Question about Holmes Products HFH435BR Compact Heater
Hello, How do I get heat on my HOlmes logic heat? The fan and time come on but no heat
  • 6,993 Answers
If the electric heater fan comes on when you turn on the heater, but no heat seems to be coming out, you could have a blown circuit or there is a break in the actual heater coil. Most parts can be ordered directly from the manufacturer and installed quickly and easily. Before you can order the parts you need, you will want to check the unit thoroughly to detect the source of your problem. Replacing a circuit can be easy, whereas replacing or repairing the coil can be much more complicated.
Materials Needed; Voltage regulator, Screwdriver or hex driver, Replacement coil, Replacement circuits, Replacement regulator, soldering gun and solder, Wire caps, Wire clamp and Wire stripping tool.
Step 1 - Locate the Source of the Problem
If the electric heater fan comes on, and you are not getting heat, it could be a blown circuit or resistor or a broken heater coil. You will want to open the case and start testing the circuits with the voltage regulator. Look for breaks in the electrical path, and know voltages will change between circuits that are separated by resistors. Resistors are the little white cylinders that connect to the board here and there on 2 wires. Once you have checked the circuits, also look at the coil. You want to see if there is a break in the line anywhere. These wires work as a complete circuit, and if it snaps from heating and cooling over a long period of use, the circuit will be broken and not give off heat.
Step 2 - Replace Burnt Out Circuits and Resisters
If you have determined that the circuits or resisters on your unit are the source of your problems, then simply use the soldering gun to heat the contacts and remove them. Replace them with parts that meet the voltage standard for their job. This will prevent you from having issues with short circuiting in the unit. If this was the only problem you could find, put the case back together and turn it on, checking the electric heater fan for warm air.
Step 3 - Replacing the Heater Coil
The coil is what will heat up, which builds temperature for the electric heater fan to blow into the room. Modern heaters generally have a replaceable heater coil unit that can simply be installed. Make sure you follow power down procedures before removing the coil to avoid electric shock or short circuiting. Find the electrical connections on the coil and remove them, and then dismount the coil. Install the new coil and close the case up. Be sure to reconnect everything properly before turning it on.
Step 4 - Repairing a Heater Coil
In older units, the electric heater fan is not connected to the temperature gauge. This usually means that the coil is going to be more difficult to replace, as they were not built for maintenance. To repair one of these, you will need a heat resistant metal wire clamp. It should be made of a conductive material such as steel so the current will pass through it to the connected wire. Take the 2 broken ends and clamp them tightly together to repair the broken circuit.
I hope the above was helpful....
Good luck.
Posted on Apr 02, 2011
I completely took apart my holmes air purifier to do a deep cleaning to get the fans and evreything dust free. need diagram to put back together. HAP9422 (model)
Hello, this is Ava with Think Crucial.
This is the manual of your Holmes model number: Holmes HAP9422 Product Manual Hope this was helpful.
You can purchase a wide variety of high quality Holmes replacement parts for your Holmes Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?type=product&q=holmes
Ava B.
Think Crucial Customer Care
Apr 09, 2015 | Holmes Products Air Purifiers
I need a 3-speed fan switch for a Holmes stand fan #HASF1522
Just a thought
If you find a junker fan try the switch off of it. Quite often they will work. Sometimes different makes the switches are interchangeable.
Jan 31, 2015 | Holmes Products Dryers
I had a holmes HPF 650 MCU outdoor pedestal fan which worked great for five years and then abruptly stopped working. Rather than repair it, I tossed it out thinking I could purchase another one. ...
Hi Bill.
Holmes makes a very good fan.
You can buy a new one here:
http://www.overstock.com/Home-Garden/Holmes-HPF650-U-Oscillating-3-speed-Stand-Fan/3473589/product.html
Good luck from Detroit, MI.
Sep 18, 2011 | Holmes Products (HPF650MCU) Stand...
Hello. I have a stand (pedestal) Holmes fan, model number HASF-1516, that is not working when plugged in to the electrical socket. How do I go about troubleshooting?
Firstly please make sure that you connecting wire in not cut at any where and connection is good.
If your connection is ok then also it doesn't rotates then might be your coil has been burned and you need to replace its wiring and check the starter
Aug 18, 2011 | Holmes Products HASF1516 Stand (Pedestal)...
I have a Holmes accutemp model HOH2520 TG-U. The heater operates for about 10-15 minutes and then the digital readout starts fluttering and it stops heating. The next day it does the same thing. Nice...
Hello- These heaters have been recalled.The Holmes heater company will mail you a new free heater, if u mail them back your power cord. Please check the recall website. Julie :)
Mar 02, 2011 | Holmes Products HOH2501 Oil Filled...
Heater comes on but quickly over heats.
There is no Filter On this Model. Check to make sure there is Dirt in the Flow way of the two towers. if that is not it the back up fuse in the heater is going bad.
Jan 16, 2008 | Holmes Products HCT460-U Utility Heater
Holmes Products HFH435BR Compact Heater Logo
149 people viewed this question
Top Holmes Products Heating & Cooling Experts
paulcarew
Gil Shultz
Paul Bade
Are you a Holmes Products Heating and Cooling Expert? Answer questions, earn points and help others
