Question about Seagate (ST3160827AS) 160 GB Hard Drive
What is DM? how will i use it? what problems can be solved by DM
  • Seagate Master
  • 27,725 Answers
Where did you first see this dm it can be a number of things coul be dm group with multimedia solutions on and offline or twitter A Message (previously called a Direct Message) is a private message sent via Twitter to one of your followers
dont worry about this dm DOS is the one that can fix your hard drive problems
click start run you have to type cmd then type something in then press enter eg: regedit will take you into the registry or chkdsk/f is the check disk utility this is called DOS there are lots of dos commands to fix a computer you can find all of the dos commands online
hope this helps
Posted on Apr 02, 2011
  • Brian Sullivan
    Brian Sullivan Apr 02, 2011
    more on dos
    click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
    click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
    do not do anything while the chkdsk utility is in progress any input may damage your computer hope this helps
Hered a pop sound and now tv wont work
From what I researched, after changin a bulb on these TV's some capacitors fail and "pop" on the DM board, You will have to take it apart and re-cap the caps on the DM board 1000uf 10v (4 - 7 of them). This solves the problem in most cases
Apr 24, 2012 | Mitsubishi WD-52531 Television
Mitsybishi WS-65711
i believe i staed ina similiar case that you seem to be having a over heating of the circuit chips on the mother board. are the cooling fans in the set running.
Aug 30, 2008 | Mitsubishi WT-42315 42" TV
Wen i switch on my computer it freezes at a screen showing biostar motherboard and the url
Remove al.l the power jack from HDD and cd/dvd.and start again,
If the problem is same think RAM problem .
I know when remove the power socket from HDD it will solve,Only reasen hdd is defected due to bad cluster.
You will zero fil with ontrack bootable dm.
Hope this helps.
2.Restart >press F2/F10/Del( for entry in the BIOS)>Set the cd/dvd as 1st priority.
3. Ensure that your Bootable dm cd, in cd rom.
4. Boot from cd will be appear then hit Enter as quick as possible.
5. All it will be possible, if you know dos other wise it will be difficult.
6. DON'T PANIC,I hope, you will can do it
Download link for ontrack dm=
http://www.downtr.net/297918-ontrack-easyrecovery-professional-621.html
Download and make bootable cd from iso file.
7. Type that letter where the dm software in the cd.
8. Type in dos mode. e.g. if your two partition c: d : so your dm will be in e:.
9.type e: and enter , for observation type= dir and enter >now you can see is there ontrack or dm (directy or folder) have or not try it once after one
10 If have ontrack in that folder type=cd (space) ontrack>cd (space) dm hit enter .
11 If all ok type dm and enter
12.Enter
13.Advance installation
14.Maintence
15.Uttility
16.Zerrofil
Hope this helps
Jan 12, 2011 | Biostar P4M800-M7A Motherboard
I also have the timer light blinking and have attempted to power off and resetting with negative results. Any suggestions?
it looks like your dm went bad, to get problem fix, you need remove the dm from the back of tv and open it , and replace the 7 caps in it. that should solve your problem, if need more help with your tv please feel free to call me at 602-810-7149 anytime.
Dec 31, 2010 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65511 has flashing timer light but will not turn on.
I used to have a WS55909 and had this problem. The light is supposed to blink for one minute while the DM (digital module) boots up after a power loss. If the light continues to blink indefinitely, there is a problem with that board. The DM power supplies are known to have faulty capacitors on these models and will need to be replaced. If I remember correctly, there are (7) 1000uf 25v capacitors and they should be desoldered from the board and replaced with 35v ones. Note that my TV model already had 35v caps but changing them solved the problem: electrolytic capacitors have a much shorter life than other components.
The DM is on the left side and is where ANT-DTV and the IR repeaters plug in. The power supply is the board above the main DM board inside the DM case.
If this sounds too technical for you, get a new TV because a repair guy will charge you more than the TV is worth. In other words you could get a (30-46") LCD TV for the same price.
Oct 21, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Wont turn on
Ur DM power board is dead.Replaced the DM power board well solved this problems.Try Tv Repair World.com for a refurbish for a DM power board.
Feb 01, 2010 | Toshiba 50H81 50" Rear Projection...
Timer light blinks rapidly, set will not turn on...
well you could replace caps in the dm module they are 1000microfarads @16 volts there are 7 of them 99% of the time that works if not you have a problem with the e2p module which is also located in the dm this will definitley fix yiur problem
Jun 17, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Rapid flashing light and now power-up after power outage
Replacing those capacitors usually solves the problem however sometimes the issue is back in the power supply. Make sure the 12 volts be supplied to the DM module is present. If not you'll need to fix the power supply.
Jun 16, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Mitsu wd-52628 green flashing timer/power light
steady blinking is the DM failing to complete the boot sequence. Your more than likely needing the DM repair kit.
Jun 18, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Read only
to format you need to hold the display/menu button down for a minute then a menu appears scroll down using FF till you get format then hit play and you will be gided from there
not difficult but impossible to guess
thanks to other guys
Dec 21, 2007 | Olympus DM-20 Digital Voice Recorder
Seagate (ST3160827AS) 160 GB Hard Drive Logo
132 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
