Question about Casio FX9750GII Graphic Calculator
How do you enter grouped data into STAT section of calulator. Eg if you had frequency 40 for x=5, frequency 37 for x=6.7 etc of statitical data, (eg 400 data entries?). Rather that entering every individual data (5 , 40 times etc...)
  • Casio Master
  • 7,993 Answers
I just posted an answer to a question, and I believe it answers yours and a bit more.
  1. Arrange you data in ascending order
  2. Determine the frequency of each datum (for un-grouped data)
  3. Turn Calculator ON
  4. Press the MENU key
  5. Highlight STAT icon and press EXE
  6. Enter the data item in list1 and frequency in list2
  7. When finished entering data press F1:Graph
  8. Select Graph1, Graph2 or Graph3 or SET to fine tune
  9. Select the Type of graph (Histogram)
  10. Select the lowest boundary of the first class (to align)
  11. Set the class width
  12. Press EXE to draw.
Here aree some screen captures to help you along.
They are in chronological sequence. If not just rearrange the sequence.
Posted on May 29, 2011
Reset samsung b3210
Well you can Enter *2767*3855#It helps you to hard reset your phone.Note: By hard resetting you all data will be lost from phone memory eg. contacts, messages etc. so make a backup of your data before hard resetting it.
Jun 12, 2013 | Cell Phones
Construct both an ungrouped and a grouped frequency distribution for the data given below: 139 130 128 134 140 139 136 130 136 128 138 137 134 128 127 136 140 132 141
Sorry to disappoint you but I will just give you directions to do it yourself.
Ungrouped
First sort the data in ascending order (from lowest to highest value)
Create a two-column table
In the first column enter a data value.
In the second column enter the frequency of a data item
Count how many times one particular data value appears in the set (how many repetitions). If it appears only once, its frequency is 1; twice, frequency 2, etc.
For each single (different) data value complete the frequency column.
Grouped
For grouped data representations you create classes: A class is just an interval of values, for example between [125, 130[
For each class interval you create, count how many data values fall within the interval. For the class given as example it will encompass all values between 125 and 129, It I counted correctly its frequency is 4.
Complete the frequency table for the class.
How many classes should you create? Usually this information is given to you. If not, create a moderate number of classes (4,5) It depends on the span of the distribution (highest value- lowest value). The intervals should have equal length. Read your instructions.
Sep 02, 2012 | Office Equipment & Supplies
How do i sort out random numbers?
Here is a sequence of screen captures that illustrates how you do 1-var statistics. I believe it is clear enough.
To sort tap EDIT and select Sort (ascending)
To perform 1-var stats Tap CALC and select one-variable.
Specify the list where the data is (list1), if you have repeated entries you should create a frequency list ( in L2). If no frequency list, frequency is set to 1.
Once you get the stats you can scroll down to read Q1,Q2, Median, etc.
Apr 13, 2012 | Casio ClassPad 300 Calculator
How do you set the intervals for a histogram on the Casio fx-9750gii?
Apr 26, 2011 | Casio FX9750GII Graphic Calculator
How do I program a frequency?
To program a known frequency into your scanner:
- Power the scanner ON
- Press the HOLD key
- enter the channel number that you wish to program
- Press the FUNC and PGM keys
- Enter the frequency, including decimal point (E.G., 155.265)
- Press E to enter the data into memory
More detailed programming instructions can be found in the scanner operating instructions, which you can download and print here:
http://scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/RadioShack-OlderManuals/Pro-83/pro83.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B
Jul 25, 2010 | Radio Shack Pro-83 Scanner
Standard Deviation
Press 2ND [CSR] to clear the stat data.
For each data point, enter the number followed by SIGMA+
If you have grouped data, enter the number followed by 2ND [FRQ] followed by the frequency then SIGMA+
Press 2ND [sigma x n] for the population standard deviation or 2ND [sigma x n-1] for the sample standard deviation.
May 25, 2009 | Texas Instruments TI-30X-IISTK Scientific...
How do you use PICK UP OPTION
Firstly, you have to know the extensions that you want in this Pick-up Group.
Eg: 227,234,+239 all want to be in the same pick up group.
To get into programming press:
-> FEATURE 2 6 6 3 4 4
-> Password: 2 6 6 3 4 4
Now you will have to look at your LCD for 3 arrows
<- Heading....Enter->
<- Back .......Next->
-> you will now see TERMINALS&SETS and press Enter (the top right arrow key) now put in the extn that you want to change (Eg. 227).
-> you should now see the extension number 227: NAME, press Enter (the top right arrow key) again
-> you will now see Line access press NEXT
-> you will now see CAPABILITIES and Enter
-> now keep hitting NEXT till you see PICKUP GROUP:__ and CHANGE this to say 7
-> hit NEXT to save this change, then the HEADING button twice till you see the beginning of this menu eg 227: NAME
-> press Find and type in Ex.234 and follow same steps above to put this person in pickup group 7
-> and once again for Ex.239
After all the sets are now in the same pickup group 7, if anyone's set is ringing, dialing FEATURE 7 5 will answer the calls ringing in the group.
Once pressing the F75, whatever call was ringing the longest will be answered first... for your knowledge.
Apr 15, 2009 | NorStar Meridian M7310 Phone
How to enter data for SD mode for FX-570 series
I BOUGHT ASENTRY ELECTRONIC COMBONATION SAF FRON A FRE\IEND WHO LOSAT EVERERY TNIMH NECESSASY TO RESET TH CUMBO . ISTHRERE ANY W-AY POSSIBIBLE TO OPEH ANDCHANGE THE NEW COMBOM[NATION
Feb 10, 2009 | Casio FX-115ES Scientific Calculator
Data validation in excel
instead of validation use conditional formating (under format menu). If c1<1 format cell as red. It does not have the attention getter that validation does not require the active cell event. Every other option requires the cell become active for a test.
Apr 13, 2008 | Computers & Internet
Excel argument
If I understand correctly, you want to figure the normal wages at 40 hours and less. If there is more then 40 hours, calculate the normal 40 hours, then calculate the hours overtime (time and a half) and add them to get a total.
B5 columns are filled with this:
=IF(A5>$B$1,($B$2*$B$1)+((A5-$B$1)*($B$3)),A5*$B$2)
NOTE: The $ sign doesn't refer to money, it refers to an absolute reference so when copying a formula, the cell references with a $ sign are fixed and don't adjust according to the relative position to where it's being pasted.
Please rate as FixYa! or ask please clarify. ThankYa!
Oct 22, 2007 | Microsoft Excel 2003 (06503995)
Casio FX9750GII Graphic Calculator Logo
272 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
