 02, 2015 | Bosch Washing Machines
Why is my bosch maxx classic frontloader washer tripping the safety switch in fuse box
hi rachel, there's a bad earth in the machine some where,things to check wiring to the motor, check the wiring it's self, any circuit boards, if they are all ok the programmer could be shorting out hope it helps
regards
shaun
May 17, 2012 | Washing Machines
What does error code E2 mean? I have a Bosch Maxx Classic.
Nov 03, 2009 | Bosch Washing Machines
I have E3 error code on a Bosch washing machine maxx classic - what does it mean? thx!
"E3" on a Bosch Maxx means the door is not closed properly. Either there something preventing it from closing properly (blockage) or there is a fault with the locking mechanism.
Jun 11, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
I have a bosch maxx Wlf1600 front loader washing machine
This will require a replacement door lock,easy replacement & part very cheap
Jun 08, 2009 | Audiovox Bosch 718 World Cellular Phone
Bosch Washing MAchine - E2 error message
Hi.
E2 means uneven balance.
The error code gets reset using the following procedure:
Ensure that the machine door is closed. Turn the dial in the OFF position.
Hold down Start/Pause button and turn the dial anti clockwise at the same time until its position is pointing at the Express (15mins) program.
Hold down Start/Pause button until the e2 message starts flashing (or keep holding for about one minute)
Release the button.
Turn the dial again to the OFF position.
The machine is reset. Select any program.
If the message comes back after selecting program, then there is still a balancing problem. Remove and redistribute load, check floor and ensure machine is at level.
Jan 31, 2009 | Bosch WFMC 3200 Front Load Washer
Washing Machines Logo
1,016 people viewed this question
Top Washing Machines Experts
