I want o general remote for 1.5 ac, locate shop
RISHABH ENTERPRISES
Old No. 39, New No. 66, Shop No. 2, City Center
Thirumalai Pillai Road, Thyagaraya Nagar, Chennai, Tamil Nadu 600017
044 28158279Bus: Viveks
Place pageeration ,chennai
Posted on Jun 26, 2011
I have a viper 5706v remote start/security alarm on my 2007 honda accord sedan. When I remote start my car no inside lights, ac/heat unit, or the radio comes on. Just the engine is running.
the accessory 1 and or 2 wires from alarm brain are most likely loose or not connected at all to the accessory wires on the ignition side... hence the lights and accessories not coming on but engine does...
if you installed it I would recheck those wires... if a shop installed it I would take it back to them...
Jun 28, 2016 | Viper Vehicle Parts & Accessories
I need Super General AC ir code to use it on Android universal remote
https://play.google.com/store/apps/details?id=com.tekoia.sure.activities&medium=referrer=utm_source%3Dsure-app-settings%26utm_medium%3Dreferral%26utm_campaign%3Dshare-via-app use this app for super general ac
Jul 07, 2015 | Universal Televison & Video
Cp9430r
Fixed Hunter ceiling fan with remote light pin out wiring 9 wire plug search words
Hunter Ceiling Fan with remote, fails to turn on light, fails to turn on fan..remote receiver is Cp9430r
1) Test your remote, Hunter uses Radio Frequency remote, point RF remote one inch from antenna of working AM radio, press each button on remote, each button will produce static sound from AM radio, if no sound..check battery wiring or solder connection on loop antenna of remote. If no sound on one or more buttons, disassemble and wash key pad with dish soap, rinse and fan dry, retest. If still one button no work apply graphite paint to button to rebuild conductivity of button.
2) Cp9430r receiver is below fan and above light. Remove light assembly, check receiver dip switches, mine was #5 On 1~4 Off, check remote control dip switches in 9v battery compartment also set #5 On 1~4 Off, new 9v battery still no Fan reversal "click" sound heard coming from the large Blue fan reversal relay located inside the Cp9430 receiver. All other buttons control transistors and will make no sound even if they are working.
3) Disassemble / unplug 9 wire plug from Cp9430r receiver, place receiver on wooden table, 9 wire plug has two empty pin squares, one empty in the center, the other empty we will call #1 ..counting clockwise #2,#3...#4,#5..#6,#7and finally top center next to empty #1 is #8. Now #8 is 110v hot/black ...& #4 neutral/white.
4) Shock Danger..carefully apply ac volts to pins #8,#4 use tape if needed, locate quad operational amplifier i call it radio receiver chip HA17324 on board, google HA17324 Datasheet, locate leg #14 it is across from leg #1. Locate small yellow ceramic capacitor very near leg #14, use capacitor's neg as neg for voltmeter, test volts at #1,#7,#8 and #14. My #1 was 3.1v, #7 3.2v, #8 3.25v and #14 .01v ...why #14 so low? I monitored each leg while pressing remote control buttons...no changes. **Desperate, I sparked (1/2 second or less) #14 with 3.14v from positive leg of yellow capacitor** and retested all legs, no change except now #14 rests at .02v and jumps to 2.5v~2.8v when any button on the remote is pressed then rests at .02v. Now Lights work, Fan speeds work, Reverse rotation Works :-)
Pin Out on 9 wire plug, #1 Empty pin, #2 Alternates w up/down fan rotation, #3 goes to 5uf fan capacitor other side of cap goes to white/neutral AC Line, #4 AC Line neutral, #5 goes to Triac? speeds? , #6 Alternates up/down fan rotation goes to up/dn blue relay, #7 goes to up/dn blue relay looks to be AC hot looking for fan probably paired with #3 changing sides at up/dn blue relay, #8 AC Line hot in. Why did **sparking** work, smarter people might know, i think a small spark got stuck in the chip and sparking helped the chip release it out. No electrical education, novice. Jer. 51 8,9 and 11
Feb 24, 2012 | Hunter (25417) Ceiling Fan
Where can i buy remote
Please visit the general accessories electronic stores that sells all sorts of add ON. Visit your shopping area or the malls where normally these shops are located.
If not you can try to get them online if the original remote is not available with Polaroid.
Try the link below;
http://www.universalremote.com/
http://www.logitech.com/en-us/remotes/universal-remotes/devices/4708
Jan 19, 2011 | Polaroid 1913TDXB 19 in. LCD TV/DVD Combo
I have an split-type aircon (brand: General) remote control AR-DL2. it has power and display when i put on batteries. but the aircon unit does not respond to the remote control. what do i do to fix...
i have general electronic ac brand i cant found universal remote can u find one for me what are the universal remote that compatible for my ac tq
Nov 29, 2010 | Heating & Cooling
How can i start my o general ac without a remote?
Hi I have o general split ac and my remot is hidden somewhere which app is best
Nov 01, 2010 | Heating & Cooling
We have just purchased a universal remote for our ducted airwell air con - we need a code for it and airwell isnt listed on the remote
I am sorry if ask wha may seem like a few silly questions, but I need some clarification to assist you better.
-Is this a Residential AC Unit?
-If it is a residential AC unit, where is the thermostat located for this unit?
-Do you know if there is a wall mounted thermistor located on the wall in another room or in the room it cools?
I ask these questions, because generally if the fan coil is mounted in the ductwork, then there isn't always a way of controlling it remotely. Generally, it's controlled by hard-wired thermostat.
If you know it was controlled remotely, then you will need to go the website for the Airwell Fan coil and do a search on programming the remote. I'm sorry there is no short cut for this, you will need to obtain the code from Airwell.
Hope this helped... :D
Jun 27, 2010 | Heating & Cooling
On ac with out remote
Lift the front panel on the indoor unit and press the small button on the right hand side near the electrical cover
Apr 23, 2010 | LG LS-K2430HL Heat Cool Mini Split Air...
I have general model AR-JE11 but it is not switching on or off or anything thru remote , i have chkd the remote with another same a/c and the remote is fine but i dnt know y it is not working ith one of...
Remote control unit are not working. I would like to buy one remote control. I live in dhaka, Bangladesh so how can I buy it? Model No: AR-JE11 for General AC 1.5 Ton Window type. My AC is working by manual on and off.
Mar 23, 2009 | General Heating & Cooling
Heating & Cooling Logo
53 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
