Question about Leviton Hardware & Accessories
I have a VPT24-1PZ 24 hour programmable timer.My question relates to after you progam the astronomic clock there is an off set option to add or subtract time from the sunup/sundown time.By pushing the up arrow you add time or pushing the down arrow you subtract time.My question is by pushing the up arrow are you adding time the light is on between sunset to sunrise or are you adding time to when the light is off between sunrise and sunset?
The timer lets you adjust the preset astronomic time for your area.
This is because actual local times vary.
If the preset time for dusk is 8:00pm and you add 12 minutes, then the timer will turn off-or-on at 8:12.
And then you can change the preset time for dawn by adding or subtracting.
If this is not what exactly you are asking, then set your timer and see what happens, and then add a comment with your findings.
Open following link to download on-line manual
http://waterheatertimer.org/Leviton-timers.html
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Apr 02, 2011
How do you cancel the sunrise sunset program and just use your own times?
Most dawn-dusk wall timers have programmable option... except aube/honeywell.
Most plug-in timers have various options... but some are just astronomic and not programmable
Following link will help identify timer so you can download possible manual with instructions.
http://waterheatertimer.org/How-to-set-timers.html
Gene
Water Heater Timers Save Money
Mar 17, 2015 | Hardware & Accessories
How to set the clock using 24 hr and 12 hr clock
Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#oval
Add comment and describe timer in detail.
Usually if a timer offers choice between 24-hour clock with 1-thru-24 displaying for current time, vrs 12 hour am- 12 hour pm, then the choice is first thing you set before programming. The choice is made before setting current time, and usually this is accomplished with single button push that toggles between 12 and 24 on the display.
The product manual has specific steps.
Not every timer offers 12-24 choice.
Again, add comment and describe timer in detail, or attach photo for best available resources.
Gene
h
Aug 08, 2013 | Woods Indoor 24 Hour Digital Timer (59203)
Uhow do you program a 24 hour timer? Lost the instructions.
Timer is not identified.
1) Open following link for setting analog timer by experimenting with features:
2) If you have analog box timer, the following link might be helpful
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
3) Most programmable timers are 7-day. But some are 24-hour like Intermatic ET100 box timer, etc.
If you have programmable timer, then add a comment and describe timer in detail
Add a comment for more help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
Sep 14, 2011 | Hardware & Accessories
Have a first alert et220 timer. After setting it and turning back to current time, pm light goes out and clock does not run. Manual switch works fine
Timer is not identified for certain. Expert does not have instruction manual and can only guess at cause of problem.
For example not all timers are rated for CFL or halogen bulbs.
Loose light bulb filament, or loose light bulb, or dirt in light bulb socket can cause problem, replace light bulb.
Conflicts in timer programming can cause problem with digital timer.
Read more options listed below:
1) Add a comment and describe timer appearance and if timer is programmable or has a rotary dial.
Describe what buttons appear on timer.
2) Take photo of timer and post on flickr and add comment with link to that photo.
3) Scan your timer instructions into file format. Post this file to Flickr and then add a comment with link to those instructions.
Sep 09, 2011 | First Alert 24 Hour Timers - 2 For The...
Have a taco 24 hr timer on water heater of home we purchased. pls descvribe how to set it to circulate the water just twice a day for a couple of hrs. thx, mg
Your question is very big because recirculation systems have a lot of parts and options.
Please open following link for re-circulation system resources that show pictures of how the system works. After reading information, add a comment with more questions.
http://waterheatertimer.org/Water-heater-recirculation-system.html
The page shows two different types of Taco timers. One timer is programmable and the other timer is called analog timer where the timer dial rotates just like a clock. Small pins located on dial face are set inward or outward. As the dial rotates, the pins move a tiny on-off lever that turns the pump on-off. The pump can also be set to operate thermostatically. You choose either timed operation or thermostatic operation using slide-switch located under timer dial.
Look at, and read information on link above. Try some things on your timer so you are familiar. And then add a comment with specific description of your Taco timer, and include what you have done so far.
Upvote the help.
May 11, 2011 | Taco 265-1 / 563-2 Combination Analog 24...
I have a TORK 920L timer for our church parking lights. The timer is supposed to be a 7 day timer according to the dial. Right now it is turning one revolution per 36 hours. How do I get it to turn in an...
1) It sounds like the clock motor is not operating correctly.
2) This timer is not supposed to be connected directly to the lighting circuit, and should control contactors instead.
http://waterheatertimer.org/Tork-timers-and-manuals.html#900
See what contactors look like
http://waterheatertimer.org/H230A.html
3) I cannot find replacement clock motor for that timer.
4) Tork 920L mechanical dawn-dusk timer seems to sell for $1200
http://kscdirect.com/item/NSI%2BT920L/NSI%2BINDUSTRIES%2BINC_120V%2B2-SPDT%2B20A%2B%2BLIGHTING%2BCONTROL%2BCENTER%250A
5) Contact NSI Tork directly to find sellers:
http://www.tork.com/contact.aspx
6) Intermatic shows 1:1 replacement for tork brand timer is Intermatic T51211BC
http://www.intermatic.com/products/timers/mechanical%20time%20switches/7%20day%2015%20amp.aspx
Electric wholesale on-line showsT515211BC timer for $1000.
http://www.electricsuppliesonline.com/in7diwicat5.html
7) Contact Intermatic directly for more information, for example their second generation astronomic electronic time clocks can perform the same functions.
http://www.intermatic.com/customer%20service.aspx
http://www.intermatic.com/products/timers/electronic%20time%20switches/astronomic%20electronic.aspx
Intermatic electronic Astronomic dawn-dusk ET8015C sells at 1000Bulbs for $179
http://www.1000bulbs.com/product/3384/ELEC-ET8015C.html?utm_source=SmartFeedShoppingcom&utm_medium=Shopping&utm_term=ELECET8015C&utm_content=LightingControls&utm_campaign=SmartFeedShoppingcom&thissku=ELEC777dash777ET8015C&site=www.shopping.com
8) Add a comment and explain what kind of electrical load you have, for example a small church with simple 120V lighting can use inexpensive timer like T101 that sells for $60 at Amazon. Timer trippers would need to be reset.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Feb 07, 2011 | TORK Variable Cycling Timer 8601
I have a 4003 osz time clock and it does not turn lights on and off. Where can I get new insides for the same box.
As of November 2010 or before, Paragon is no longer making timers or parts except Defrost timers.
4003 0SZ is not a defrost timer.
http://waterheatertimer.org/Paragon-timers-and-manuals.html
0SZ suffix appears to be 120Volt astronomic time clock that turns ON at Dusk and OFF at Dawn
4003 is DPST 120Volt 40 amp mechanical timer
http://waterheatertimer.org/pdf/Paragon-4000-24hr-7000-7day.pdf
Tork shows 120volt mechanical Astronomic time piece
7200Z DPST
http://waterheatertimer.org/pdf/7000Z-series-wiring.pdf
MR Supply sells 7200
Intermatic mechanical astronomic clocks:
http://www.intermatic.com/products/timers/mechanical%20time%20switches/astronomic.aspx
These time clocks are Indoor-outdoor and can control 3 different 120V Loads, for example store light in front, outdoor light in back, and outdoor sign. All Loads turn on-off at same time.
Beverly Hills shows the V4547r
Intermatic also makes electronic astronomic time pieces where voltage is selectable, with many timing options (programming is detailed and complicated):
NEMA1 is indoor box
NEMA 3R is indoor-outdoor box.
SPST means timer can control 1 Load
SPDT can control 2 120V Loads
1000 Bubs sells the ET8115C
Add a comment for more free help, for example a question about a specific model or about cross-over wiring. I have experience with wiring diagrams and experience with some different models.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 11, 2011 | Paragon Vintage 24 Hour Timer Command 12...
How do I program Woods digital timer 59203?
Link shows all Woods timers and manuals
If instructions below do not match your timer, look through timers on Woods page to identify, and then add a comment.
Manual for 59203
http://waterheatertimer.org/pdf/Woods-59203.pdf
Instructions below are for Woods 59203 & GE 59203 plug-in programmable timer with 2-prong polarized outlet:
Plug timer in until battery is charged.
If display will not show, then timer battery needs to be recharged, or timer may be busted, or electric circuit is tripped off, or electric circuit heeds to be tested with circuit analyzer.
Set current time:
Press and hold CLOCK button.
Press HOUR and MINUTE to set correct time with am and pm.
Press Day button to set current day.
Release clock button.
Program timer:
Press PROGRAM button until "1 ON" displays. This is program1 ON.
Press MINUTE and HOUR buttons to set ON time for program1
Press DAY button to choose day or group of days for program1 ON
Press PROGRAM button until "1 OFF" displays. This is program1 OFF
Press MINUTE and HOUR buttons to set OFF time for program1
Press DAY button to choose day or group of days for program1 OFF
Press PROGRAM button until "2 ON" displays. This is program2 ON.
Repeat steps above to set ON and OFF time for 5 programs.
When programming is completed, press CLOCK button to exit programming.
Press ON/AUTO/OFF button until Auto displays.
Make sure lamp is turned on.
Make sure bulb is good.
Dec 11, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
I want a programmable timer that can, eg, switch on a single phase electric motor for 10 seconds every hour. It may be 9 secs or 11 secs.
You need a programmable interval timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ET70
Intermatic and Tork make digital timers with interval settings that can be set for specific short-duration with 1 minute minimum.
(Or set to pulse bell ringing with 1-127 seconds.
10 minutes is 600 seconds)
For example ET70115 single-channel timer.
The timer would be set for 24-hour operation, and then programmed for Pulse, and then set timer with 24 programs, with 1 program for each hour.
Mechanical cycle timers from Intermatic:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#cycle
1) Talento 1 hour cycle timer/ each tripper represents 1.25 minutes
2) Model C8835/ each tripper represents 15 seconds.
To operate these timers certain hours of the day, add another timer in-line.
The in-line timer could be digital, but remember digital timers are not protected from power surge and tend to have more problems, and do not have replaceable clock motors and trippers.
Apr 08, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
Hardware & Accessories Logo
651 people viewed this question
Top Leviton Hardware & Accessories Experts
Hippy_dd
Gene Haynes
Are you a Leviton Hardware and Accessory Expert? Answer questions, earn points and help others
