Question about Samsung SyncMaster 713N 17" LCD Monitor
Screen is black on my samsung 713n when i plug in vga cable
  • 6 Answers
SOURCE: sansung 915N no video
the monitor gets the wrong signal from the computer (refresh rate too high or scan rate too high )
check the screen refresh rate from Display properties / Settings tab / Advanced button / Monitor settings
worse case: damaged hardware
Posted on Nov 07, 2008
SOURCE: black screen with message about no input signal
might be something wrong with your monitor's data cable
Posted on May 21, 2009
SOURCE: 713N samsung monitor; No display
Necesito Manual de servicio, con todos planos y circuitos, defectología
Posted on Sep 04, 2009
  • 36 Answers
SOURCE: monitor is going out...
hello
I am a technician-informatic. I have repaired about 80 Lcd Samsung monitors with theese problems. I offer the repair manual.
Manual has been done with the experience of the repairing Samsung Lcd monitors. Manual was made by me and shows how to open monitor, how
to solve dark screen problem, how to check and replace capacitors, how to solve the problem non-optimal mode (without reprogramming MCU or
changing the main board) photo are included. 100% functional. The repair process is very simple 30-40min. (does not need a lot of
experience in electronics and expensive instruments) and is not expensive. With this manual you can solve problems by yourself and save
money.
"Not Optimum Mode 1280x1024 60Hz"
- The monitor turns on but turns off by itself, the LED blinks green.
- If you detach from the PC points to "control cable" the picture runs continuously in the vertical direction or presents while line , and
as soon as it is reconnected, the monitor goes off.
- The monitor does not turns on and dont dispaly anything, the LED blinks green-lit, if you detach from pc points to "control cable".
- The monitor turns on, works well some time, but after a window apiers "Not optimum mode. Mode recommended 1280X1024 60Hz"
- The monitor turns on, works well only with low resolution 800x600, when try to change a window that reads "Not optimum mode. Mode
the manual you can find on ebay (my ebay name is asnerejas123):
Samsung monitor repair manual guide 710n,913v,510n more
220498646211
Riparazione - repair Lcd Samsung monitor 710n,913v,510n
220498645860
Reparaturhandbuch für Samsung 710n,913v,510n und andere
220499443698
Posted on Oct 27, 2009
SOURCE: My Samsung syncmaster 713n screen
u can change preset in power supply board
Posted on Jan 30, 2011
Samsung synchmaster 913n vga connected to pc and monitor but black screen just, if i press the leftest button it says "test good" but still black screen
I would first check to make sure your video card is seated properly, unless you have an integrated video chip then you might want to insert a video card on the PCI slot to make sure that the problem is not with your motherboard or your PCI slot. If no problem with that, use a flash light at an angle to light up your monitor when your computer is on and plugged into your monitor to see if the screen is on but maybe too dim too see. If that is the case it sounds like the capacitors in your monitor might be causing a problem. Sometimes the capacitors do no look busted or bulged at the top, one might be bad internally without giving an indication by looks.
Mar 18, 2014 | Computers & Internet
How can i fix the resolution 17" syncmaster 713n
you would normally do this in the display settings either in control panel or by right clicking on desktop and Screen Resolution. The native resolution for this display is 1280 x 1024
Aug 28, 2013 | Samsung SyncMaster 713N 17" LCD Monitor
The screen is all yellow. i am using samsung sync master 713N. it was working fine but now suddenly all white has turned light-yellow.
It does sound like a bad monitor, but first! hook a spare monitor to the computer, if okay The Samsung SyncMaster is the problem, caused by the master board which is attached behind the LCD display, the video signals are feed to the main board where the colors are balanced. To repair this would not be cost effective "cheaper to buy new" Now! if the video cable from the computer to the monitor can be detached, sub another cable just to be sure. Finally if both monitors show the same issue, the problem is in the video graphics card of the computer.
Jan 21, 2011 | Samsung SyncMaster 713N 17" LCD Monitor
Will not come on...green light blinks showing power, but screen remains black...have tried all resets, hooked up different computers to it etc...
It's possibly the cable/plug points. I leave the vga plug unscrewed so that the computer is easy to move around and I sometimes have problems with the screen not coming on. Try a different cable.
Mar 09, 2010 | Samsung SyncMaster 244T 24" LCD Monitor
Samsung 713N screen goes black
OK. IN XP GO TO DEVICE MANAGER AND CLICK ON THE MONITER AND UPDATE THE DRIVERS.IF IT TELLS YOU IT CAN NOT FIND A BETTER DRIVER UNINSTALL..REBOOT AND DOWNLOAD NEW DRIVERS FROM CO. WEB SITE.RICHARDM69
Aug 31, 2009 | Samsung SyncMaster 713N 17" LCD Monitor
HOW MUCH FOR PLUG FROM SAMSUNG FLATSCREEN TO LAPTOP
You mean the VGA cable? You can buy it from PC stores. Just ask for the VGA cable.
Jul 22, 2009 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Displayed "not optimized divice recomanded mode 1024x768"
Press F8 while booting and go to VGA Mode. Press enter key. This should solve the problem.
Saleh aldoseri Information Technology
Al Hala Muharraq Town
P.O Box 1538
Bahrain
Tel:- 00973 13681214
Feb 26, 2009 | Samsung SyncMaster 713N 17" LCD Monitor
Nov 25, 2008 | Samsung SyncMaster 713N 17" LCD Monitor
Sansung 915N no video
Nov 07, 2008 | Samsung SyncMaster 915N 19" Flat Panel LCD...
Samsung SyncMaster 713N 17" LCD Monitor Logo
79 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
