Question about Acer Extensa 4620 Notebook
My DVD rom don't show up in BIOS. can you help?
  • Acer Master
  • 11,800 Answers
It doesn't shows up because it's defective - you will have to replace it. You can buy a similar one for less than $45 at every IT shop.
Posted on Apr 02, 2011
My dvd/cd-rom is not able to play a dvd or cd of anytype
Restart your PC and go into your BIOS and disable the CD/DVD-R, this way it doesn't detect your CD/DVD-R it when you boot to Windows. Once you're in Windows, do a re-start again and go back into your BIOS and enable the CD/DVD-R.
Mar 17, 2013 | Microsoft Windows XP Professional
Gigabyte G41MT-S2P can't boot on cd/dvd rom (installing win7)
If both the HDD and the CD/DVD drive contain bootable devices, the BIOS will usually ask just before starting the HDD boot, while still on the black screen, "Press any key to boot from CD". If you don't watch for this (it's usually at the very bottom or top of the screen), then the system will boot to the HDD.
Jan 18, 2012 | Computers & Internet
I needed to change the hard disk of my computer. I installed the hard disk and tried to install the operating system which I have been using viz. windows XP pro. I inserted the operating system cd in the...
Hi
first go to the BIOS and check your Hard Disk is detected or not if it is detected then go to the boot section on your BIOS and set CD Room as a first boot device and HDD as a second...
or if your hard disk is not shown in the bios then check your hard disk reconnect power on you hard
disk.. and most important thing don't forget to check jumper setting of you hard disk...
ifyou find this is helpful for you so please rate me this will encourage me to domore free work..
regards
sandy
Sep 06, 2011 | Computers & Internet
Dvd writer doesnot showing in bios
Theres' a couple things you need to double check. If you also have a CD-ROM drive connected to the same data cable as the DVD-ROM writer check the jumper on the back side of both. One should be pinned with a two pin jumper and set as a master and the second should be set as the slave. The back side of each ROM drive is marked M for Master, S for Slave & C for cable select. (Cable Select not suggested).
Double check the data cable. Remove and re-seat at the motherboard and at the ROM drives Parallel ATA data cable. Also check the power cable. Remove and re-seat. If everything is connected and the two pin jumper correctly and snug you should see the DVD listed in the BIOS.
Performed a restart and check your BIOS.
Cheers'
Mike
Jul 20, 2010 | ASUS K8S-MX Motherboard
My Lifebook C2340 won't recognize it's own DVD-ROM. When I set the CD in the BIOS, it goes back to "None". It doesn't show up in My Computer. I've cleaned the contacts and tried another DVD. Still won't...
Does it show the device in the BIOS? If not then there could be a problem with the motherboard hardware. If it is not showing up in the BIOS then I would first verify that the power connector for the drive has voltage. Also verify that the slave/master jumpers are correct if the drive has any. You could also try downloading the BIOS update from Fujitsu and see if after updating the BIOS it brings the cd-rom drive detection back. If the BIOS is seeing the drive but Windows is not then the problem could be with the Windows drivers or installation. You could try going into the control panel for windows and use the "detect new hardware function" and see if Windows detects the drive.
Dec 16, 2009 | Fujitsu LifeBook C2340 Notebook
Vostro 1510. CD/DVD-R doesn't show up in the BIOS or 'My Computer' Is this a bad drive or can it be fixed?
If it is a normal IDE type of CD/rom drive it may not show in your BIOS. It may just need to reinstall the driver once up in W**dows.
Oct 31, 2009 | Dell DVD-rom DVD Drive
Want to Boot from dvd ROM
when the pc in post usually on dells bios there is a boot menu option it is usually f12
if you don't know what your doing in the bios it is not a good place to test your skills after pressing F12 just choose cd rom for boot
Jan 28, 2009 | Dell OptiPlex GX280 PC Desktop
Doesnt boot from DVD rom
Hi
I know it sounds a bit odd but were u using a bootable disk to boot?
If yes, then try epgrading ur BIOS version it may help.
Jun 01, 2008 | Dell Inspiron E1405 Notebook
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
Acer Extensa 4620 Notebook Logo
24 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
