Question about Verbatim (47562) 250 GB USB 2.0 Hard Drive
I connect the in a Mac computer and it works. When I connect it to a computer with Windows vista, xp or 7 it appears the message "new hardware found. your hardware is ready to use". However, I can't read it. I go through Computer or My Pc but it doesn't appear any where. Thanks
Crankstart
  • 696 Answers
SOURCE: reading information on USB
The problem is most likey that the family tree maker file you have created requires the same program to be able to open it.
In order to use the file on your husbands computer you will need to install the same program on his computer and then you should be able to open it with no problem.
Chris
Armor-IT
Posted on Apr 26, 2009
Chinthakaj
  • 416 Answers
SOURCE: verbatim external hardrive not showing up on computer?
A Hard disk making noise, does not sound too good. if it was waorking before on both PC's & not having issues then it has to be with the unit. try on a nother computer. if its the same thing i suggest you look for that warranty card of yours.
Posted on Jun 10, 2009
SOURCE: Verbatim portable hard drive not recognized by XP - works in 2000
Try it is different USB port of your PC. It worked for me.
Farhan
Posted on Nov 10, 2009
  • 10406 Answers
SOURCE: i canĀ“t see the portable hard drive unit in my pc
First, try to connect it to a different computer, to see if it can be read on _any_ computer at all.
Second, check the warranty-status of the unit; if the warranty still is valid, Verbatim will replace the hardware (but will NOT make any attempts to 'recover' your files).
Third, an external drive has two major components -- the disk-drive and the USB-to-disk-drive adapter. Open the enclosure, and remove the disk-drive, and connect it as a 'slave' disk-drive in a desktop computer, to see if that interface hardware is the problem.
Posted on Oct 07, 2010
  • 60 Answers
SOURCE: How to load backup from one computerWindows XP
This is not really a solution but for information. There is no direct upgrade path from Windows XP to Windows 7. So, unless you have a compatible program installed on your Windows 7 PC, you will not be able to import a backup from your XP PC. (To My Knowledge).
Posted on Oct 17, 2010
Computer does not recognise Scanner -- why not?
How old is the scanner? did you read for what Windows version it was made in the first place?
If it is for an older OS then Windows7 and you are using Windows 7 or higher, you ran out of luck.
Always first install the software that came with the device. The driver needed for the device is supposed to be on the install disk.
You have to be sure the computer has the correct software to recognise the hardware and can work with it. From Windows 7 and up, for all hardware that is certified with Microsoft, you can download the drivers from Microsoft. Lots of hardware is recognised when connected and will initiate a download from Microsoft. But not all hardware will do so and not all hardware is compatible (same as not certified by Microsoft from Windows 7 and up) with the new operating systems.
Most things that worked fine with Windows XP and or Vista, can fail with Windows 7 and 8, because the factory that made the hardware in the first place does not ask for certification with Microsoft for their old Hardware. They only spend time and money to get their new hardware certified on the new operating systems. So to make sure your hardware is compatible with the OS. Check the manual and find out, what you have to do so it will work on your computer.
If your device was working on a USB2 port, it also should work on an USB3 port, on the same computer. But don't expect another speed, because the slowest part decides the speed.
Oct 17, 2014 | Veho VFS-008 Smartfix Film Scanner USB...
Where can I obtain the icatch spca 1628 driver
When you connect something to an USB port for the first time, don't hope to much. You have to be sure the computer has the correct software to recognise the hardware and can work with it. From Windows 7 and up, for all hardware that is certified with Microsoft, you can download the drivers from Microsoft. Lots of hardware is recognised when connected and will initiate a download from Microsoft. But not all hardware will do so and not all hardware is compatible (same as not certified by Microsoft from Windows 7 and up) with the new operating systems.
Oct 14, 2014 | Cameras
Display stopped working than recovered
first check for a virus or malware
http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html
microsoft security essentials your operating system must be registered
Win7/Vista/XP 64 bit
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
Open Personalization by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization.
Click Window Color and Appearance.
Under Window Color and Appearance, click the color you want, and then click OK.
Note
If you see the Appearance Settings dialog box instead of the Window Color and Appearance
window, the theme might not be set to Windows Vista, the color scheme might not be set to Windows Aero, or the computer might not meet the minimum hardware requirements for running Windows Aero. For more information, see Troubleshoot problems with Windows Aero.
hope this helps
Aug 15, 2012 | Computers & Internet
I have this problem on my Canon MP210 Scanner that doesn't work! I even re-installed the driver, but nothing worked but the copier works. That mean that the hardware works correctly.
First try a different data cable and a different port. If you use a USB hub or print server, try a direct connection. Check that a known working device can connect to the computer. Check the device manager and power saving settings. What message do you see in the Devices and Printers window (Printers and Faxes for Win XP) for the MP210? What error messages do you for printing and scanning?
For Windows 7, Start > Control Panel > Hardware and Sound > Device Manager. Look for a triangle with a yellow exclamation point or a red x at the bottom of the list at Universal Serial Bus Controllers. You can try updating the drivers for the USB controller or uninstalling them and then rebooting the machine. (The computer should find and install new drivers automatically. However, you should also check in Windows Update for them (check for new updates - optional and important).) With some computers this could be the result of static at the USB ports. Disconnect all of the external devices and the power cord (computer and the outlet). For a laptop, also remove the battery. Then press and hold the power button for 30 seconds. Then put the battery back in (if applicable) and reconnect all of your cables.
For the power savings settings, again for Windows 7, right click on the desktop (anywhere there are no icons or running programs). Select Personalize. Then click on Screen Saver then choose Change Plan Settings. Next click on Change Plan Settings (for the active plan). Then click on Advanced Plan Settings. Scroll down to USB selective suspend.
Did you install the Canon driver, full software or the OS driver? Can you print any documents? (Sometimes the scanner will not respond but the printer still works.) If you have documents in the print spooler, you may need to stop and restart the spooler. (One way to do this is to launch the Command Prompt window (run as administrator for Vista or Windows 7). Start > All Programs > Accessories > right click on Command Prompt and choose Run As Administrator. Type "net stop spooler" without the quotes followed by enter. On the next line, type "net start spooler" again without the quotes and press enter. Now restart the computer.
If the printer works, but the scan buttons do not. If you connected the USB cable before installing the Canon driver, you have a generic driver that may not run the scanner. Uninstall the driver, unplug the data cable and then reboot the computer. Then install the full featured software (if available) from Canon http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp210?selectedName=Specifications#DriversAndSoftware . Next try to scan from the computer. You need to set up the full software with destinations for the scanner buttons and the monitoring program must be running. (If you use the basic driver, the scan buttons will not work. In Windows XP, Vista or 7, you can acquire scans with Paint. File > Import from Camera or Scanner > New Scan. Vista comes with Photo Gallery that can also do this (it can be downloaded for XP and Win7). Vista and Windows 7 also include Windows Fax and Scan to acquire scans.
If the unit still fails to work at the current computer, try connecting it to another (with known working USB ports). If it still fails, then the USB port has failed in the all-in-one. This could be another static issue. With the printer on, unplug the cables (data and power from the printer, outlet and the computer). Press and hold the power button for 30 seconds to a minute. If this doesn't help, if the printer is under warranty ask Canon to repair it.
I hope this helps.
Cindy Wellls
Apr 24, 2011 | Computers & Internet
I want window vista BUT I DONT KNOW HOW CAN I DO THIS
Hi there !
So tell me, what do you want to do with your computer? Do your computer crash and need to reinstall your Windows Vista operating system? Or you want to upgrade your operating system from Windows XP to Windows Vista.
For reinstalling Windows Vista, is it the same procedure when reinstalling Windows XP and Windows 7. Here is the link on how to reinstall operating system http://www.fixya.com/support/r7410371-reinstall_windows_xp_or_installing_clean. For Windows Vista, here is the procedure on how to reinstall Windows Vista.
1. Just put the installer CD into the CDROM Drive and open your computer
2. If message appear to press any key to boot from CD. Press any key to go to Windows Set up.
3. From there, just follow the installation procedure and put CD key if prompted and it will install itself the whole process. It will reboot for 3 times and don't press anykey when this happen. it will be finished within 20 mins.
For upgrading from Windows XP to Windows Vista, remember that all your files and softwares will be remove except for the hardware drivers. But not all the hardware drivers will be 100% working because upgrading the operating system will make your drivers outdated or not compatible with Windows Vista. If some drivers not working, just install the hardware drivers compatible with Windows Vista.
Here is the procedure.
1. Do not put the Windows Vista installer CD yet into the CDROM drive.
2. Open your computer and let it run to Windows XP program until is is finished to load your Windows settings.
3. Now insert your Windows Vista installer CD to the CDROM drive, it will pop up the upgrade installation wizard and just choose the upgrade installation. It will run the upgrading installation and just follow the instruction and it will be finish with 20 mins.
I hope this will help you and thank you for using FixYa !
Jan 07, 2011 | Computers & Internet
Dynex Easy Transfer XP to Windows 7 not working
Remove old drive from computer and install in new computer using ide ribbon. It will connect as a secondary unit and you can then using windows explorer transfer any data on old drive to new one.
Jun 19, 2017 | Dynex Computers & Internet
I cannot find a driver or SW package for Windows 7.
I have the same problem. This is what Tripp Lite told me: "We have tested the existing drivers for the US-4A on both Windows 7 and Mac OS 10.6.2. Neither Windows7 nor Mac OS 10.6.2 functioned with the USB server products (US-4A and U2S-2A) while utilizing current drivers. I suspect that this is due to the fact that both OS' appear to have undertaken a major overhaul over their prior counterparts (XP, Vista, 10.5.X). In order for functionality to exist between the operating systems (in this case Win 7 and Mac OS 10.6.X) new drivers would need to be released. At this point, there is no plan to move forward with drivers to accommodate these operating systems."
I told them I was not impressed and that this lack of support would affect any future purchases of thier products.
Mar 27, 2010 | Keyspan USB Server US-4A (d47710) Print...
Driver problem
just download active sync if you are using windows xp
mobile device center if you are using Vista or windows 7
May 23, 2009 | ASUS Mypal A730W Windows Mobile 2003
Windows xp screen freeze
try reinstalling vmware and XP if that does not work you should get parallels
Mar 16, 2009 | Microsoft Virtual PC 7 with Windows XP...
Verbatim (47562) 250 GB USB 2.0 Hard Drive Logo
Top Verbatim Computers & Internet Experts
Martin Murray
Computer Links
Marcin
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
