Most often the problem is caused by loops in your PHP. One common mistake is to forget to actually ++ add to the counter at the end of a loop, so your loop will continue to run forever. Another common mistake is that, you do add to the counter, but then accidently overwrite it again at the start of the next loop, so you never gain any ground.
Depending on what your loops is doing, this can cause your script to continue to output the same information over and over again (continuing to make the page longer and longer and longer) or it can keep processing the same information over and over without outputting anything giving it the appearance of a page that is trying to load but is lagging.
One way to help you spot this is to echo () the current counter number (or other useful information) at the beginning of each cycle. This way you might get a better idea of where the loop is tripping up.
If you're not using loops, you may want to double check that any HTML or JAVA you are using on your page isn't causing the problem, and that any included pages are without error.
I want to execute java command for a software which is stored on my web server with the help of...
(More)
I want to execute java command for a software which is stored on my web server with the help of command line but this should be executed through php... I have a code as follows,but its not working ,i need to integrate all exec commands. $cmd='cd C:Program FilesApache GroupApache2htdocsmainsphinxsphinx4-1.0beta-binsphinx4-1.0betain'; exec('C:WINNTsystem32cmd.exe'); exec($cmd); exec("java -mx312m -jar wav2text.jar voice_rec.wav>6.txt"); Reply fast>.
Hi there, I am using PHP5, where i need to mail with attachement. exact thing is, am getting the...
(More)
Hi there, I am using PHP5, where i need to mail with attachement. exact thing is, am getting the file in one page through basic input tag with file attribute. in next page am not getting the file path in order to mail it. Please help me.
Hiya Im trying to get a collaspable panel to save state, the example I am currently using is...
(More)
Hiya Im trying to get a collaspable panel to save state, the example I am currently using is downloadable at: http://www.webdesignermag.co.uk/tutorial_files.php?tutorial=19 all the other cookies such as colour and panels work fine, but when you add a new section to the feeds in the panels and refresh the page it reverts to the original state. Is there anything you could advise me on please, or install the demo and have a look for yourself, I would be really grateful if you could help. Regards Richard
