New Mobo & Processor but no Bleeps etc
I have recently renewed my Motherboard and processor as my previous one died after a power surge.
I have installed a Gigabyte s-series motherboard and dual core processor , however when I turn on the PC the cooling fans work but nothing else, not getting any bleeps, Monitor not receiving signal ( I have tried another monitor still nothing).
Any ideas on what could be wrong and how I can get it working?
Thankyou.
Regatds
Runningman
  • runningman Aug 05, 2008
    Hi
    Thanks for that but already replaced that to 450 watts unit.
    regards
    Richard
    Sergeant:
  • 221 Answers
Could be the power supply is not strong enough to power the system. Replace the power supply with one that is between 350 - 450 watts. This should provide ample power to the system.
Posted on Aug 05, 2008
SOURCE:
My power supply died (popped), so I replaced it (Antec SL350 with an Antec SL350S). However, when I turned on the switch on the back of the power supply, the motherboard powered up immediately (tower...
If you "popped" the power supply, I would check to see if the RAM might have taken a hit as well. Ram chips and CPU are sensitive when it comes to power surges. I would troubleshoot the system, unplug everything. you need monitor, power, cpu, and ram (1 at a time). Check to see if the system will POST. if you do get it to POST, start with 1 item at a time and see if the system will POST every time. If nothing happens, there is a chance you may have a damaged motherboard or cpu.
Mar 28, 2017 | ASUS A8V Motherboard
Problems with Abit NF-M2S Motherboard?
hi there..
i also have the same mobo like yours. i also thinking to upgrade my old processor with better one..
made some quick research.. i would say the mobo unable to support the new processor. checked the BIOS update n CPU support list in Abit's site..
didn't show X4 processor is supported :(
Jan 15, 2010 | Abit NF-M2S Motherboard
Looking for a compatible processor for this mobo
It is impossible to fry a motherboard by using the wrong processor, the board simply won't post. You can use a chart at the ECS website, your motherboard is a Socket A type. Looks like the fastest processor that they have tested is a Athlon XP 3000+.
Apr 04, 2009 | EliteGroup 741GX-M Motherboard
New Motherboard & Processor not working
Usually this symptom has to do or with memory modules with problems or the VGA adapter (integrated) could be damaged. First try to reset the BIOS of *********** taking out the battery and using the reset jumpers informed in the Mother Board manual. Then put the battery and the jumpers back to the factory default position and try again.
If this doesn't work, try to plug the power cord to another 220V as the ground could cause this type of problems.
You can also try to install another VGA adapter to check if you receive the VGA signal in your monitor.
Hope it helps...
Please tell us about your progress.
Best regards
Eduardo
Oct 04, 2008 | Computers & Internet
Replaced Mobo & Processor but PC not working
First step is to check and make sure that all cables are connected properly and that the RAM is seated properly. Also are you using onboard video or an add on card?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/larry_1fe25e09c54eece2
May 30, 2017 | Computers & Internet
Replaced Mobo & Processor Nothing Working
May I know the model of your gigabyte mobo, you just replaced your unit with.
'cause it may not be compatible with the new power suply you have upgraded with.
Thanks
Sep 26, 2008 | Computers & Internet
New Mobo & Processor but nothing happening
You need to have a PSU greater than 450watts. that could be the problem..
Sep 22, 2008 | Computers & Internet
New cpu but no video output
I SEE YOU MENTIONED NOTHING ABOUT INSTALLING ANY DRIVERS FOR THE HD'S DID YOU?
GOOD DAY
KZ
Feb 28, 2008 | Intel Motherboard
Open Questions:
Computers & Internet Logo
49 people viewed this question
Ekse
Alun Cox
