Question about ASUS Computers & Internet
Motherboard p8p67 ws revelution diagnostic saying 32 and bios wont post
  • ASUS Master
  • 27,725 Answers
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or you might try
During the boot process tap the f8 button three times this will boot into safe mode where the only things
working will be your mouse and keyboard enabling you to attempt to repair your computer
hope this helps
Posted on Apr 02, 2011
P8P67 EVO Won't Boot with power to board
This is almost always the power supply. How exactly did you "check the power supply"? You checked all 12 or so voltage outs under load?
If replacing the power supply doesn't work, replace the motherboard.
Dec 24, 2012 | ASUS P8P67 EVO LGA 1155 Intel P67 SATA...
I need the C:\windows\chipset\asussetup.ini
I would try inserting the motherboard drivers CD and reinstall the chipset. Better still go to ASUS's website and get the newest chipset.
Jun 11, 2012 | ASUSTeK COMPUTER Asus P8p67 Pro Rev 3.1...
Problem with BIOS. Cannot change system date.
Put all default setting on CMOS setup and then set the date by checking that the replaced one battery is energetic enough to meet the system requirement. I mean to say having 3V as it should have.
best of luck!
Mar 11, 2012 | ASUS Motherboard P8P67 PRO REV 31 Core...
I have a ASUS P8P67 LE motherboard, intel i5 - 2310 processor, kingston DDR3 RAM and ASUS ENGTX560 DC/2DI/1GD5 graphic card. When I turn on the PC i get one long and then three short beeps, and the...
> one long and three short BEEP
Something is wrong with some of your hardware.
Turn the computer off.
Disconnect the AC power.
Remove the graphic card.
Connect the AC power.
Turn the computer on, to see if the pattern of BEEP has changed.
Remove the RAM -- all of it.
Reinsert one stick of RAM.
Reinsert the graphic card.
Jul 16, 2011 | ASUS P8P67 LE LGA 1155 P67 SATA 6 Gbps and...
Getting an A2 error on motherboard. How do I fix it?
I think it has something to do with your 2nd RAM module or SLOT
Read more
http://www.overclock.net/intel-motherboards/911168-asus-p8p67-memory-slot-problem.html
Jun 11, 2011 | ASUS P8P67 Deluxe Motherboard
THE PC BOOTS TO 1 LONG BEEP, 3 SHORT BEEPS. THE BOOK SAYS DID NOT DETECT VIDEO. TRIED BOTH PCIEX SLOTS AND 2 DIFFERENT VIDEO CARDS. CAN'T GET OT TO GO ANY FURTHER!!?? WHATS THE LIKELY PROBLEM?
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
test or replace all the leads that attach to your hard drive make sure the connections are secure including electrical extensions + IDE,SATA the ones that attach from your
((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Jan 27, 2011 | ASUS P8P67 PRO - ATX - INTEL P67 - SOCKET...
Bios changes
What are you changing? The motherboard or one of the peripherals such as memory or video card or drive controller may not like the setting or may be incompatible with certain options causing the problem. You may also want to see if there is a bios update to address the issue.
Good luck.
Dec 26, 2008 | ASUS P5QL-E Motherboard, LGA775, Intel P43...
P5NT won't boot
Have you tried clearing the CMOS by removing the battery with PSU off and then shorting the 'reset cmos" (or similar) pins on mobo?
Also found this on the ASUS web site under the specs for the P5NT WS board...
01.gif ASUS CrashFree BIOS 2
The CrashFree BIOS2 feature now includes the BIOS auto-recovery function in a support DVD. Users can reboot their system through the support DVD when a bootable disk is not available, and go through the simple BIOS auto-recovery process. ASUS motherboards now enable users to enjoy this protection feature without the need to pay for an optional ROM.
Have you tried this?
Jul 26, 2008 | ASUS P5NT WS (P5NT WS GREEN) Motherboard
Gigabyte ga-8siml rev 1.0
Click HERE for troubleshooting help.
May 29, 2008 | Intel Motherboard
Computer wont start consistently.
Just reset ur bios settings on ur board by jumper settings or by remove the cmos battery once and once again place it in its position . start ur computer and in bios just reset all the bios settings then restart the computer
Apr 11, 2008 | Foxconn N68S7AA-8EKRS2H nForce 680i SLI...
Computers & Internet Logo
44 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
