Question about Acer Aspire 5535-5050 Notebook
One key on my acer 5535 not working the letter that comes after abc! will use # in place of that letter. nothing happens when press it an there #oesnt seem to be anything stuck un#er it. only stoppe# working to#ay. can u help?
    Genius:
  • Acer Master
  • 1,274 Answers
Pop the key off using your fingernail, and underneath there should be a small rubber boot that actually makes the contact when the key is pressed. it's possible that it has moved (they're usually glued on) try and realign the boot and put the key back on. if it's not that, it's possible that the key simply does not work. if that's the case you'll have to replace the keyboard.
Posted on Jan 28, 2012
Acer 5535 will not boot up
I understand that the Windows is not loading on your computer. It may happen due improper shutdown of the computer or any files corrupted. Please try the steps below to resolve the issue:
1. Keep on tapping F2 key on your computer keyboard as soon as you hit the power button.
2. Then press F9 key, press "Y" to confirm and then Press "F10" and press "Y" to confirm, the computer will restart.
It should take care of the issue, however, if the issue still persists, then follow the below mentioned steps:
You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the data on the computer.
You can also create a set to Recovery disk from the recovery partition, to do so
Start Menu> All Programs> Acer erecovery management> Click Create Factory Default Disk, if you receive any error code or unable to burn the disk, please contact Acer Technical support at 1 800 816 2237 and order for an Recovery Disk.
Thanks and regards,
Jitha
Nov 15, 2011 | Acer Aspire Computers & Internet
My Acer Aspire 5535 after pressing the power button it goes green and the fans whir a little but nothing else happen ony black screen with out any message.
Your 5535 ATI GPU got a problem cause by overheat. You need to reflow the ATI GPU by hot air gun around 30 second. Your laptop display will be fix back. Make sure you clean all dusk inside your laptop and apply new heatsink compound to GPU and CPU ( Processor )
Thanks
Jun 26, 2011 | Computers & Internet
The "E" key on my
check under the key and make sure there isn't dirt or some other foreign debri blocking the key from depressing fully
Mar 28, 2011 | Acer Aspire 5535-5050 Notebook
When i try to type a letter the symbol on that letter comes up. how do i turn that off?
Keep pressing hash (#) key until symbols at top of screen change to abc. (it may be * depending on your device.
Hope this helps and please rate thanks
Mar 26, 2011 | Acer Computers & Internet
How do I input names on address screen in all CAPS
When you are at the "Enter Name" screen while adding a contact to your Phone Book, press the "*" key to switch between modes. You can check which mode you are in by looking at the box in the upper-righthand corner.
"Abc-W" mode will capitalize the first letter of each word
"Abc-S" mode will capitalize the first letter of each sentence
"ABC" mode will enter in all capital letters
"abc" mode will enter in all lower case letters
"123" mode will enter only numbers
You may switch between modes while entering the name if , for instance, you need to switch between letters and numbers,
Nov 02, 2010 | One Touch Jitterbug One-Touch Cellular...
Im sick wit my kf310,i hv a problm wit typing sms too,the alphbt doesnt change..keep aaaaa,dddd,ggg..i need to delete 1 file in phone memory,but day by day there is ZERO file in phone memory to delete..i...
Have you asked your service provider about this issue???
There are several methods used to entering letters and numbers in test messages or SMS. Generally speaking, there is "ABC" mode where you select each letter by pressing a key several times until you get the letter you want. There are several "ABC" modes ... there is "ABC". "Abc" and "abc" all related to capitalization rules you want to follow.
Another method is called in a lot of LG models, "T9" where the phone uses a built in dictionary to select the word you want with only one press on the key. The phone will try to select a word, but it may not be correct after you pressed all the letters. There is a "next" key, usually the "0" which will roll through the words available until you find what you want. I use a modified T9 method. Some times I want a word that is not in the dictionary so I enter part of the word, then space, then clear and enter the next part of the word to get what I want.
Other data entry methods are "123" and symbols. Use your telephone 'soft keys' to make these selections according to instructions on the screen.
You may need to visit your service provider store for additional assistance in operating your telephone.
Thank you for your interest in FixYa.com
Feb 20, 2010 | LG KF310 Cellular Phone
When i press a key it comes up as another comand so when i press the @ key i get ' intead and the pound sign which i cant find comes up as # how do i fix this and how did this happen can anyone help please...
This is because it is set to US english keyboard layout rather than UK English layout.
Go to Start -> Control Panel -> Keyboard
and change the language settings.,.
Oct 05, 2009 | Acer Aspire 5535-5050 Notebook
Number keys locked but number lock key is not releasing them
Try holding the Fn key down and then press numlock.
Mar 18, 2009 | Acer Aspire 5100 Notebook
My snom 300 is dialling letters instead of numbers how do I fix
Pick up the handset and press down on the direction button until the display reads "123" instead of "ABC" or "abc"
Oloff
Nov 25, 2008 | Snom 300 IP Phone
How do you make you r letters capitol on sign in page for email
You can make the letters capital just by pressing "0" key
"0" key here works as a SHIFT key of computer
You will notice that when you press this key, there is a
change in upper right corner, for example look like this:
"abc" All small letter
"Abc" First capital and others small
"ABC" All small letter
Jan 14, 2008 | Cell Phones
Acer Aspire 5535-5050 Notebook Logo
48 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
